Question freins sur s14/a...
tony-s14 Hors ligne
Sujets : 33
19-01-2005, 18:52:26   -
j ai trouve ca :
""""""""""""""""""""""""" a 750 $ """""""""""""""""
This brake kit features a 13" diameter 2-piece rotor with an aluminum hat and a special high-friction alloy disc which has been crossdrilled and slotted for improved braking performance.
This kit uses stock calipers which are balanced to the rest of the braking system. The stock calipers are more than adequate to provide the clamping force necessary but with a larger rotor they actually dont have to clamp as hard to produce the same braking force - leverage works to your advantage! By using stock calipers, the entire braking system stays balanced and stock pedal travel is maintained.
Kit Includes:
(2) 13" 2-piece rotors
(2) Caliper relocating brackets
Grade 9 fasteners
Nismo 50mm wheelstuds
Hubcentric locating rings
Hubcentric spacing rings
Installation manual
The rotors are guaranteed against warpage!
NOTE: This kit requires that you have at least a 17" wheel in order to fit.
$750.00
tony.. Wink
ian© Hors ligne
Sujets : 46
19-01-2005, 20:28:58   -
hades...j'ai les memes sources...
1999 delsol 160
2001 mr2 175
2003 s14a +-280
2005 Z3M coupé 321
2007 Corolla TS 192 aille
2009 Porsche 996 carrera 4S et ça roule
tony-s14 Hors ligne
Sujets : 33
19-01-2005, 23:42:52   -
je viens d en trouvé au japon a 280 euros, putain j y comprends rien au japonais, c est au pif que j avance.
si y en a qui comprenne.
http://nifty.amikai.com/amiweb/browser.j...c_id=nifty
http://www.apbrake.com/
tony.. Wink
ian© Hors ligne
Sujets : 46
19-01-2005, 23:52:24   -
euh tu peux utiliser la version beta de traduction japonais>>anglais de google..
http://www.google.fr/language_tools?hl=fr
ca aide...sauf sur les textes traités en images...
1999 delsol 160
2001 mr2 175
2003 s14a +-280
2005 Z3M coupé 321
Greg_P Hors ligne
19-01-2005, 23:55:14   -
Attention, APbrake n'a rien a voir avec AP racing, a prior...
---->>> MP!!!! <<<----------
tony-s14 Hors ligne
Sujets : 33
19-01-2005, 23:58:00   -
y avait une adresse mail je viens de lui envoyé quelque chose.
on vera bien.
tony.. Wink
tony-s14 Hors ligne
Sujets : 33
20-01-2005, 18:54:42   -
bon j ai eu une reponse du japonais, il n envoie pas ces pieces.
j ai un contact au japons cela vous interesse que je lui demande ou pas ?
tony.. Wink
Greg_P Hors ligne
20-01-2005, 19:16:58   -
Ben on va attendre ce que peut faire hades, ca m'a l'air une bonne chose ses brochs, si c'est bien fait. Ensuite, on tachera de trouver qqch pour les disques.
Hades Hors ligne
20-01-2005, 19:23:21   -
pour les pattes de déport y auras pas de problème d'en faire mais c'est pour les disques.
Franchement , j'arrive pas à trouver des disques de skyline hors mis DBA et Projetc µ.
Il y aurais que ca qui pose problème, le fournisseur DBA ne fait pas dans l'achat groupé Cry , et en plus il y a 1 mois de délais, la réponse du gars : c'est le temps pour les faires :] , ils doivent les fairent à la lime, les commandes numeriques ils connaissent peut etre pas :]
R33 RB25DET reçu, les 12 travaux d'hercules ? ce type est une tafiole à coté de ce qui m'attend...
A car that will punish driving errors but rewards skillful execution.
A car that will be street oriented and comfortable in daily use.
That's why i love my Silvia
A +, seb.
Greg_P Hors ligne
20-01-2005, 19:38:14   -
On passe par brembo angleterre... Ya des tas de fournisseur la bas, ils ont des skiline. Je pense que bren peut nous en avoir aussi.
ian© Hors ligne
Sujets : 46
20-01-2005, 19:57:51   -
Hey Hey...petite bonne nouvelle... en feuilletant mon catalogue d'accessoires de silvia... j'ai vu un kit GLOBAL avec disques + brakets... avec des disques de JZA80 (supra) disques en 324 donc une compatibilité de base!!! donc peut etre une piste a suivre, sachant que les américains sont équipés en rotors aftermarket pour supra... apres faut savoir si c'est au niveau d'un freinage de sky!
http://cgi.ebay.com/ebaymotors/ws/eBayIS...ename=WDVW
1999 delsol 160
2001 mr2 175
2003 s14a +-280
2005 Z3M coupé 321
tony-s14 Hors ligne
Sujets : 33
20-01-2005, 20:08:36   -
c est sur y a le kit complet apex, pour 800 Euros.
seb, tes pieces tu peux nous les sortir a combien ?
car il y a les durittes a acheté, + les plaquettes , + les disques , + le liquide ht .
c est a voir tous ca ?
tony.. Wink
Greg_P Hors ligne
20-01-2005, 20:16:32   -
Les plaquette c les meme, les durit c pas obligatoire, et le liquide, ca coute 7 euro le bidon de 5.1 ferrodo a pipotau.
