dj_spark
Ford Fiesta ST182 mk7.5
77 - Seine-et-Marne France Messages : 8 796
Sujets : 76
30-07-2006, 22:14:27 -
J'avais pas osé poster, je me disais ils s'en fouttent royal !!!
Synoptic sur pgmfi.org a écrit :K23 Turbo
1- VTEC operates on the intake camshaft in the turbocharged engine, as compared to the k24a2 in which vtec operates on both camshafts
2- vtec operates with two lobes, meaning that one valve has the ability to switch between high and low cam profiles, as opposed to the three-lobe system on the k24a2 and k20z3, which allows both valves to switch cam profile simultaneously
3- a long reach 26.5mm spark plug is used in the k23a1 compared with the 20.5mm plugs in the k24a2. this allows the water jacket to be larger and hold more coolant
4- the exhaust manifold is made from aluminium, and like the turbocharger itself, is actually water-cooled
5- the turbo engine will incorporate VTC (variable timing control) on the intake cam
6- the k23 uses substantially different engine mounts than does the k24 or k20, incorporating a different style torque-absorbing "dog-bone" type mount on the passenger side
(not shown) the colder spark plugs are slightly narrower than those found on other K-series engines, down to 12mm from 14mm. This is to aid in cooling
(not shown) despite being turbocharged, the engine retains some of the rev-happiness that Honda motors are known for; redline is 6800 RPM
Tsuchiya
Sujets : 86
31-07-2006, 23:41:45 -
SK_Flowne a écrit :Vous êtes bien gentils mais Nissan fait du turbo (et plutôt du très bon) depuis l'aube des 80's.
Et la Skyline reste twin turbo.
Dans la lignée des Fairlady l'intrue c'est la 300ZX (et pas la 350Z) qui est la seule suralimentée du lot.
tu oublie les 280zx qui avait un turbo
Yob1 a écrit :ouai mais c'est vrai que nissan abandonne le turbal pour l'athmo en se moment ( skyline, 350Z ect .. )
par contre les européens reviennent en force sur le marché de la turbal comme la nouvelle golf 1.4l bi turbo ou la megane RS
a bon nissan abandonne le turbo  la nouvelle gt-r c'est un v6 bi turbola 350z est un modéle un peu batard chez nissan de toute façon , elle est la juste pour combler un trou le temps que les nouvelles générations de sportive arrive et elle le fait bien, d'ailleurs elle devrait elle aussi etre déclinée en turbo
Micra K11 1.0
