sansoub
28-06-2012, 11:34:18 - RE: [audi] mon break de chasse 2jz gte
mail de acl recu ce matin:
Hi Adrien,
Here is some information on the appearance of the ACL RACE Series bearings:
ACL RACE Series Technical Bulletin
- RACE Series performance bearings- Appearance
Questions about the appearance of the RACE Series bearings are quite common, as this series of trimetal copper lead bearings have a very different appearance to regular aftermarket ACL Duraglide trimetal bearings, which have a light silver /grey appearance.
The RACE Series performance bearings as manufactured have an appearance that is a dark tarnished colouration, which can vary from dark black/brown/blue colours. This colour comes from the electroplating which is the last manufacturing process. The electroplated overlay has copper as one part of its composition, which tarnishes to the dark colours described above. This tarnish colouration has negligible thickness, so once installed in the engine, the crankshaft journal contacting the bearing, will polish the bearing surface, removing the surface colour and leaving the bearings with a polished silver appearance.
Performance bearings do not start out with the silver grey appearance of regular aftermarket bearings, as there is no final silvery tin flash applied to these bearings. Not applying a silvery tin flash to these high performance bearings is a specific design feature. A silvery tin flash for appearance and long term corrosion protection, as applied to the regular aftermarket bearings, can under high loading and heat, move, with the plate migrating and causing high spots on the back of the shells, and distorting the bearing. For this reason the ACL RACE Series performance bearings do not have a cosmetic silvery tin flash applied, so there is no risk of any overlay plate movement on the backs of the shells, giving better bearing to housing contact and better bearing performance and function.
You are correct that the bearing surface of these bearings is quite soft, and can be marked with your fingernail as you have noted. Any minor contact between the crankshaft journals and the bearings as will occur at engine assembly, will polish the lead based overlay surface (removing the tarnished grey/brown/green colouration) and will then show as a shiny/mirror polished surface.
The wear when this occurs is negligible.
It sounds like the appearance of your bearings is quite normal
Kind Regards
Bruce Williams
sansoub
17-07-2012, 10:07:08 - RE: [audi] mon break de chasse 2jz gte
bonjour a tous, donc quelque news
je suis a 3000km de rodage et nous avons deja fini la carto, plus vite que prevu
en effet, avec les aac 272 que j ai monter, nous faisons rentrer plus d air dans le bloc, du coup je sature mes injecteur 1000cc beaucoup plus vite qu avant
avant la limite etait a 2bar, aujourd hui j en suis a 1.6bar
du coup cet hiver je passerais en 2000cc
pour ceux que ca interesse j aurais a vendre une paire de poulie hks reglable, et mes 6 injo en 1000cc avec le rail eventuellement
sinon le rodage se passe au poil, je le continue encore, je fais une accel le matin, une accel lesoir pour pauffiner les afr
j ai fait aussi l ecatombe des mano egt no name
mon premier a lacher au bout de 2ans
le deuxieme a fait 15 jours
donc j ai commander un auberin
y a juste un point qui m inquiet actuellement, c est le vvti
ma poulie n est pas piloté, le soleno n est pas brancher pour la bonne et simple raison que j arrive pas a faire marcher les sortie sur l ecu, elle veule rien savoir, on les a passer a l oscillo, j ai tester la sorti du boost programmé pour le vvti ca marche, mais j ai plus de boost, donc j ai du faire un choix
avant de faire n importe quoi on a etudier le comportement de la poulie en cruise et en accel
en cruise j ai 7.5° d avance, quand j accelere ca tend vers le 0
sauf que dans le log je dois avoir des bug, puisque ponctuellement de temps a autre j ai des pic a 66° d un coup comme ca
la lecture de l angle de l arbre na aucun impact sur la carto, juste que les soupape peuve toucher les piston si y a un reel bug
je pense que cette valeur a 66° est erroné, mais je comprend pas pourquoi
sinon j ai comparer mes chrono, pour voir ou j en suis
avant je fesais 100/200 en 4.9 seconde avec 2 bar
aujourd hui, je suis a 1.6bar, avec un 100/200 a 6.5seconde, et un 120/220 a 6.1seconde, puisque la puissance est décaler
donc pour l instant bof bof
et j ai du chanbger mes bougie hier, les ik24, devait etre vieille, j avais des coupure a haut regime
(Modification du message : 17-07-2012, 10:08:24 par sansoub.)