SI vous etes d'accord, je peux tenter la commande groupée aupres d'oreca. Ca sera de la carbonne lorraine... une fois qu'on aura verifié que ca fite.
Et puis dans l'histoire, on gagen 15mm sur le disque (324 ou 325mm) au lieu des 310 un peu baard de apex. C'est pas qu'il sont pas efficace, c'est que pour faire refaire des disques, faut voir directement avec lui.
Hades Hors ligne
20-01-2005, 21:38:48   -
Ben pour les disques de supra je sais pas comment ils font mais ca vas pas, il manque 4mm pour la hauteur du chapeau et le trou de centrage c'est du 68 chez nissan ( sur les modèles qui nous interessent ) et une supra c'est du 62, ca ca peut s'usiner mais pour la hauteur, avoir un disque décalé par rapport à l'étrier c'est pas top.
Pour les durites avia, le prix c'est 88 $ les 4.
Mais bon c'est pas le plus chiant, le + ( je trouve perso ) c'est toujours c'est putain de disques avant.
Et c'est vrai que je suis pas aller voir du coté des englich.
Les dimensions d'un disque avant de S14/S15.
diam:280
hauteur chapeau ( totale koi ) : 54
epaisseur : 30 maxi -28 mini
diam trou de centrage : 68
entraxe et nbr de trou : 5 x114.3
disque de skyline GT-R :
diam : 324
hauteur chapeau : 53.75
epaisseur : 30 maxi - 28 mini
entraxe et nbr de trou : 5x114.3
donc si il y en a qui on des adresses, voir avec ces dimensions si ca peut etre dispo .
A +, seb.
Greg_P Hors ligne
20-01-2005, 21:47:49   -
suffti de se fournir chez quelqu'un qui vend des disques de skiline...
tony-s14 Hors ligne
Sujets : 33
20-01-2005, 21:56:21   -
Hades a écrit :.... avoir un disque décalé par rapport à l'étrier c'est pas top. .
etant donné que tu fait des deports d etriers tu ne peux pas les faires justement pour qu ils recuperent ce decalage.
comme ca si c et plus facile de trouvé des disques de supra, on fait une commande groupé et tu les usines tous dans la foulé.
t en pense quoi ?
tony..
photo du kit a 750 $ enumeré plus haut
[Image: mbigbrakecomparo0ww.jpg]
ian© Hors ligne
Sujets : 46
20-01-2005, 22:14:52   -
attention grosse tof...sortie de mon fameux catalogue...y a peut etre des infos a trouver dedant... voila!
[Image: page-brake.jpg]
1999 delsol 160
2001 mr2 175
2003 s14a +-280
2005 Z3M coupé 321
tony-s14 Hors ligne
Sujets : 33
20-01-2005, 22:16:37   -
pour brembo :
http://www.coximport.com/brembo/gt-nissan.html
Hades Hors ligne
20-01-2005, 22:42:42   -
Greg_P a écrit :suffti de se fournir chez quelqu'un qui vend des disques de skiline...
ben ya plus qu'a Wink
pour coximport, ca c'est des kit brembo c'est pas que les disques.
et oui, ya aussi Apexi, endless, mais tout ca c'est dans la meme gamme de prix, cher quoi
A +, seb.
Hades Hors ligne
21-01-2005, 00:28:31   -
ah oui, faudrais penser aussi à avoir des speed bleeders non ?
moi en tout cas j'en prendrais, ca seras moins la merde pour les purges.
A +, seb.
Greg_P Hors ligne
21-01-2005, 00:30:02   -
Ca t'achete directement sur le site. C'est suffisament peu cher pour pas payer de tva
tony-s14 Hors ligne
Sujets : 33
21-01-2005, 09:28:35   -
Hades a écrit :ah oui, faudrais penser aussi à avoir des speed bleeders non ?
c est quoi c est truc, des clapets anti retour non ?
grumly avait posté une adresse je crois ?
tony.. Wink
PS seb tu n a pas repondu a mon post un peu plus haut pour les usinages de disques de supra.
et le gars pour le power fc, il a monté sa sté ?
