C'est un probleme connu aux US. J'ai le meme sur mon Forester quand il fait tres froid (-10).
Il n'y a pas grande choses a faire malheuresement. (sauf si la fuite est visible bien sur...)
Le tesxte en anglais:
NHTSA Action Number : PE04002 NHTSA Recall Campaign Number : N/A
Make / Models : Model/Build Years:
SUBARU / IMPREZA 2002-2003
SUBARU / WRX 2002-2003
Manufacturer : SUBARU OF AMERICA, INC.
Component :
FUEL SYSTEM, GASOLINE
![Big Grin Big Grin](https://www.japancar.fr/forum/images/smilies/biggrin.gif)
ELIVERY:HOSES, LINES/PIPING, AND FITTINGS
Date Investigation Opened : January 7, 2004
Date Investigation Closed : May 27, 2004
Summary:
SUBARU REPORTS THAT THE FUEL ODOR IS CAUSED BY "FUEL SEEPAGE DURING COLD START OF THE ENGINE UNDER EXTREMELY COLD TEMPERATURES." THE LEAK OCCURS IN A FUEL LINE IN THE ENGINE COMPARTMENT. IT REPORTS THAT THE FAILURE IS DUE TO "THE MISALIGNED ANGLE BETWEEN TWO FUEL DELIVERY LINES
WHICH RESULTED IN SUCH FUEL SEEPAGE DURING THE FIRST FEW SECONDS OF COLD ENGINE START DURING THESE COLD TEMPERATURES." SUBARU REPORTS THAT
THE TWO FUEL LINES ARE CONNECTED WITH A HOSE THAT BECOMES TOO STIFF IN VERY COLD TEMPERATURES TO CONFORM TO THE MISALIGNMENT. SUBARU HAS ISSUED A TECHNICAL SERVICE BULLETIN (SUBARU SERVICE BULLETIN NUMBER 09-36-03) TO REPLACE THE FUEL LINES WITH NEW LINES THAT ARE PROPERLY ALIGNED
AND THAT HAVE A LONGER CONNECTING HOSE. ODI PHONE CALLS TO MANY OF THE COMPLAINANTS CONFIRM THAT FUEL ODOR IS NOTICABLE DURING VERY COLD TEMPERATURES AND COLD START BUT GOES AWAY AS THE ENGINE WARMS UP, AND THE ODOR IS NOT PRESENT IN WARMER TEMPERATURES. A FEW OWNERS
REPORT THAT ATTEMPTS TO ELIMINATE THE LEAKAGE BY TIGHTENING THE CONNECTING HOSE CLAMPS IS NOT EFFECTIVE IN ELIMINATING THE FUEL ODOR. A SAFETY RELATED
DEFECT HAS NOT BEEN IDENTIFIED AT THIS TIME AND FURTHER USE OF AGENCY RESOURCES DOES NOT APPEAR TO BE WARRANTED. ACCORDINGLY, THIS
INVESTIGATION IS CLOSED. THE CLOSING OF THIS INVESTIGATION DOES NOT CONSTITUTE A FINDING BY NHTSA THAT A SAFETY-RELATED DEFECT DOES NOT EXIST. THE
AGENCY WILL MONITOR THIS ISSUE AND RESERVES THE RIGHT TO TAKE FURTHER ACTION IF WARRANTED BY THE CIRCUMSTANCES.
NHTSA
Subaruuuuuuuuuuuuuuuuuuu...