- France Messages : 29 297
17-07-2012, 10:21:47 - RE: [audi] mon break de chasse 2jz gte
les coupures sont peut-etre dus au gap des electrodes, ou a des bobines vieillissantes.
tu fais ta carto en rodage toi, mwai, c'est un point de vue.........
09s14
Sujets : 38
17-07-2012, 13:32:22 - RE: [audi] mon break de chasse 2jz gte
Un 4ieme moteur ....????
Ken Henderson a dit:
Benjamin Franklin a dit:
sansoub
17-07-2012, 14:08:07 - RE: [audi] mon break de chasse 2jz gte
non, le demontage des coussinet a 2000km, nous a montrer qu il fallait booster un peu pour roder, (conseil de ACL), sinon les coussinet ne "touche" jamais ou du moins pas assez les palier de vilo, et donc ne se rode pas, puisque j avais encore les trace de la couche oxydé sur les coussinets
les vidanges etant faite dans les preconisation, aucune saleté ne traine dans l huile
donc j ai fait 2000km, sans boost,puis 1000km au minimum de pression soit 1.2bar,et la nous sommes monté progressivement a 1.6bar
je regarde regulierement les paliers d AAC, puisque ce sont les plus facile d acces
concernant les bougie, le gap etait bon et les bobines neuves, j ai monté des njk 3330 avc le meme gap et le probleme est resolu
et oui je suis obliger de faire la carto sur le rodage puisque tout les afr etait a reprendre du au AAC
(Modification du message : 17-07-2012, 14:10:45 par sansoub.)
09s14
Sujets : 38
19-07-2012, 22:27:16 - RE: [audi] mon break de chasse 2jz gte
Et tu veux nous faire croire que tu poses 650ch a 1b avec un précision 67mm ???
MAis sérieux tu te rend compte de l'anerie que tu postes ???
sansoub
20-07-2012, 10:23:21 - RE: [audi] mon break de chasse 2jz gte
non, j ai 600 en vrai, et 510whp, j ai enlever la correction sae qui en rajoutais
c est pas un 67
et oui je crois les resultat pour la bonne raison que j ai croisé powerdyn avec des log de supra ayant deja fait un un banc
et surtout que j ai regarder le log ou mon embrayage a glisser hier, et le point de glisse est pile a 1000nm, les spec de l embrayage sont 1000nm max
a oui j oubliais qu on vous avait foutu dans le crane qu une turbo xs power c etait bon qu a sorti 500ch max lol
et les estimations du tuner sont 500whp donc 500/510, c est coherent, tu crois que le logiciel sur un banc il est magique? c est exactement la meme chose, il etudie la courbe de vitesse, ou de regime selon les banc, ensuite il calcule lui meme la perte en transmi, c est la seul difference,moi j ai rentré la perte transmi preconisé par toyota
de toute facon on va pas refaire ce debat sterile, en france sur supra, on a que des tuner de merde qui se la raconte, et surtout qui comprenne rien au carto...
quand je vois, un gars qui touche a ma caisse, qui commence a la regler qui toruve les avances bizare et que ca marche pas, et que moi qui n y connaissait rien a l epoque, je lui dit "ta pensez a synchrnoiser l ems et le moteur en allumage?" et que apres verife j avais 10° d ecart...y a de quoi avoir les boules
le jour ou j ai sorti 495cv, avec 1.35bar et ce meme turbo, mais sans aucune gestion, ni fuel system, rien , nada, ca en a foutu un coup a plus d un, mais peut etre que digiservice etait de meche? ou le fbi qui sait..
