- Moyenne : 0 (0 vote(s))
- 1
- 2
- 3
- 4
- 5
help me!!! swap h22 dans EG
CHICOLAS
Sujets : 69
fastrunner
AYRTON SCENIC
Isuzu, Honda
- Thailand
Sujets : 39
Peut être qu'en fouillant sur ce site (ou en envoyant un e-mail) tu trouveras:
http://www.iwebmedia.net/teamallstock/ci...civic.html
★ Fastrunner World ★ (.)(.)
Motobécane Velover --- Isuzu Dmax 3.0 DiD --- Honda Hre 410 --- Honda Civic Fk2 Type R
dj_spark
Ford Fiesta ST182 mk7.5
77 - Seine-et-Marne France
Sujets : 76
Citation :H22A into Civic information:
MERGING OBD1 CIVIC HARNESS TO H22A ENGINE:
- Take off and mark every single harness connector on where it came from/where it goes from both H22A and stock civic engine. Make sure you label them of where pulled the plug from! This will save a TON of time!
Mount Civic harness on H22A and measure/modify wire to be lengthened/changed as follows:
- Change fuel injector connectors to H22A type and add resistor pack from H22A harness to Civic harness (see diagram on page 4)
- Extend Alternator wires to reach the H22A alternator (match the pinouts)
- Lengthen wire that goes to the starter solenoid on starter
- Attach reverse light sensor wire to the new H22A reverse light sensor wire
O2 sensor (CX only) add 3 wires to O2 sensor and follow o2 wires and change to Prelude O2 sensor connector. And wire the following:
- WHT/RED wire goes to D14 which is O2 Sensor Input
- ORG/BLK wire goes to A6, which is Heater Control
- GRN/WHT wire goes to D22 which is Sensor Ground
- YEL/BLK wire goes to A25 which is Sensor voltage
VTEC wiring: This applies to DX,LX,CX models only in 93-95!
- Wire from the VTEC Solenoid to the A4 pinout at the ECU. Add the pin to the shock tower harness, and female pin at the female shock tower connector.
Knock sensor wiring: (mounted at the rear of the engine near the cylinder head)
Air Intake Bypass solenoid (secondary butterflies)
- Sensor voltage to the A25 pinout (or splice into the Yel/Blk wire connector at the driver shock tower harness.
- ECU Signal leading to A17 pinout on ECU
EGR (Exhaust Gas Recirculation) System: Applies to all model civics except VX
- EGR lift valve solenoid sensor voltage (A25 pinout) & ECU signal to A11
- EGR lift sensor sensor voltage (A25 pinout), ground (D22 pinout) & ECU sensor signal to D12
MOUNT KITS AVAILABLE:
- HASport mount kit
- Place Racing Mounts
- HCP Mount kits
Citation :Wiring: I know that people think that this is the hardest part of the swap, but it is not (thanks to that damn shift linkage pin ). Now, the easiest harness to use is your stock harness. Most of the plugs will match up. If the is the same OBD, the colors of the wires will match up too. Now, there we go:
1. You will have to change the injector clips to the h22a style, that is very easy, just cut and splice. Now, your stock injectors are saturated. The H22a injectors are Peak and hold. you will have to wire in a resistor box. It is easy. there is a diagram:
http://www.hondata.com/techinjectorwiring.html
2. You will have to extend the Alternator wiring. Now, if it is the SAME OBD then you should have no problem. All the colors are the same.
3. You will have to length the wire going to the starter solenoid.
4. You will have to use the H22a reverse light plug. No biggy, just cut and splice.
5. Depending on what model and year you have, it will determine how much wiring you will have to do. there is a diagram to help you:
also you may have to rewire the 02 sensor (on VX and CX only) there are the pinouts:
WHT wire goes to D14 (O2 Sensor Input) - needs to be a shielded wire with ground (it has to be shielded wire, or it will not work right)
BLK wire goes to A6 which is Heater Control
GRN wire goes to D22 which is Sensor Ground
BLK wire goes to B1 or A25 which is Sensor voltage
6. As for the EGR, JDM motors you do not have to wire it up, BUT USDM you do. The JDM motors will get a code for it off and on, but just reset the computer, and it will go away.
7. Sensor ID. There is a pic that will make the job easier:
#1 is ECT (engine coolant temperature switch)
#2 is the coolant sending unit (this is what sends your cluster how hot your water is)
#3 is the knock sensor.
#4 is the oil sensor.
NOW, label all the sensors when you take them off. It will make it easier when you put the new motor in.
Les images sont dispo là bas :
http://www.honda-tech.com/zerothread?id=642479
Donc il est conseillé de garder sont faisceau d'origine et de juste le modifier.
CHICOLAS
Sujets : 69
decidement mister djspark t es un crack :top:
"la valeur de la vie peut être mesurée par le nombre de fois où votre âme a été profondément ému." Soichiro Honda 1906-1991
Ma 260Z le projet: https://www.facebook.com/chicostyle260z/
dj_spark
Sujets : 76
Arf j'y suis pour rien, c'est Google mon ami
civicameleon
http://www.kamikazenipponracer.be/viewfo...13a7a2e5c7
dans ceux qui parle francais et qui en sont pas a leur premier swap y a eux et il sont pas avar en conseille
japan way of life addict
Vinz
jesus
breizh poowwaa
vas aussi te renseigner chez eux :
http://www.clubcivicquebec.com
c'est un forum québecois et j'ai vu quelques photos de swap bien sympa. HA22 turbo echap de 3.5 pouce
mais qu'est ce que je fous en france moi
![[Image: masignature600x150v2fp7.jpg]](http://img440.imageshack.us/img440/4888/masignature600x150v2fp7.jpg)
mon coupé : http://www.japancar.fr/forum/viewtopic.p...&highlight=
en cours : forger le D16Z6 qui traine à la maison, avec le stock de pièces qui traine à la maison (fini  )
monté le LSD dans la nouvelle boite qui traine aussi à la maison (fini  )
rodage fini, carto au poil en cours
bip-bip
accord, shuttle, integra
27 - Eure France
Sujets : 54
question a la con d'ou provient le H22 a la base
C'est bon
dj_spark
Sujets : 76
Prelude et Accord 2.2 de 185 à 220 ch je crois selon la config.
Juliusdesigns
dj_spark
Sujets : 76
Vinz a écrit :regarde vite ici
http://www.gtrteam.com/gtrteam/catalog/i...bd51bad7d4
Cardan pour H22A dans civic
546.00EUR
Faisceau sur mesure H22A pour civic
363.00EUR
Support Moteur H22A pour civic
650.00EUR
1559 Euro et on à pas encore ajouté le prix du moteur et de la boite
Franchement y'a moyen d'économiser rien que sur le faisceau...
Sujet / Auteur
Réponses
Affichages
Dernier message