Hades Hors ligne
21-01-2005, 10:35:52   -
à l'usinage tout peut ce faire pour les pattes de déport , usiner un disque aussi mais à mon avis le prix sera pas pareil.
oui les speed bleeders c'est des clapets anti-retour, je viens de retrouver le site officiel, je les acheterais là.
Pour le power FC , toujours pas de news, je vais me demmerder tous seul, j'ai dejà trouver un gars qui peut me preter une sonde large bande, reste plus qu'a acheter le logiciel.....
A +, seb.
tony-s14 Hors ligne
Sujets : 33
21-01-2005, 23:55:03   -
je viens d envoyé un mail a tous ceux qui font des disques sur ebay.
on verra bien......
tony Wink
grumly2000 Hors ligne
Sujets : 99
22-01-2005, 00:43:32   -
tony.. Wink
Oui vis de purge avec clapets, c'est top.
Chooselife aussi en a mis Wink
http://www.jpcar.net/forum/viewtopic.php...eedbleeder
PS: si vous en commandez tenez moi au jus car il m'en faudrai pour l'embrayage Wink
http://grumly2000.labrute.fr
Greg_P Hors ligne
22-01-2005, 03:54:00   -
J'en ai mis aussi, ca marche bien Big Grin
Greg_P Hors ligne
22-01-2005, 04:29:42   -
Tony, t'exagere...
Ca m'a pris 15 minutes.
http://www.skylineowners.com/forum/showt...hp?t=17240
4000 Series Gold
[Image: 4000gold.jpg]
Front Discs for R32 GTR/33 GTS/34 GTT £222.08 a pair
Front Discs for R33 GTR/34 GTR £237.94 a pair
5000 Series
[Image: 5000series.jpg]
Front Discs R33 GTR/34 GTR £571.05 a Pair
All Prices Include VAT
SInon, apex en vend, 365£ la paire.
[Image: Skyline%20330%201.JPG]
voila, j'ai envoyé 2 ou 3 mails aussi en angleterre, pour voir ce que ca va donner... Ca fera un peu moins loin en shipping.
la je vais me coucher...
tony-s14 Hors ligne
Sujets : 33
22-01-2005, 10:33:54   -
non c est vrai , j ai envoyé 17 de mails au states.
4 reponses negatives.
1 reponse ou il me demandent des precisions année , modele etc...
confirmé moi : Skyline R34 , Année 2001 , Ø324 ep: 30
c est ca ?
greg j ai vu ca aussi sur ton lien, tu lui a envoyé un mail ?
http://www.skylineowners.com/forum/showt...hp?t=15074
tony.. Wink
Ataru kun Hors ligne
22-01-2005, 10:38:08   -
Greg_P a écrit :5000 Series
y s'existe pour 300ZX ?
nan parceque en Suisse on a droit a 6 rainures et 20 trous pas plus.
Hades Hors ligne
22-01-2005, 10:49:01   -
Greg_P a écrit :4000 Series Gold
c'est ceux là que je vais prendre, bizarre c'est plus cher chez le revendeur officiel ?
enfin bref, sinon les 5000 sont jollie mais trés cher, ils sont en 2 partie mais bon à moins d'es plaquettes agressives, un disque normal ca doit tenir en longévité Wink
237£ ca fait quoi dans les 350 euro non ? c pas excessif vu la qualité des galettes LOL
A +, seb.
  [ S13] : Passage en 5 trous et freins S14/Z32 Nicolay45 19 8 750 26-08-2014, 05:59:19
Dernier message: dhovick
  question freins shem hazai 12 2 478 30-04-2007, 18:10:45
Dernier message: Anonymous
  question sur les sorte de moteur sur S14 SR20 6 2 110 27-08-2006, 14:16:16
Dernier message: SR20
  Question générale sur les plaquettes de freins MUSTANG 17 3 335 23-08-2006, 01:33:15
Dernier message: Théo
  Question existantielle (poidsdes freins) musty54 10 1 759 28-06-2006, 19:21:30
Dernier message: musty54
  plaquettes de freins S14 powerpuff mookie 8 2 345 06-06-2006, 12:55:28
Dernier message: Greg_P
  question freins qu'avez vous et que mettriez vous KEMOUTE 02 12 2 025 12-10-2005, 20:40:46
Dernier message: KriZZ68
  Question freins Bubuche 8 1 227 20-09-2005, 23:06:29
Dernier message: grumly2000
  problème démontage des disques de freins sur S14 HKS Yakusa 12 2 744 09-06-2005, 20:51:03
Dernier message: HKS Yakusa
  prix des freins de s14 ou 300 ? bambby 1 1 300 29-05-2005, 01:07:54
Dernier message: Lio
