[FAQ Nissan] Nissan 300ZX
tibo Hors ligne
16-12-2005, 21:26:52   -   RE: [FAQ Nissan] Nissan 300ZX
tous les "how to" sur la 300zx
c'est dans la langue de shakespeare mais il y a de jolie photos qui expliquent donc ca aide voila un petit apercu de se que vous pourer trouver ici
lien
Citation :Engine-Drivetrain, Troubleshooting/Maintenance:
Why does my Z hesitate sometimes?
Why does my Z hesitate at full throttle?
How do I clean my throttle bodies?
How do I tighten my throttle cable?
How do I keep my car from stalling at speed?
What causes safety boost?
How do I keep from constantly going into safety boost?
How do I perform the ECU diagnostic?
How do I perform ECU self diagnostics?
How do I perform the auto transmission diagnostic?
How do I find/fix a vibration?
How do I adjust my parking brake?
Am I having injector failure?
What can I do to pep up my higher mileage Z?
Why won't my car start when I turn the key?
My Z suddenly has 0psi of oil pressure!
How do I replace the oil pressure sender?
What's the 'gurgling' sound from the front fenders?
How do I replace the Idle Air Adjusting (IAA) unit?
How do I locate and repair fuel leaks?
How do I replace my shifter bushing?
How do I change my oil?
What's in the 60K maintenance routine?
How do I replace my stock airfilters or clean my K&N style?
How do I replace my fuel filter?
How do I replace my spark plugs?
How do I replace my timing belt?
How do I perform the HICAS self diagnostic?
How do I change my transmission and differential fluid?
What's the story with turning the brake rotors?
How do I rebuild my brake calipers?
My clutch is slipping, do I need a new one?
My transmission grinds from 5th to 4th, anything I can do?
My ignition coil connectors are all broken, I have to buy the whole expensive wiring harness?
What can be tested through the wiring harness?
What are the normal values displayed on the Techtom MDM-100?
How do I replace my PCV valves?
How do I remove my engine?
How do I replace my turbos?
How do I replace my EGR valve?
How do I check my compression?
How do I replace my clutch?
How do I replace my flywheel?
How do I replace my rear main seal?
How do I remove my transmission?
Does my fan in front of the radiator work?
How do I check my oxygen sensors?
How do I fix my center console clock?
Engine-Drivetrain, Modifying:
Should I get blow-off valves or not? Do they really help?
How do I install blow-off valves?
Could someone explain boost jets to me?
How do I set the boost with boost jets or welding tips?
What is a modified torque converter, and do I want/need one?
How do I paint my brake calipers?
How do I install a K&N style intake?
How do I install a twin POP intake?
How do I tweak my timing?
How do I replace my brake rotors?
How do I install NA headers?
How do I do an ECU swap & boost jet install?
How do I gut my pre-cats?
How do I install an underdrive pulley?
How do I change my brake pads?
How do I install stainless steel brake lines?
Is going with a lightened flywheel worth it?
What's involved in a properly upgraded turbo?
How can I remote mount my Blitz turbo timer or other electronics?
How do I install a traction control?
How do I swap differentials?
How do I install aftermarket intercoolers?
How do I install a HKS Twin Power Ignition Amplifier?
What are the ARP part numbers?
Engine-Drivetrain, Misc:
How do I remove the shift knob?
What is the lug pattern size?
How do I replace a broken wheel stud?
Does my automatic Twin Turbo really have 20 horsepower less at the flywheel?
How do I read the engine timing marks correctly?
What size tires can I run?
Body-Electrical, Troubleshooting/Maintenance:
My hood squeaks when I go over bumps, how do I stop this?
What's that buzzing sound coming from the cabin lights?
How do I bleed the brakes?
How do I get my Z really clean?
How do I remove swirl marks in my paint?
How do I run the diagnostics on my auto climate control?
My Cruise Control doesn't work. What do I check?
Body-Electrical, Modifying:
BOSE?
How do I replace my BOSE system?
How can I put black-outs on my taillights so they look different?
