TCHEN-TAÏ
Voilà, c'est dans le titre.
Qui connaît les spec de nos arbres à came pour ZC ?
Advertised Duration ?
Duration @ .050 ?
Gross lift w/ 1.75 ?
Sinon voilà les infos que j'ai récupéré :
86-87 Integra D16a1
Cam Lift: .204(Intake) & .187(Exhaust)
Duration @.50 in degrees: .194 (Intake) & .194(Exhaust)
(Unfortuntaely no Valve Lift info for these, but should be VERY close to 88-89 D16a1)
88-89 Integra D16a1
Cam Lift: .220(Intake) & .210(Exhaust)
Duration @.50 in degrees: .202(Intake) & .201(Exhaust)
Intake Valve Lift: .352(Intake) & .378(Exhaust)
86-89 Integra JDM-ZC
Cam Lift: .236(Intake) & .210(Exhaust)
Duration @ .50 in degrees: .212(Intake) & .210(Exhaust)
Intake Valve Lift: .376(Intake) & .378(Exhaust)
Manufacturer --MODEL # --dur-@--Lift--IN/EX-----Dur IN/EX
D16A1 Intake----------------.050-----220-------------202
ZC Intake--------------------.050-----236-------------212
JG Engine Dynamics
230215------.015-----391/366-------250/250--$280
240240------.015-----408/408-------258/258--$280
1001--------.015-----410/390-------260/254--$280
301---------.015-----417/408-------274/260--$280
Crespo
H2-----------.050----413/413--------214/213--$425
H4-----------.050----451/451--------235/222--$449
H5-----------.050----496/449--------260/260--$650
WEB Racing
35-030------.050-----395/390-------242/228--$311
35-190------.050-----410/395-------250/242--$311
Exospeed
SR-ZC------.010------388/388-------268/254--$240
Race ZC-----.010-----396/396-------272/272--$240
Gude
AISO1-----------------407/407-------224/224
AICS02----------------418/418-------228/228
AICS03----------------418/418-------242/242
AICS04--------------- 418/418-------226/226
Nouveau
AICSO1---------------418/418-------224/224
AICSO3---------------440/440-------256/256
Crane Cams http://www.cranecams.com/
251-0010
Advertise Duration: Int=226 / Exh=228
Duration @ .050: Int=200 / Exh=202
Lobe Separation: 107
Gross lift: 384/376
251-0012
Advertise Duration: Int=232 / Exh=234
Duration @ .050: Int=206 / Exh=208
Lobe Separation: 108
Gross lift: 394/386
251-0014
Advertise Duration: Int=232 / Exh=228
Duration @ .050: Int=206 / Exh=202
Lobe Separation: 110
Gross lift: 394/376
251-0016
Advertise Duration: Int=242 / Exh=244
Duration @ .050: Int=216 / Exh=218
Gross lift: 425/416
Web Cams http://www.webcamshafts.com/
148e/273
Advertise Duration: Int=226 / Exh=230
Lobe Separation: NA
Gross lift: 376/370
115/273
Advertise Duration: Int=240 / Exh=230
Duration @ .050: Int=218 / Exh=208
Lobe Separation: NA
Gross lift: 376/370
202/168
Advertise Duration: Int=282 / Exh=286
Duration @ .050: Int=258 / Exh=262
Lobe Separation: NA
Gross lift: 406/410
Exospeed http://www.exospeed.com/
Street A6
SR909 A6
Advertise Duration: Int=268 / Exh=256
Duration @ .050: Int=NA / Exh=NA
Lobe Separation: NA
Gross lift: 398/388
Race A6 not 100% sure
Advertise Duration: Int=268 / Exh=268
Lobe Separation: NA
Gross lift: 398/398
Delta Camshafts http://www.deltacam.com
260 Profile
Advertise Duration: Int=260 / Exh=260
Lobe Separation: NA
Gross lift: 400/400
272 Profile
Advertise Duration: Int=272 / Exh=272
Lobe Separation: NA
Gross lift: 425/425
the 'tech guy' said that the 260 was designed to be just a stock replacement without having too many aftermarket bolt-ons, where the 272 works better with modifications.
also the 260 out-accelerates the 272 till ~3500rpm where the 272 out-performs.
