Blitz K26 Turbo + ext. Wastegate. GT Four, MR2, 3SGTE
Rob Hors ligne
04-11-2004, 14:55:56   -   Blitz K26 Turbo + ext. Wastegate. GT Four, MR2, 3SGTE
Pour ceux qui seraient intéressé !!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...eName=WDVW
Blitz/KKK K26 (K2670 GGA) turbo for sale with BLITZ external wastegate. Also comes with CT20b/CT26 manifold adapter for fitment to 3SGTE engines.
The Blitz wastegate alone is worth a hefty sum.
Rated about 300-320bhp (confirmed by KKK).
So a good fast road upgrade for a ST185, ST165 and ST205 GT Fours, plus MR2 Turbos.
I bought this turbo second hand from japan but have never fitted it to my car as I changed my plans. There's no play in the shaft etc, everything is secure. New gaskets are needed. And some other modifications may be needed to fit this to your car.
From the position that the turbo is in and the positioning of the wastegate when everything is placed together i would suggest that this setup was removed from a MR2. But the turbo positioning can be adjusted to suit.
Cheaper than a hybrid, plus you get the expensive wastegate included.
Some trimming needed on the outlet to fit to chargecooler/A2A cooler
The impeller outlet measures 2 inches and the exducer measures 2 1/2 inches across.
NO RESERVE AUCTION
More pics available on request.
Ill try and answer any questions you may have.
KKK are the preffered and only endorsed turbo by Blitz. Reknowned for performance and durability. Also used by the BMW, Porsche and Ferrari race teams.
Items are heavy so will send via Parcelforce.
Will not split parts.
Will cancel suspicious looking bidders so email your intentions before bidding, if you have low feedback.
[Image: 04_1_b.JPG]
[Image: p5_gal_car.jpg]
DARKJIL Hors ligne
04-11-2004, 15:27:27   -
ET EN FRANCAIS CA DONNE KOI?
http://toyotagt4.free.fr/forum/index.php l'ultime forum francophone pour tous les possesseurs de 3SGTE
GT4 addicted Hors ligne
05-11-2004, 18:32:39   -
ben ça permet au proprios de 3s gte gen 2 d' atteindre voir de dépasser les 300cv...
sur un 3è gen ça sert à que dalle puisque le turbo d'origine permet d'atteindre 300 cv... c pour ça d'ailleurs que le proprio de ce turbo qui a une st205 le revends...
il y a une cale d'adaptatin du turbo KKK sur le collecteur d'origine et qui permet de monter la waste gate externe Blitz fournie avec...
par contre il faut penser qu'à ce kit il faut rajouter une downpipe pour raccorder la ligne... et les durites d'eau et d'huile... :roll:
[Image: 81qa.jpg]
  transfo celica GT four citycar 7 2 474 29-08-2013, 18:38:38
Dernier message: MoTT
  Swap 3SGTE pour Celica ST182 ChuckPower 48 12 883 26-07-2013, 23:53:00
Dernier message: Neoxys13
  [ST 185] Probleme apres changement moteur 3SGTE rev 2 Ïngenix 21 4 317 07-06-2013, 19:10:03
Dernier message: Ïngenix
  couple de serrage des vis ARP pour 3sgte bimorr 3 1 986 03-10-2012, 22:45:24
Dernier message: BiSBAR
  réglage boost controller blitz dual sbc spec r bimorr 1 6 304 31-07-2012, 21:24:42
  Recherche bas moteur 3sgte Rev2 Toy Man 60 1 2 309 28-02-2012, 00:22:12
Dernier message: bozo-merlin
  Vd joint de culasse renforcé metal 1mm 3SGE ou 3SGTE celica GT4 12 4 804 27-02-2012, 10:40:22
Dernier message: gt2_boy
  info swap 3sge 3sgte corolla pierrotg6 1 3 945 05-11-2011, 12:42:47
Dernier message: lebof
  Ou trouvé un par-choc avan de toyota celica gt-four??? KazGTFOUR 6 3 367 26-07-2011, 21:41:06
Dernier message: KazGTFOUR
  [MR Turbo - 3SGTE] Montage d'un Boost Controller diz9-MR 15 25 929 12-04-2011, 21:30:25
Dernier message: djo04
