[RH9] R33 GTR / PT6870 CEA Turbo build dyno : 898,8ch
John Quaker Hors ligne
03-12-2015, 16:23:38   -   [RH9] R33 GTR / PT6870 CEA Turbo build dyno : 898,8ch
Vivant en Angletterre depuis plus d'un an et ayant toujours mes joujou en France, j'ai decide de reimporter ma RH9.
La voiture possedait deja un bon gros setup a + 800ch. mais en discutant avec l Mark de MGT racing, quelque improvement sont a venir.
Ancien setup :
Vehicle info:
1996 Nissan Skyline R33 GTR
75,000km, (6,000km on built engine)
Colour change from white to purple (no accident history)
Engine
BNR34 GTR base engine
HKS 87mm forged pistons
Tomei H Beam forged conrods
Super high balanced crank (10,000rpm)
HKS High lift cams 272IN/280Ex 10.5 Lift
OS adjustable cam pulleys
Topsecret intake manifold
90mm infinity single throttle body
Trust T88-34D (22cm)
Trust external waste gate
External vented screamer pipe
Tomei oil pump
N1 water pump
Nismo thermostat
Trust sump extension
Custom internal sump mods
Aftermarket valve springs
Ported and polished head
Valve guides cut
Naprec oversized valves
Naprec modified valve head
HKS timing belt
Muffler has the apexi ECV controller
HKS mushroom filter
Custom intake pipe
Oil catch tank
HKS hard piping
Trust muffler system
R34 GTR cas sensor
Fuelling
Sard 1000cc injectors
Trust fuel delivery
Sard FPR
Collector tank
Tomei tank fuel pump
2 x 044 Bosch external fuel pumps
2 fuel filters
Cooling
Aluminium radiator
HKS drag intercooler
Oil cooler kit
Ecu and controllers
Apexi power FC d-Jetro with twin map sensors
Apexi power fc hand contoller
HKS evc 5 boost controller
Techtom meter
Transmission/Suspension
OS Giken 6 speed sequential (Over £9,000 for gearbox alone!)
Breather bottles for OS sequential
ATS carbon triple plate clutch (very easy to use)
Rear Cusco 2 way LSD
HKS drag suspension
Rear arms upgraded
Rear upper arm cusco
Rear front arms and bush are nismo
Rear solid mount bush
Hicas cancel bar
Front pillow tension rods
Interior
Recaro driver and passenger reclining bucket seats
Defi fuel pressure gauge
Defi oil pressure gauge
Defi water temp gauge
Defi oil temp gauge
Defi exhaust temp gauge
Defi boost presure gauge
Defi rev meter with shift light
Defi link controller
Techtom meter
Nismo 320km dials
OS sequential shift gauge built into clock (awesome idea!)
Exterior
18” work emotion alloy wheels
JUN front bumper
JUN side skirts
Nouvelles pieces :
-Link G4+ Plug-in
-Innovate LC2 wideband
-Precision PT6870 CEA Gen 2 divided turbine
-T316 Twin gate T4 divided turbo manifold
-Turbosmart 40mm Compgate x2
-Custom downpipe
-Custom oil delivery & return lines
-Custom boost oulet pipe
-Exhaust wrap
-Iridium spark plugs
-Timing belt
-Tensioner & idler pulley's
-Suppression de la clim
-Suppression de la valve exhaust apexi
-Suppression du cata
-Getrag 6 speeds close ratio gearbox PPG dog gears
-ATi pulley damper
Bon quelques photos aller Smile
[Image: Rivertec_GTR005.jpg]
upload pictures
[Image: Rivertec_GTR011.jpg]
screen shot windows 7
[Image: Rivertec_GTR026.jpg]
free upload image
[Image: Rivertec_GTR024.jpg]
free upload pictures
(Modification du message : 17-12-2015, 18:10:43 par John Quaker.)
Keedy Hors ligne
E36 #TPPT
25 - Doubs France
03-12-2015, 16:25:51   -   RE: [RH9] R33 new single turbo build
Et tu crois que tu va t'en sortir sans poster de photo? LOL
« C’est un Renault Espace, sans doute le meilleur des monospaces. Pas de quoi se vanter quand même. Ce serait comme dire: Super, j’ai la syphilis, la meilleure des MST !»
