[FAQ Honda] AAC pour ZC : OEM et autres
TCHEN-TAÏ Hors ligne
Sujets : 19
12-03-2005, 14:40:34   -   [FAQ Honda] AAC pour ZC : OEM et autres
Voilà, c'est dans le titre.
Qui connaît les spec de nos arbres à came pour ZC ?
Advertised Duration ?
Duration @ .050 ?
Gross lift w/ 1.75 ?
Sinon voilà les infos que j'ai récupéré :
86-87 Integra D16a1
Cam Lift: .204(Intake) & .187(Exhaust)
Duration @.50 in degrees: .194 (Intake) & .194(Exhaust)
(Unfortuntaely no Valve Lift info for these, but should be VERY close to 88-89 D16a1)
88-89 Integra D16a1
Cam Lift: .220(Intake) & .210(Exhaust)
Duration @.50 in degrees: .202(Intake) & .201(Exhaust)
Intake Valve Lift: .352(Intake) & .378(Exhaust)
86-89 Integra JDM-ZC
Cam Lift: .236(Intake) & .210(Exhaust)
Duration @ .50 in degrees: .212(Intake) & .210(Exhaust)
Intake Valve Lift: .376(Intake) & .378(Exhaust)
Manufacturer --MODEL # --dur-@--Lift--IN/EX-----Dur IN/EX
D16A1 Intake----------------.050-----220-------------202
ZC Intake--------------------.050-----236-------------212
JG Engine Dynamics
230215------.015-----391/366-------250/250--$280
240240------.015-----408/408-------258/258--$280
1001--------.015-----410/390-------260/254--$280
301---------.015-----417/408-------274/260--$280
Crespo
H2-----------.050----413/413--------214/213--$425
H4-----------.050----451/451--------235/222--$449
H5-----------.050----496/449--------260/260--$650
WEB Racing
35-030------.050-----395/390-------242/228--$311
35-190------.050-----410/395-------250/242--$311
Exospeed
SR-ZC------.010------388/388-------268/254--$240
Race ZC-----.010-----396/396-------272/272--$240
Gude
AISO1-----------------407/407-------224/224
AICS02----------------418/418-------228/228
AICS03----------------418/418-------242/242
AICS04--------------- 418/418-------226/226
Nouveau
AICSO1---------------418/418-------224/224
AICSO3---------------440/440-------256/256
Crane Cams http://www.cranecams.com/
251-0010
Advertise Duration: Int=226 / Exh=228
Duration @ .050: Int=200 / Exh=202
Lobe Separation: 107
Gross lift: 384/376
251-0012
Advertise Duration: Int=232 / Exh=234
Duration @ .050: Int=206 / Exh=208
Lobe Separation: 108
Gross lift: 394/386
251-0014
Advertise Duration: Int=232 / Exh=228
Duration @ .050: Int=206 / Exh=202
Lobe Separation: 110
Gross lift: 394/376
251-0016
Advertise Duration: Int=242 / Exh=244
Duration @ .050: Int=216 / Exh=218
Gross lift: 425/416
Web Cams http://www.webcamshafts.com/
148e/273
Advertise Duration: Int=226 / Exh=230
Lobe Separation: NA
Gross lift: 376/370
115/273
Advertise Duration: Int=240 / Exh=230
Duration @ .050: Int=218 / Exh=208
Lobe Separation: NA
Gross lift: 376/370
202/168
Advertise Duration: Int=282 / Exh=286
Duration @ .050: Int=258 / Exh=262
Lobe Separation: NA
Gross lift: 406/410
Exospeed http://www.exospeed.com/
Street A6
SR909 A6
Advertise Duration: Int=268 / Exh=256
Duration @ .050: Int=NA / Exh=NA
Lobe Separation: NA
Gross lift: 398/388
Race A6 not 100% sure
Advertise Duration: Int=268 / Exh=268
Lobe Separation: NA
Gross lift: 398/398
Delta Camshafts http://www.deltacam.com
260 Profile
Advertise Duration: Int=260 / Exh=260
Lobe Separation: NA
Gross lift: 400/400
272 Profile
Advertise Duration: Int=272 / Exh=272
Lobe Separation: NA
Gross lift: 425/425
the 'tech guy' said that the 260 was designed to be just a stock replacement without having too many aftermarket bolt-ons, where the 272 works better with modifications.
also the 260 out-accelerates the 272 till ~3500rpm where the 272 out-performs.
