Greg_P
05-11-2004, 21:25:25 -
Tu me la fait a gratuit?
![[Image: GS_ef9a881fe345b7edf2e52c9cbd28f7a2.png]](http://generateuryelims.free.fr/GS_smileys/GS_ef9a881fe345b7edf2e52c9cbd28f7a2.png)
---->>> MP!!!! <<<----------
fabs13
05-11-2004, 21:30:36 -
ça ce monte facilement sur s13 ?
neuf ou combien de kms ?
normal but pas banal.
fabs13
05-11-2004, 21:54:42 -
oui je viens de me souvenir que la s15 c'est un sr20vet...cqfd
bon bien motivé ca doit ce monté mais bon
Hades
06-11-2004, 10:37:36 -
ce que je veut dire c'est que c'est pas le meme systeme d'embrayage.
alors in english ca donne :
"Can I buy a clutch for my S15 which suits a SR20DET, e.g. from an S13/S14 Silvia/200SX?
No. The first thing you need to know is that the S15 has a dual mass flywheel. This means the clutch plate and flywheel are put together differently to the S13/S14 gearbox/flywheel combination.
The dual mass flywheel is sprung in the middle which is designed to reduce harmonic vibrations induced from rotational idle of the flywheel. Other benefits are supposed to be smoother driving and easier gear changes.
Because of this, you will need to either buy a clutch which is a solid centre and is suited to the dual mass flywheel. Alternatively, change the flywheel to a solid centred design and have a clutch which is sprung (as in the S13/S14).
Many S15 owners have converted to sold centre flywheel design and have had no difficulties or adverse side-effects. However, it is possible that you hear a whining noise which is the result of harmonic resonance is the flywheel is either not correctly installed or designed. This can also be cause by the build of the gearbox. This is an unlikely outcome, but one you should consider nonetheless. To overcome it, you will need to take the flywheel back to the place of manufacture to see if they can work something out. "
Voilà, pour info c'est là : http://www.200sx.org/
R33 RB25DET reçu, les 12 travaux d'hercules ? ce type est une tafiole à coté de ce qui m'attend...
A car that will punish driving errors but rewards skillful execution.
A car that will be street oriented and comfortable in daily use.
That's why i love my Silvia
A +, seb.
SK_Flowne
06-11-2004, 10:38:50 -
Pour la Sunny c'est pas possible parce que vu la position du moteur la boîte sortirait par le passage de roue :]
Pas évident de passer ses vitesses par la vitre :]
Pour la boîte de S15 biens sur que oui ça se monte sur S13, les ponts sont compatibles.
Il suffit juste d'y mettre également un SR20VET
Hades
06-11-2004, 10:47:21 -
un sr20vet ?
tiens je croyais qu'il avais le meme moteur que la S14a, juste la carto et les injecteurs qui changent.
à ma connaissant le sr20vet, devais etre monter sur une hypotétique S16. ![Confused Confused](https://www.japancar.fr/forum/images/smilies/confused.gif) :
A +, seb.
Greg_P
06-11-2004, 11:37:34 -
Pour la Niemefois, non, les moteur de la S15 est le SR20det avec des petit ajustement qui font grimper la puissance a 260cv en version specR. Au passage, injecteur de 480cc, turbo T28bb "renforcé" (ya une histoire de ceramique), carto specifique et intercooler 33% plus gros.
Hades
06-11-2004, 11:48:23 -
Greg_P a écrit :Pour la Niemefois, non, les moteur de la S15 est le SR20det avec des petit ajustement qui font grimper la puissance a 260cv en version specR. Au passage, injecteur de 480cc, turbo T28bb "renforcé" (ya une histoire de ceramique), carto specifique et intercooler 33% plus gros.
merki ![LOL LOL](https://www.japancar.fr/forum/images/smilies/icon_lol.gif) !
je me disais bien aussi, le sr20vet d'ailleurs il existe ? sur quel char il est monté ?
A +, seb.
Tsuchiya
Sujets : 86
06-11-2004, 12:52:21 -
fabs13 a écrit :oui je viens de me souvenir que la s15 c'est un sr20vet...cqfd
a bon depuis quand c'est nouveau car le sr20vet fait 280cv comment ca se fait su'il en ai perdu 30 sur la s15, et il existe depuis 1998????!!! ![Shock Shock](https://www.japancar.fr/forum/images/smilies/icon_eek.gif) :], et c'est bizarre je croyais qu'il n'équipait que les Xtrail et peut etre la future s16!
je suis sournois
Micra K11 1.0
Diamantis
06-11-2004, 13:04:14 -
C'est un SR20DET et pas vet qui est moté uniquement sur les xtrail
sinon pour en revenir a la boite, c'est casiment inmontable car il y a rien qui correspond
MOI
Visiteur
06-11-2004, 14:32:27 -
Le CA est un moteur ecologique
les coussinets sont bio-degradable c'est tout simplement ça
Greg_P
06-11-2004, 14:41:50 -
Vi, si tu sais pas ce que c'est qu'un vilo ou un piston, suffit de pousser un peu tes rapport, ils finiront par apparaitre d'eux meme sous le capot :f
Et sur les 200sx, c'est pour quand? ti tidi tididi, ti tidi tididu...