Jeremy Clarkson
03-12-2015, 16:34:13   -   RE: [RH9] R33 new single turbo build
[Image: IMG_5896.jpg]
image upload no size limit
[Image: IMG_5916.jpg]
upload a gif
ancient setup T88-34D
[Image: IMG_5945.jpg]
image ru
hop a degager !
[Image: IMG_5941.jpg]
free image hosting
(Modification du message : 03-12-2015, 16:36:31 par John Quaker.)
wards Hors ligne
Civic Type R FN2
17 - Charente-Maritime France
03-12-2015, 16:34:16   -   RE: [RH9] R33 new single turbo build
Grave il nous faut des photos de ta 33!!!
En tout cas beau setup!!!
Mes ex's: Red EG4 - Dark Grey EG4 x2 - Blue EG4 - Grey ED9 - White EJ2 - Smart Fortwo - Alfa Guiletta - Clear Grey EG4 - Blue EG6 - Clear Grey FN2 - Fiesta ST Pack Perf 2018 Grey fox - Honda Civic FK7 Black
Mon actuelle : FN2 Daily'R
DAV4WS Hors ligne
Mineur de corde
03-12-2015, 16:51:33   -   RE: [RH9] R33 new single turbo build
jolie en purple !
ya des boite qui font des bas moteur et culasse pour les 100cv et + pour les RB , tu vise toujours les 1000++ je suppose ?
en Angleterre c'est vrai qu'il arrive a faire homologuer des truc de fou (je ne sais comment d'ailleur si tu peux nous l'expliquer sur un autre topic Wink )
si tu peux la ramener homologuer et la passer en papier français se serait cool!
bravo en tout cas une jap Langue
Keedy Hors ligne
E36 #TPPT
25 - Doubs France
03-12-2015, 16:57:35   -   RE: [RH9] R33 new single turbo build
Jolie, même si c'est de loin la gtr que je préfère, mais la couleur est super belle Big Grin love
C'est vrai que ça doit avoiné un peu quand même Big Grin
Jeremy Clarkson
03-12-2015, 17:01:10   -   RE: [RH9] R33 new single turbo build
(03-12-2015, 16:51:33)DAV4WS a écrit : jolie en purple !
tu dois passer une seris de test, comme en France, a par que cela vise plus des point technique et pas seulement lier au constructeur. Tu peux tres bien construire ta proper voiture, si elle passé les tests, elle est homologuee
DAV4WS Hors ligne
Mineur de corde
03-12-2015, 17:02:55   -   RE: [RH9] R33 new single turbo build
tiens un autre John ça va te plaire :
http://www.speedhunters.com/2011/10/rand..._all_four/
je rêverai de faire ma propre auto mais en France ça couterai trop chère a la limite la fabriquer en France et la faire homologuer en angletaire mais en tant que français c'est impossible me faudrait passer par un Anglais de confiance ....
ça m'embeterai de la fabriquer que pour aller rouler sur circuit avec et l'emmener avec un plateau ect ..
pour moi ce ne serait plus un plaisir mais un contrainte !
(Modification du message : 03-12-2015, 17:05:22 par DAV4WS.)
03-12-2015, 17:07:01   -   RE: [RH9] R33 new single turbo build
Voici les nouvelles pieces Smile
[Image: IMG_5902.jpg]
upload a gif
[Image: IMG_5923.jpg]
forum image hosting
Downpipe sur mesure
[Image: IMG_5909.jpg]
screen capture windows 7
Distri pompe a eau
[Image: IMG_5900.jpg]
imag
[Image: IMG_5957.jpg]
free picture hosting
[Image: IMG_5958.jpg]
free photo hosting
DAV4WS Hors ligne
Mineur de corde
03-12-2015, 17:12:36   -   RE: [RH9] R33 new single turbo build
j'adore ces nouvelles bride "turbo " depuis que j'ai testé !
pour ta down pipe sais tu que 2 coude a 45° donne plus de perte de charge qu'un seul coude a 90°?
apres souvent on a pas le choix ,
du coup tu vise combien tu ne m'as pas dit 1200?