Gude/Bullfrog http://www.gude.com/
2624
Advertise Duration: Int=241 / Exh=228
Lobe Separation: NA
Gross lift: 415/421
26824
Advertise Duration: Int=228 / Exh=225
Lobe Separation: NA
Gross lift: 425/383
274245 Team Cam
Advertise Duration: Int=242 / Exh=237
Lobe Separation: NA
Gross lift: 428/428
262F2416 Gorilla JR.
Advertise Duration: Int=242 / Exh=258
Lobe Separation: NA
Gross lift: 428/421
270241 Gorilla
Advertise Duration: Int=283 / Exh=268
Lobe Separation: NA
Gross lift: 428/421
JG http://www.jgenginedynamics.com
301X
EF-1
15 cam
Advertise Duration: Int=265 / Exh=265
Lobe Separation: NA
Gross lift: 402/402 (10.2mm)
The specs are as follows:
intake lift .425 duration 228 valve clearance 6
exhaust lift .383 duration 225 valve clearance 8
Réparer ses étriers AR grippés
Vend lame PC av de Promax pour crx : 140e
Recensement ED7
RB26DETTvs2JZ Hors ligne
Sujets : 146
12-03-2005, 15:00:39   -
TCHEN-TAÏ, Pareil, j'avais deja posté la question..et on avait pas trouvé... :roll:
Enfin si il me semble qui si, j'essaairais de trouver ca!! (Merci pour les liens Yes )
[Image: 528858tsukubaautoworkssignature.jpg]
Crédit photo: Autoworks magazine.
Sujets : 19
12-03-2005, 16:59:36   -
Arf dommage. C'est fou ça, personne n'a fait mesurer ces AAC ?
Recensement ED7
civic_16Turbal Hors ligne
Sujets : 20
12-03-2005, 23:31:21   -
Je ferais ça qd je remonterai ma culasse (jen suis au bloc...)
Donc d'ici cet été, je peux pas faire plus vite.
Mais si quelqu'un est "chaud", faut peu de matos (comparateur entre autres) et se reserver une après midi..
Sujets : 19
13-03-2005, 01:06:37   -
J'ai une paire d'AAC en stock.
Que dois-je faire ?
Recensement ED7
flocrx Hors ligne
13-03-2005, 10:01:39   -
TCHEN-TAÏ a écrit :J'ai une paire d'AAC en stock.
Que dois-je faire ?
ah c'est cool ca si tu pouvais me donné les levées
tu prend un pied a coulisse tu mesure la hauteur de la came puis tu mesure la largeur (heu pour etre simple tu prend l'aac d'admission tu mesure donc la hauteur de la came tu ne bouge pas ton pied a coulisse puis tu le tourne(aac) a 90° et tu resssere ton pied a coulisse et la tu a ta largeur ) enfin tu fait hauteur - largeur = levée
voila merci de nous tenir au courant ca m'interresse Wink
[Image: ban_circuit.jpg][/url]
Sujets : 19
13-03-2005, 11:00:42   -
Ouahah ! ça demande de la précision.
Tourner à 90° ???
Je vais essayer.
Recensement ED7
flocrx Hors ligne
13-03-2005, 11:23:40   -
TCHEN-TAÏ a écrit :Ouahah ! ça demande de la précision.
Tourner à 90° ???
Je vais essayer.
ca c'est juste pour expliqué de toute facon tu mesure au plus large
Sujets : 20
13-03-2005, 17:01:33   -
voila ça permet d'avoir la levée.
Pour le reste, c'est un peu plus long à expliquer, mais il faut faire ça AAC monté (donc enlever le cache culbu et faire la manip).
Si tu veux le faire je peux essayer d'expliquer vite fait ..
Sujets : 19
13-03-2005, 17:11:20   -
oui, vas-y, j'ai une deuxième culasse avec AAC monté, de mon ancien moteur cassé.
Recensement ED7
Sujets : 19
14-03-2005, 10:46:34   -
Bon ben, hier j'ai fait les mesures mais j'étais naze hier soir, gros taff sous ma bagnole. Donc hier soir trop crevé pour noter les valeurs.