Gude/Bullfrog http://www.gude.com/
2624
Advertise Duration: Int=241 / Exh=228
Lobe Separation: NA
Gross lift: 415/421
26824
Advertise Duration: Int=228 / Exh=225
Lobe Separation: NA
Gross lift: 425/383
274245 Team Cam
Advertise Duration: Int=242 / Exh=237
Lobe Separation: NA
Gross lift: 428/428
262F2416 Gorilla JR.
Advertise Duration: Int=242 / Exh=258
Lobe Separation: NA
Gross lift: 428/421
270241 Gorilla
Advertise Duration: Int=283 / Exh=268
Lobe Separation: NA
Gross lift: 428/421
JG http://www.jgenginedynamics.com
301X
EF-1
15 cam
Advertise Duration: Int=265 / Exh=265
Lobe Separation: NA
Gross lift: 402/402 (10.2mm)
The specs are as follows:
intake lift .425 duration 228 valve clearance 6
exhaust lift .383 duration 225 valve clearance 8
RB26DETTvs2JZ
TCHEN-TAÏ, Pareil, j'avais deja posté la question..et on avait pas trouvé... :roll:
Enfin si il me semble qui si, j'essaairais de trouver ca!! (Merci pour les liens )
TCHEN-TAÏ
Arf dommage. C'est fou ça, personne n'a fait mesurer ces AAC ?
civic_16Turbal
Je ferais ça qd je remonterai ma culasse (jen suis au bloc...)
Donc d'ici cet été, je peux pas faire plus vite.
Mais si quelqu'un est "chaud", faut peu de matos (comparateur entre autres) et se reserver une après midi..
TCHEN-TAÏ
J'ai une paire d'AAC en stock.
Que dois-je faire ?
flocrx
TCHEN-TAÏ a écrit :J'ai une paire d'AAC en stock.
Que dois-je faire ?
ah c'est cool ca si tu pouvais me donné les levées
tu prend un pied a coulisse tu mesure la hauteur de la came puis tu mesure la largeur (heu pour etre simple tu prend l'aac d'admission tu mesure donc la hauteur de la came tu ne bouge pas ton pied a coulisse puis tu le tourne(aac) a 90° et tu resssere ton pied a coulisse et la tu a ta largeur ) enfin tu fait hauteur - largeur = levée
voila merci de nous tenir au courant ca m'interresse
![[Image: ban_circuit.jpg]](http://www.team-kyoto.com/images/banjpcar/ban_circuit.jpg) [/url]
TCHEN-TAÏ
Ouahah ! ça demande de la précision.
Tourner à 90° ???
Je vais essayer.
flocrx
TCHEN-TAÏ a écrit :Ouahah ! ça demande de la précision.
Tourner à 90° ???
Je vais essayer.
ca c'est juste pour expliqué de toute facon tu mesure au plus large
civic_16Turbal
voila ça permet d'avoir la levée.
Pour le reste, c'est un peu plus long à expliquer, mais il faut faire ça AAC monté (donc enlever le cache culbu et faire la manip).
Si tu veux le faire je peux essayer d'expliquer vite fait ..
TCHEN-TAÏ
oui, vas-y, j'ai une deuxième culasse avec AAC monté, de mon ancien moteur cassé.
TCHEN-TAÏ
Bon ben, hier j'ai fait les mesures mais j'étais naze hier soir, gros taff sous ma bagnole. Donc hier soir trop crevé pour noter les valeurs.
Alors, voilà ce que j'ai mesuré ça :
Admission : hauteur = 32,5
largeur = 27,0
donc levée = 5,5 mm
Echappement : hauteur = 32,0
largeur = 27,0
donc levée = 5,0 mm
icedfluid
59 Nord France
Super ce post ! (çà change)
civic_16Turbal
Correctif : sur Honda on ne peut pas mesurer la levée comme ça, à cause des poussoirs (d'ailleurs 50 mm de levée c débile, on devrait trouver dans les 9/10 mm d'origine, et les AAC les plus méchants sont dans les 13 mm et quelques).
Pour faire les épures de distri :
1) le matos : un comparateur à touche avec un support orientable et un disque gradué 360°
2) le graphe :
en abscisse les ° , -180° à +180° normalement, mais dans le réalité on va moins loin car il n'y a plus rien d'intéressant.