03-12-2015, 17:17:32   -   RE: [RH9] R33 new single turbo build
Je vise pas de chiffre en particulier, je fais confiance a Mark pour me sortir un chiffre correct avec une belle courbe qui spool tres tot Smile
bashibuzuk' Hors ligne
03-12-2015, 17:21:30   -   RE: [RH9] R33 new single turbo build
Ce monstre ! LOL
Par contre j'ai pas compris pour ta boite, t'es en OS giken ? Et tu passe en dogbox getrag ? Ou tu change les rapports de ton os giken pour approcher ceux de la getrag ? Scratch
Et du coup toutes ces modifs risquent de se faire sentir sur le zero-yon Big Grin (elle était à combien au fait dans son ancienne config ? J'ai pas le souvenir du chrono)
"Il ne faut pas grand chose pour être un bon pilote : un pied lourd, et une tête légère." Ari Vatanen
"La vie c'est pas un essai, c'est un tour de piste et un seul !"
(Modification du message : 03-12-2015, 17:22:07 par bashibuzuk'.)
03-12-2015, 17:29:05   -   RE: [RH9] R33 new single turbo build
elle a une getrag de r34 gtr avec interne renforcer, la os88 est en reparation.
nouvelle gestion et wideband
[Image: IMG_5899.jpg]
pic host
Mark le boss de MGT avec le turbo Big Grin
[Image: IMG_5953.jpg]
uploading pictures
modification de l'echappement
[Image: IMG_5912.jpg]
free image uploading
[Image: IMG_5927.jpg]
pic host
[Image: IMG_5961.jpg]
picture uploading
[Image: IMG_5971.jpg]
image hosting 12mb
[Image: IMG_5972.jpg]
[Image: IMG_5973.jpg]
gifs upload
[Image: IMG_5920.jpg]
imagehosting
(Modification du message : 03-12-2015, 17:52:48 par John Quaker.)
04-12-2015, 10:20:48   -   RE: [RH9] R33 new single turbo build
Mise en place du turbo et collecteur et waste gates
[Image: IMG_5925.jpg]
free picture upload
[Image: IMG_5966.jpg]
image free hosting
[Image: IMG_5965.jpg]
free photo hosting
[Image: IMG_5964.jpg]
free photo upload
vroomdams Hors ligne
Man Made By Ikéa
BB9 + TA60
94 - Val-de-Marne France
Sujets : 50
04-12-2015, 10:59:34   -   RE: [RH9] R33 new single turbo build
Wo.... Shock
C'est quoi ce truc de dingue la ? LOL
Bon, bah comme les autres on va suivre Big Grin
TA60 & BB9
04-12-2015, 11:55:05   -   RE: [RH9] R33 GTR / PT6870 CEA Turbo build (800++)
Mise a l'air des sortie de waste gate Smile
[Image: IMG_5969.jpg]
image upload free
[Image: IMG_5974.jpg]
photo uploading
Montage de l'exhaust et descente de WG Smile
[Image: IMG_5975.jpg]
picture hosting
[Image: 12319318_1369544799738686_167144076_n.jpg]
upload images
[Image: 12348781_1369545913071908_1571586282_n.jpg]
image search
[Image: 12336136_1369544189738747_1182595790_n.jpg]
photo hosting sites
[Image: 12348549_1369545566405276_131540330_n.jpg]
picture uploading
[Image: 12336347_1369544969738669_1737069044_n.jpg]
imgurl
Ancienne ligne modifiee 4 pouces tout le long maintenant
[Image: 12312096_1369558709737295_1096057065_n.jpg]
click image upload
[Image: 12325087_1369558689737297_825430869_n.jpg]
image hosting above 5 mb
(Modification du message : 04-12-2015, 13:23:29 par John Quaker.)
nonovtec Hors ligne
Nono, le petit Modo
協定ホンダ CL9
70 - Haute-Saône France
04-12-2015, 14:19:33   -   RE: [RH9] R33 GTR / PT6870 CEA Turbo build (800++)
La vache le projet de ouf!!
Je suis avec attention le déroulement. .. Wink
Yaya 16v Hors ligne
Z32TT-EJ1 chandelles
37 - Indre-et-Loire France
Réputation : 15
04-12-2015, 15:07:43   -   RE: [RH9] R33 GTR / PT6870 CEA Turbo build (800++)
Projet de malade, je vais suivre Shock
Petite question, sa craint pas que les screamer pipe crache devant la downpipe avec la bande thermique ?
04-12-2015, 15:28:50   -   RE: [RH9] R33 GTR / PT6870 CEA Turbo build (800++)
C'est un effet d'optique Wink ca passé a coter et en dessous Smile
screenshot on pc
(Modification du message : 04-12-2015, 15:29:13 par John Quaker.)
