correspondance ecu SR20DET
tibo Hors ligne
23-06-2005, 12:48:04   -   correspondance ecu SR20DET
1 Coil pack 1 output (via power transistor Unit)
2 Coil pack 2 output (via power transistor Unit)
3 Tachometer signal output
4 ECCS relay
5 Ignition pulse monitor (for trip comp ?)
6 Ignition Signal Ground
7 RX data (signal from Nissan Consult hand terminal)
8 Coil pack 3 output (via power transistor Unit)
9 Coil pack 4 output (via power transistor Unit)
10 -
11 -
12 A/T signal DT3 (autotrans gear select ?)
13 Ignition Signal Ground
14 CLK clock (timing signal) ?
15 TX data (signal to Nissan Consult hand terminal)
16 AFM Signal input (air flow meter)
17 AFM ground
18 Water temp sensor input
19 Oxygen Sensor input (O2)
20 TPS input (throttle position sensor)
21 Sensor ground
22 CAS 180deg signal (crank angle sensor)
23 CHK check (check start) ?
24 Monitor check lamp (Red) (fault code lamp output)
25 Exhaust over temp warning lamp output
26 Exhaust temp sensor input (behind the Cat)
27 Detonation sensor input (knock sensor)
28 TPS for A/T (kick down switch)
29 Sensor ground
30 CAS 180deg signal (crank angle sensor)
31 CAS 1deg signal (crank angle sensor)
32 Speed sensor input
33 -
34 START signal (from ignition switch)
35 A/T neutral switch input
36 IGN (ignition ON, from ignition switch)
37 TPS power output (power to throttle position sensor)
38 ECCS power
39 ECCS ground
40 CAS 1deg signal (crank angle sensor)
41 A/C on input (Air Con ON from A/C panel or climate control)
42 A/T signal DT1 (auto trans gear select ?)
43 Power steering switch (speed proportional control output)
44 A/T signal DT1 (auto trans gear select ?)
45 Ambient air temp sensor input
46 ECCS backup power
47 ECCS power
48 ECCS ground
101 Injector No 1 drive output
102 EAI control solenoid output (EGR valve control ?)
103 Injector No 3 drive output
104 Fuel pump relay output
105 Fuel pressure control module
106 A/C on output (Air Conditioner on relay signal)
107 Injector ground
108 Injector ground
109 Reverse electrical flow return circuit (alternator fail input ?)
110 Injector No 2 drive output
111 Turbo boost pressure control solenoid (over boost cut ?)
112 Injector No 4 drive output
113 AAC valve control (Auxiliary Air Control, idle speed control)
114 -
115 -
116 Injector ground
trouvé sur nissan performance Wink
http://www.npclub.com/
23-06-2005, 13:46:20   -   Re: correspondance ecu SR20DET
Bien utile, ce topic.
Merci.
Et pour la s14a ?
Je pense entre autre à ces 2 là :
tibo a écrit :19 Oxygen Sensor input (O2)
Pas d'EGR, et pas de sonde d'O2 (je crois) sur la a.
tibo Hors ligne
23-06-2005, 13:49:20   -
Citation :Pas d'EGR,
vi pas d'EGR c est remplacer par un pré cata ou je sais pas trop comment sa s appel sur la ligne
  • bougie iridium
  • sortie 100mm type HKS
  • jante 15” TD drifz
  • glastint
  • collecteur 4/2/1 OBX
23-06-2005, 14:07:11   -
C'est ça oui, pré-cata.
Comme je dois bientôt swapper ma s14 avec un moteur de s14a, je me pose des question niveau correspondance des ECU A/pas A.
En tout cas merci pour le topic, ça tombe à pic pour moi :top:
Je pense pas en avoir besoin (je vais essayer de récupérer le fasceau entier), mais c'est bon de savoir que je l'ai sous le coude.
Biohazard200sx Hors ligne
25-09-2005, 17:02:18   -
ca correspond pas du tout a mon faisceau de S14 Confused
25-09-2005, 17:24:13   -
http://www.emergent.com.au/200sx/s14-ecu.html
voila c beaucoup mieux comme ca...
  Correspondance Reference Butée CA18DET boyou2 7 5 901 18-08-2015, 14:16:39
  ecu sr20det hoblingre 0 1 327 26-04-2012, 19:16:51
Dernier message: hoblingre
  correspondance pieces moteur Z32 / S13 skoh 7 1 742 16-06-2006, 12:57:05
Dernier message: Jack-of-all-Trades
  correspondance amortos? sebar 2 876 19-12-2005, 09:22:41
Dernier message: stef78
  Dump de l'ECU impossible = ECU modifié? grumly2000 4 1 494 16-11-2005, 16:40:42
Dernier message: grumly2000
  correspondance ecu CA18DET tibo 1 2 949 23-06-2005, 13:13:19
Dernier message: Jibe
  correspondance plaquettes S13 et question disque fab14 4 1 249 14-02-2005, 21:52:49
Dernier message: fab14
  correspondance sieges 300zx 2 places/4places tyler 3 1 318 29-09-2004, 18:03:13
Dernier message: tyler
  papillon de sr20det (s13) sur un sr20det s(14) = + de ch 9 3 463 29-05-2004, 23:36:12
Dernier message: Guest
