Démontage panneaux de porte Civic EP
demi-secte Hors ligne
08-02-2007, 19:53:31   -   Démontage panneaux de porte Civic EP
Salut,
J'ai l'intention de changer les haut-parleurs d'origine dans mon EP4 et les panneaux de porte m'ont l'air assez difficiles à démonter (aucunes vis apparentes). Quelqu'un aurait une méthode claire? Et aussi, quel est le diamètre des haut-parleurs d'origine dans les portières avant?
Merci pour votre aide
He_Lo Hors ligne
08-02-2007, 20:34:44   -
Tiens mais c'est en anglais
(source : http://civictype-r.co.uk)
Hi, Here comes a description of how to remove the door cards of our cars !
Read and follow step by step then everything will work without damaging the
door card, Good Luck everybody !
A: Behind the "handle" here you will find a small hole in which you put a small screwdriver or something else and push inwards, this will result in the "silver" part of your handle will pop out. Behind this you will find a couple of screws....it is only the top one you need to loosen.
B: At the point of the arrow you can very carefully pry open this whole panel with a flatface screwdriver, behind this you will also find a number of screws....only loosen the one at the far left. Now the door is free from the screwing part....
C: Where the C-arrow points you will find an opening in the plastic....this is where you use a flatface screwdriver to carefully pull outwards (towards you ) which will make the doorcard pop out piece by piece...then just follow the edge of the card around so you can feel that the card loosens totally from the door.
Now comes the tricky part, take the card and pull it upwards along the thick arrow at the top...when you feel that the card has let go from the "lockpin" you carefully pull it away from the a-pillar, this will loosen the card even more from the door. Now the only thing left to do is disconnect the card from the door ( the electricwindows and the "dooropener" ) by pulling easily at the connections.
Now you should have your doorcard in your hand, hopefully !
[Image: door.jpg]
Pour le diamètre = 16.5" je crois...
08-02-2007, 20:53:32   -
Alors là... je suis comblé!
Merci beaucoup.
Big Grin
He_Lo Hors ligne
08-02-2007, 22:13:55   -
Pas de quoi Wink
N'oublie pas les photos du démontage ! Wink
tam Hors ligne
23-02-2007, 03:14:57   -
http://www.k-series.com/tech_detail.php?...ER_INSTALL
jette un coup d oeuil la dessus
  [tuto] Rénovez vos panneaux de portes pour pas trop cher =) Semper_fi 9 6 464 19-12-2012, 22:47:44
Dernier message: Semper_fi
  [EG] Refaire tissu des panneaux de portes Gstorm 12 18 488 14-05-2011, 20:28:08
Dernier message: Gstorm
  [EJ9] demonter panneaux de porte pour mettre une centralisat ddymelo 9 6 033 10-04-2011, 02:51:54
Dernier message: ddymelo
  [EG] panneaux de portes Angel 19 4 926 14-05-2010, 18:32:49
Dernier message: Dandy
  [ej8] panneaux de portes roulecool 5 2 198 12-05-2010, 11:14:55
Dernier message: roulecool
  [EG4] Souci démontage garniture de porte Malakay 4 4 989 07-12-2009, 11:41:37
Dernier message: push
  [EK4] Panneaux de portes et banquette arrière BRIDE RaeKown 4 4 991 11-07-2009, 23:21:49
Dernier message: RaeKown
  [EG6] Comment démonter panneaux de porte avant EG6 Vtieg6RP 5 2 513 10-07-2009, 00:46:04
Dernier message: faburisu
  [EE8] Poids des panneaux de contre porte ? fram35 4 1 899 23-01-2009, 15:12:03
Dernier message: Mister_Z@z
  [EK4 VTI] démonter les panneaux de porte Sam98 3 2 684 07-12-2008, 21:45:34
Dernier message: Sam98
