Bienvenue, Visiteur ! S’enregistrer Date actuelle : 06-04-2025, 15:44:07
[FAQ] S14 Fuel pump needed?
grumly2000 Hors ligne Senior Member ****
Sujets : 99
04-02-2005, 18:45:45 #1
Voilà en regardant un peu en détail ceci:
http://www.sxoc.co.uk/vbb/showthread.php...ge=4&pp=20
extrait:
Citation :OK, the figures below arent hard fact, and will vary car to-car, but lets take the things in order of being "maxed out" ... dont think anyone could argue with the order even with differance of opinion on figures.
Generally (12psi) 240bhp is OK on std pump & plugs
At (13psi)250bhp fuel pump may cause lean running @ 7K in 5th on WOT
At 14psi (260bhp)fuel pump may cause lean running @ 6.5K in 5th on WOT
At 14psi your WMIC is in danger of overheating after 1 minute flat out .. (that may not seem a long time, but consider standing 1/4 to 100mph takes 14secs ...)
At 15psi (270BHP) your injectors are @ 90%
At 18psi (310BHP) your T28 is maxed.
RR with full fuelling and setup cheack are one of the few ways to get 95% peice of mind ... but this is not 100% safe if it happens to be a 30oC hot summers day when you do your top speed run......or your fuel filter starts to block / muck from your tank blocks your pickup sock (this happened with my old volvo, wouldnt go up hills, couldnt supply the fuel) NOTHING is 100% safe, not even a 100% standard car.
et ceci:
http://www.sxoc.co.uk/vbb/showthread.php...ge=2&pp=20
ben du coup j'ai encore craqué et j'ai pris un wahlbro :'(
http://grumly2000.labrute.fr
Greg_P Hors ligne Senior Member ****
04-02-2005, 19:29:29 #2
Oublie pas le masque pdt l'installation, ou bien 4 aspirine quand tu as fini...
---->>> MP!!!! <<<----------
Sujets : 99
04-02-2005, 19:51:30 #3
Oui t'inquiètes pas; j'ai déjà du remettre par 2 fois ma jeauge à essence suite à des sorties circuit...musclées :]
Donc du coup j'ai du faire ça alors que le réservoir était au 3/4; et j'ai halluciné mais l'essence ça attaque la peau :o
A des moments comme j'ai du me rincer le bras dans l'eau car j'avais la peau rouge de l'essence qui me brulait :o
Tsuchiya Hors ligne Senior Member ****
Sujets : 86
04-02-2005, 23:58:48 #4
grumly2000 a écrit :Oui t'inquiètes pas; j'ai déjà du remettre par 2 fois ma jeauge à essence suite à des sorties circuit...musclées :]
:roll: quel idée c'est évident que l'essence ca brule, la question est pourquoi tu y as mis le feu!!!:]
ok je sort
Piaf
8 225
Dernier message par faburisu
02-12-2009, 19:09:11
1 584
Dernier message par folken
15-09-2007, 01:11:40
3 453
Dernier message par Asphalt Burner
18-04-2006, 13:09:56