bref debat sterile
donc pas la peine d enchainer, je sort ce que je sort, et le jour ou je ferais un banc je pourrais enfin croiser reelement, en attendant le banc il est a 300km
(Modification du message : 20-07-2012, 10:45:09 par sansoub.)
papagog
15-08-2012, 15:10:24 - RE: [audi] mon break de chasse 2jz gte
Bon ben ça reroule content pour toi
j aurais une question, du coup, peut on ou pas rectifier les pastilles de réglages AAc ?
d origine, il y a un revetement mais j ai l impression qu il dégage assez vite, donc peut etre est ce juste un anticorrosion avant montage ?
ça m'éviterait d avoir a racheter des cales neuves
18-09-2012, 15:20:52 - RE: [audi] mon break de chasse 2jz gte
(18-09-2012, 15:18:53)NikoLifeStyle a écrit : Des nouvelles de ta Supra ?
je pensais a upper le sujet en plus
NikoLifeStyle
In Supra We Trust!
White Supra Targa
62 - Pas-de-Calais France Messages : 4 759
sansoub
19-09-2012, 15:31:46 - RE: [audi] mon break de chasse 2jz gte
salut, oui oui elle roule nikel, l huile est clean, les egt et afr sont bon
cet été je suis parti en vacance avec, elle a gouté les bouchons, elle a pas du tout aimé, l eau montait a 117°, c etait la merde, donc d ici peu, je vais rajouter 2 ventilo electrique devant mon radiateur, pour aider le visco
en rentrant des vacances, ma poulie de vilo etait plus bruyante que d habitude, je me suis apercu que la courroie avait rippé sur l interieur de la poulie, j ai demonter avec 2 doight, j ai reussi a separer la poulie amorti en 2... vive les poulies stock, donc j ai remis ma poulie allégé
pour le moment j excede pas 1.1bar, ca menage le moteur, et j attend surtout de recuperer des fond pour acheter un 3eme embrayage, j en fais la collection...
la on optimise la carto pour le confort, sur une charge au moment du changement de rapport,des que j enquille le suivant j ai un pic tres pauvre, parfois une coupure(trop pauvre), on essaye de voir d ou ca vient
j aimerais bien faire des videos, mais tout seul c est tendu
et mon frere a acheté un ninja zx10r, mais il est pas chaud pour tirer, il maitrise pas la machine
et j ai remarqué que la voiture donnait bien plus de sensation la nuit que la journée c est assez dingue
(Modification du message : 19-09-2012, 15:33:40 par sansoub.)
19-09-2012, 15:52:28 - RE: [audi] mon break de chasse 2jz gte
normal, il fait plus frais la nuit, tu verras cet hiver
19-09-2012, 19:27:25 - RE: [audi] mon break de chasse 2jz gte
si normalement c'est corrigé, soit avec le MAF (qui comprends une sonde de temperature) soit en MAP (qui comprends aussi une sonde de temperature)
normalement, tu prends légèrement plus de pression aussi, a voir si tu peux logger ça pour comparer.
19-09-2012, 21:15:48 - RE: [audi] mon break de chasse 2jz gte
Tres subjectif les sensations
sansoub
20-09-2012, 19:34:29 - RE: [audi] mon break de chasse 2jz gte
bon la j ai besoin de plusieurs cerveaux, on a un phenomene bizare a corriger, on a esssayer plusieurs variables rien a faire
lorsque j accelere a fond, lors du changement de vitesse, j ai un trou pauvre juste apres etre a 100% du tps
j ai checker les log, les fuel trim sont inactif, juste le boost trim, les ignition trim sont a 0
on comprend pas d ou ca vient
donc si je reflechi en mode logique, j ai du duty au injo, j ai de l allumage, mais je suis pauvre
j en deduis que ca vient en amont des injecteurs?
regulateur d essence aeromotive pas assez reactif? pompe a essence aeromotive idem?
je vais vous mettre un screen shot
(Modification du message : 20-09-2012, 19:41:48 par sansoub.)