What is the correct offset for aftermarket rims?
How do I rewire my fog lights?
How do I instal a shift light?
How do I make my foglights brighter?
How do I install air guides for rotor cooling?
How do I tweak my stock suspension for Autocross?
How do I install a pillar mounted boost gauge?
How do I replace my front tension rods or install adjustable ones?
How do I install adjustable upper links (A-arms)?
How do I make the 300ZX on the rear panel glow?
Body-Electrical, Misc:
How do I get my dashboard off?
How do I remove my front facia to replace it?
How do remove my front fenders?
Misc:
Can I convert my NA to a TT?
What color is my Z?
More on colors codes & serial numbers
Any stats on what models/colors/etc were produced?
What are the differences between model years?
Where can I look for Zs for sale on the internet?
What should I look for when purchasing a used Z?
What are the best shift points?
What is the best way to import a Z from Canada?
What magazines was the Z in?
How do I read the NGK spark plug codes?
  • bougie iridium
  • sortie 100mm type HKS
  • jante 15” TD drifz
  • glastint
  • collecteur 4/2/1 OBX
tibo Hors ligne
16-12-2005, 21:27:51   -
passages au banc de 300zx prepa ( 30aines de dyno) + descriptif de modification sur 300ZX
lien
de nombreux passages au banc de 300ZX dans differente configuration d'evolution moteur
Citation :Dyno Charts
Air Guides for Rotor Cooling Installation
Timing Tweak
Rotor Replacement
NA Header Install
ECU Swap & Boost Jet Install
Pre-Cat Gutting
Colors Codes & Serial Numbers
ECU Diagnostics
Autocross Suspension Tweak
Underdrive Pulley Install
Brake Pad Install
Stainless Steel Brake Line Install & Brake Bleeding Procedure
Boost Gauge Install
Shifter Bushing Replacement
Oil Change
Tension Rod Install/Replacement
60K Maintenance
Air Filter Replacement/Cleaning
Fuel Filter Replacement
Spark Plug Replacement
Timing Belt Replacement
HICAS Diagnostic
Twin POP Install
Cat-Back Exhaust Install
Transmission and Differential Fluid Change
PCV Valve Replacement
Engine Removal
Turbo Replacement
EGR Valve Replacement
Auto Climate Control Diagnostics
Anti-Sway Bar Install
Clutch and Flywheel Replacement
Intercooler Installation
Door Hinge Alignment
Door Handle/Lock Repair
Ground Net Installation
Split Cargo Cover Repair
  • bougie iridium
  • glastint
  [FAQ Nissan] Mecanique: Bielles S13 Ludo_fC3S 37 14 850 22-12-2023, 19:24:18
Dernier message: folken
  [FAQ Nissan] Nissan SR20DE tibo 18 83 376 30-10-2021, 08:57:54
Dernier message: S0LlDSNAKE
  [FAQ Nissan] Calcul map turbo civic_16Turbal 14 26 808 27-11-2018, 13:04:01
Dernier message: DAV4WS
  FAQ NISSAN : Preparation moteur 200sx s13 sebar 41 24 733 20-08-2008, 15:20:26
Dernier message: 80franck
  [FAQ Nissan] Cablage des feux kouki sur s13 Anonymous 18 18 322 24-01-2007, 21:08:37
Dernier message: Anonymous
  [FAQ Nissan] Changement de turbo a la maniere sur 300zx Maceo 11 16 991 10-10-2006, 10:21:42
Dernier message: Muad-Dib
  [FAQ Nissan] Installation mano T° huile / pression huile Ludo_fC3S 163 45 003 17-06-2006, 21:55:34
Dernier message: Jack-of-all-Trades
  [FAQ Nissan] Nissan 200SX Goose 26 64 627 16-12-2005, 21:03:26
Dernier message: tibo
  [FAQ Nissan] F.A.Q. Globale Nissan Goose 12 126 224 16-12-2005, 14:10:03
  [FAQ Nissan] Nissan 100NX tibo 2 9 647 30-06-2005, 13:25:01
Dernier message: sepi