Alors, voilà ce que j'ai mesuré ça :
Admission : hauteur = 32,5
largeur = 27,0
donc levée = 5,5 mm
Echappement : hauteur = 32,0
largeur = 27,0
donc levée = 5,0 mm
Recensement ED7
icedfluid Hors ligne
59 Nord France
Réputation : 15
14-03-2005, 11:58:02   -
Super ce post ! (çà change) Wink
Remaps sur banc : Honda / RX-7
icedfluid.free.fr/blackpower
icedfluid@gmail.com
Sujets : 20
14-03-2005, 13:28:36   -
Correctif : sur Honda on ne peut pas mesurer la levée comme ça, à cause des poussoirs (d'ailleurs 50 mm de levée c débile, on devrait trouver dans les 9/10 mm d'origine, et les AAC les plus méchants sont dans les 13 mm et quelques).
Pour faire les épures de distri :
1) le matos : un comparateur à touche avec un support orientable et un disque gradué 360°
2) le graphe :
Fleche en abscisse les ° , -180° à +180° normalement, mais dans le réalité on va moins loin car il n'y a plus rien d'intéressant.
:!: le 0° correspond au PMH
Fleche en ordonnée les mm (relevé du comparateur)
3) comment on fait (en gros) : il faut lever la voiture (on va faire "tourner" le moteur en tournant une roue).Il faut fixer le disque 360° sur la poulie de vilo, mettre le moteur au PMH, et ajuster le "0°" du disque (faire un repère en face du 0 après ajustement). Ensuite il faut placer la touche du comparateur sur le haut de la soupape (ici sur le poussoir ça devrait être bon) et surtout le précontraindre un peu pour avoir de la marge dans les 2 sens).
Après c'est pas très dur : il faut faire tourner le vilo (ex de 10° en 10°) et relever la valeur donnée par le comparateur en partant du PMH.
Une fois ceci fait pour les 2 AAC, on doit obtenir un graphe avec deux courbes (qui font chacune une "bosse") et qui doivent se croiser un peu avant le PMH (axe vertical).
A partir de cela, si tout à été bien fait, on peut "voir" la levée maxi et calculer les angle d'ouverture.
Comme je suis pas chez moi je n'ai pas de photos dispo, ni les formules (qui pourtant sont bidons...)
Mais sur le net on trouve facilement tout ce qu'il faut.
Par ex http://www.mikadoracing.com/technique/do...s_aac.html
flocrx Hors ligne
14-03-2005, 13:38:31   -
arf oui sur nos moteur y a un "lingué" donc maintenant faut connaitre la distance entre l'ingué et arbre et lingué et soupape . parce que une levé de 55mm lolllllll
Sujets : 19
14-03-2005, 14:34:53   -
Ah ben voilà pourquoi.
Donc en fait c'est trop compliqué.
Recensement ED7
Sujets : 19
14-03-2005, 15:10:52   -
Attention données top secrètes qui arrivent sur ce post (merci Nico) ...
Levée de came : 5,90mm Adm et Ech (coeff culbu : 1,73)
Jeu de fonctionnement : Adm = 0,12mm Ech = 0,20mm
Temps d'ouverture : Adm = 0,12mm/288° Ech = 0,20mm/269°
Calage de distribution au PMH : Adm = 106° Ech = 110°30
Recensement ED7
59 Nord France
Réputation : 15
14-03-2005, 17:22:12   -
TCHEN-TAÏ a écrit :Levée de came : 5,90mm Adm et Ech (coeff culbu : 1,73)
Sûr, sûr que c'est çà ? Wink
icedfluid@gmail.com
Fushi Hors ligne
Honda Civic
13 - Bouches-du-Rhône France
14-03-2005, 17:23:54   -
Oh, ça c'est du bon post Smile
Merci pour les infos !
"Life is measured by the number of times your soul is deeply stirred" Soichiro HONDA
Sujets : 19
14-03-2005, 17:50:29   -
Oh oui alors, c'est les données constructeurs.
