- Moyenne : 0 (0 vote(s))
- 1
- 2
- 3
- 4
- 5
AE86 - Mode Diag
Goose
Administrateur
Sujets : 103
Pour ceux qui se demanderait comment mettre l'ECU en mode Diag sur nor vieilles corolla :
![[Image: fi_22.jpg]](https://www.japancar.fr/photos/albums/10001/fi_22.jpg)
C'est toujours bon à savoir...
En cas de besoin je peux egalement mettre la signification des codes erreurs
Webmaster Japan Car - Forum auto
sid
merci!!!!!!mais j ai le livre en D/L et j'avais meme pas fais gaffe que sa y etait dedan..
Spirit Of Winner
Eg6 Gr.A
lebof
Goose
Administrateur
Sujets : 103
Citation :Diagnostic Codes:
Normal Operation: (no malfunction) :
the light will alternatively blink ON and OFF at 0.26 second intervals.
Malfunction Codes Indication :
In the event of a registered malfunction, the light will blink every 0.52 second. The first series of blinks will equal the 1st digit of a 2 digit code and after a 1.5second pause, the second series of blinks will indicate the 2nd digit.
If there are 2 or more codes, there will be a 2.5 seconds pause between each signaled codes.
After all codes have flashed, there will be a 4.5 second interval and the codes will repeat until TE1 and E1 has been disconnected.
2-Trip detection logic:
Diagnostic Codes 20-29 are usually indicated with 2 -trip logic. This means that the ECU will need two repeated engine operational cycles, with the same problem for the code to be indicated, minimizing the false codes. The ignition must be switched OFF between the 2 successive engine operations.
signification des codes erreurs:
http://www.club4ag.com/faq%20and%20tech_...0Codes.htm
Mount
78 Yvelines
l'image marche plus ouinnnn
Sujet / Auteur
Réponses
Affichages
Dernier message