:!: le 0° correspond au PMH
en ordonnée les mm (relevé du comparateur)
3) comment on fait (en gros) : il faut lever la voiture (on va faire "tourner" le moteur en tournant une roue).Il faut fixer le disque 360° sur la poulie de vilo, mettre le moteur au PMH, et ajuster le "0°" du disque (faire un repère en face du 0 après ajustement). Ensuite il faut placer la touche du comparateur sur le haut de la soupape (ici sur le poussoir ça devrait être bon) et surtout le précontraindre un peu pour avoir de la marge dans les 2 sens).
Après c'est pas très dur : il faut faire tourner le vilo (ex de 10° en 10°) et relever la valeur donnée par le comparateur en partant du PMH.
Une fois ceci fait pour les 2 AAC, on doit obtenir un graphe avec deux courbes (qui font chacune une "bosse") et qui doivent se croiser un peu avant le PMH (axe vertical).
A partir de cela, si tout à été bien fait, on peut "voir" la levée maxi et calculer les angle d'ouverture.
Comme je suis pas chez moi je n'ai pas de photos dispo, ni les formules (qui pourtant sont bidons...)
Mais sur le net on trouve facilement tout ce qu'il faut.
Par ex http://www.mikadoracing.com/technique/do...s_aac.html
flocrx
arf oui sur nos moteur y a un "lingué" donc maintenant faut connaitre la distance entre l'ingué et arbre et lingué et soupape . parce que une levé de 55mm lolllllll
TCHEN-TAÏ
Ah ben voilà pourquoi.
Donc en fait c'est trop compliqué.
TCHEN-TAÏ
Attention données top secrètes qui arrivent sur ce post (merci Nico) ...
Levée de came : 5,90mm Adm et Ech (coeff culbu : 1,73)
Jeu de fonctionnement : Adm = 0,12mm Ech = 0,20mm
Temps d'ouverture : Adm = 0,12mm/288° Ech = 0,20mm/269°
Calage de distribution au PMH : Adm = 106° Ech = 110°30
icedfluid
59 Nord France
TCHEN-TAÏ a écrit :Levée de came : 5,90mm Adm et Ech (coeff culbu : 1,73)
Sûr, sûr que c'est çà ?
Fushi
Honda Civic
Oh, ça c'est du bon post
Merci pour les infos !
TCHEN-TAÏ
icedfluid a écrit :TCHEN-TAÏ a écrit :Levée de came : 5,90mm Adm et Ech (coeff culbu : 1,73)
Oh oui alors, c'est les données constructeurs.
flocrx
oula c'est quoi ces levés de naz que l'on a loll
icedfluid
59 Nord France
J'ai l'impression qu'il y un gros soucis dans ces valeurs ... C'est pas du n'importe quoi ?
Le temps d'ouverture est enorme, et la levée ridicule !
RB26DETTvs2JZ
TCHEN-TAÏ
Vous ne savez pas lire ces données ?
icedfluid
59 Nord France
TCHEN-TAÏ a écrit :Vous ne savez pas lire ces données ?
On les comprends surtout pas !
Elles sont ... comment dire ... incohérentes !?
TCHEN-TAÏ
Je crois que là j'ai des raisons de me fâcher sévère.
Personne n'a trouvé ces données et ne les a mise sur le forum.
Et qu'est-ce que vous faîtes ?
Vous contestez alors que j'essaie d'aider ?
Je ne suis pas de nature à me fâcher. Vous l'avez peut-être remarqué ?
Mais là, c'est pas normal !!!
TCHEN-TAÏ
Lisez toutes les données et sachez que ce sont des valeurs françaises, pas japonnaise ou US
RB26DETTvs2JZ
Fifi
Sujets : 34
TCHEN-TAÏ a écrit :Temps d'ouverture : Adm = 0,12mm/288° Ech = 0,20mm/269°
Est ce que tes données correspondent a des valeurs mesurées quand la soupape décolle du siège ( off seat) ou a une levée de 1mm ?
TCHEN-TAÏ
C'est la durée totale avec jeu réglé.
icedfluid
59 Nord France
Pourquoi la levé est si petite ??? Je comprends pas.