Recensement ED7
flocrx Hors ligne
14-03-2005, 20:16:24   -
oula c'est quoi ces levés de naz que l'on a loll
59 Nord France
Réputation : 15
14-03-2005, 20:23:02   -
J'ai l'impression qu'il y un gros soucis dans ces valeurs ... C'est pas du n'importe quoi ?
Le temps d'ouverture est enorme, et la levée ridicule ! LOL
icedfluid@gmail.com
Sujets : 146
14-03-2005, 20:35:08   -
Heu je sais pas où t'as trouvé ca mais c'est PORTNAWAK dsl.. Oops!
Citation :Temps d'ouverture : Adm = 0,12mm/288° Ech = 0,20mm/269°
C'ets pas possible ca !! :no:
Sinon vais essayer de retrouver ce que j'avais trouvé.. Smile
Merci quand meme Wink
Sujets : 19
14-03-2005, 21:46:58   -
Vous ne savez pas lire ces données ?
Recensement ED7
59 Nord France
Réputation : 15
14-03-2005, 21:51:41   -
TCHEN-TAÏ a écrit :Vous ne savez pas lire ces données ?
On les comprends surtout pas ! Big Grin
Elles sont ... comment dire ... incohérentes !?
icedfluid@gmail.com
Sujets : 19
14-03-2005, 21:54:21   -
Je crois que là j'ai des raisons de me fâcher sévère.
Personne n'a trouvé ces données et ne les a mise sur le forum.
Et qu'est-ce que vous faîtes ?
Vous contestez alors que j'essaie d'aider ?
Je ne suis pas de nature à me fâcher. Vous l'avez peut-être remarqué ?
Mais là, c'est pas normal !!! Evil
Recensement ED7
Sujets : 19
14-03-2005, 21:57:09   -
Lisez toutes les données et sachez que ce sont des valeurs françaises, pas japonnaise ou US
Recensement ED7
Sujets : 146
14-03-2005, 22:08:18   -
TCHEN-TAÏ, autant pour moi... j'ai vraiment lu trop vite.. Oops!
Effectivement tu as raison.. Yes
Fifi Hors ligne
Sujets : 34
14-03-2005, 22:08:56   -
TCHEN-TAÏ a écrit :Temps d'ouverture : Adm = 0,12mm/288° Ech = 0,20mm/269°
Est ce que tes données correspondent a des valeurs mesurées quand la soupape décolle du siège ( off seat) ou a une levée de 1mm ?
le Fifi de l'occident.
www.club-honda-classic.fr
Sujets : 19
14-03-2005, 22:13:14   -
C'est la durée totale avec jeu réglé.
Recensement ED7
59 Nord France
Réputation : 15
15-03-2005, 09:33:10   -
Pourquoi la levé est si petite ??? Je comprends pas.
icedfluid@gmail.com
  [FAQ Honda] : réglage jeu aux soupapes (en images) nico42 177 116 372 30-09-2024, 23:25:26
Dernier message: Kvn7
  [FAQ Honda] tous les codes pannes push 6 64 813 28-10-2022, 09:57:03
Dernier message: Chris6672
  [FAQ Honda] Choisir ses coussinets sur bloc D16 icedfluid 62 27 496 14-04-2022, 16:18:13
Dernier message: fdb35
  [FAQ] Diamètre Barres Anti-roulis OEM Kounkoun78 198 57 078 04-03-2022, 01:11:27
Dernier message: T0MuX
  [FAQ Honda] Purge système de freinage dj_spark 61 35 817 05-07-2021, 13:32:19
Dernier message: Torti
  [FAQ Honda] Vidange boite de vitesse dj_spark 106 73 347 14-06-2021, 09:58:41
Dernier message: boyou2
  [FAQ Honda] Installer une clim d'origine sweet 27 10 375 12-06-2021, 19:04:59
Dernier message: zigzag42520
  [FAQ Honda] Réaliser un mini-me sur D15 umulbuya 352 115 665 16-07-2020, 15:31:49
Dernier message: JM13
  [FAQ Honda] Torsen & pont court d'Itr sur VTI Romuald 182 44 625 23-05-2020, 20:53:39
Dernier message: DAV4WS
  [FAQ Honda] Main relay et problèmes de démarrage Furious Vtec 225 131 498 23-01-2020, 15:23:14
Dernier message: GaetanEC9