RobinS Hors ligne
04-12-2015, 15:41:41   -   RE: [RH9] R33 GTR / PT6870 CEA Turbo build (800++)
Heuuuuu Et bien j'en reste muet. C'est magique pour moi ! Belle bête !
Et bah moi Je suis en Peugeot... Ca c'est la classe...
Ouinn S'il vous plaît, aidez moi... Ouinn
Sxyllaz Hors ligne
04-12-2015, 16:00:47   -   RE: [RH9] R33 GTR / PT6870 CEA Turbo build (800++)
Pour suivre !
Saïzo Hors ligne
Ae86 Ae92
04-12-2015, 22:08:48   -   RE: [RH9] R33 GTR / PT6870 CEA Turbo build (800++)
Outch !! Super prepa pour caisse de legende !!
Madnu Hors ligne
Nissan Bluebird
92 - Hauts-de-Seine France
04-12-2015, 22:19:36   -   RE: [RH9] R33 GTR / PT6870 CEA Turbo build (800++)
Post pr Suivre.   smileeek
Nissan Bluebird 1.8 Turbo U11T - Moteur CA18ET - Since 1985
http://france-bluebird.forumactif.org/t1...11t-caet18
04-12-2015, 22:28:27   -   RE: [RH9] R33 GTR / PT6870 CEA Turbo build (800++)
[Vidéo: http://youtu.be/iHa3BQ3H5hc]
La voiture vient de demarrer Smile
(Modification du message : 04-12-2015, 22:29:18 par John Quaker.)
jordanJDM Hors ligne
MX5 NBFL
30 - Gard France
05-12-2015, 00:14:42   -   RE: [RH9] R33 GTR / PT6870 CEA Turbo build (800++)
Wow le projet de dingue :o
Je vais suivre sa avec attention Big Grin
J'aime ma Jap ! love
PAPA est en bas il fait une prepa ... MAMAN est en haut, qui fait la carto ... Sac
Onizukkaa Hors ligne
mx5 na
69 - Rhône France
Sujets : 55
05-12-2015, 10:21:45   -   RE: [RH9] R33 GTR / PT6870 CEA Turbo build (800++)
Hoooo mais tu ne va plus avoir de place sous le capot!! déjà que c'est pas grand hahaha jolie projet!!
Nouvelle petite mx-5 =>ici
De l'intelligence artificielle chez toi ? -> ici
Raijuman Hors ligne
350Z Roadster
83 - Var France
05-12-2015, 20:47:58   -   RE: [RH9] R33 GTR / PT6870 CEA Turbo build (800++)
Bon bah je me joins au public, je veux entendre hurler le bébé. Big Grin
DAV4WS Hors ligne
Mineur de corde
07-12-2015, 11:46:51   -   RE: [RH9] R33 GTR / PT6870 CEA Turbo build (800++)
au top , ra je viens de voir que vous avez déjà de la neige la chance Langue !!!
07-12-2015, 11:48:58   -   RE: [RH9] R33 GTR / PT6870 CEA Turbo build (800++)
Ah rien du tout chez moi, il fait 10deg ca risqué pas de neiger encore LOL
DAV4WS Hors ligne
Mineur de corde
07-12-2015, 11:49:39   -   RE: [RH9] R33 GTR / PT6870 CEA Turbo build (800++)
(07-12-2015, 11:48:58)John Quaker a écrit : Ah rien du tout chez moi, il fait 10deg ca risqué pas de neiger encore LOL
ah dsl j'ai cru avec la vidéo de la sky sur neige ^^
mais elle été blanche j'aurais du tilter
(Modification du message : 07-12-2015, 11:50:02 par DAV4WS.)
  [Lexus IS200] Kompressor Club Sport SK Build Thread SuperKaribou 574 68 097 28-12-2024, 19:13:53
Dernier message: SuperKaribou
  [nissan R33 Gtr]The lapin cretin project. Radia huile HKS p24 Jocky 732 101 790 02-11-2020, 12:58:50
Dernier message: tomatoto
  [GT86] Build piste sans compromis - Swap boite CD009 page 4 Vgarcin 137 23 158 24-05-2020, 06:46:01
Dernier message: Onizukkaa
  [BCNR33] R33 GTR serie 3 97' cricricrx 141 15 310 11-02-2020, 19:41:19
Dernier message: cricricrx
  [R32 Skyline GTR] Build à très (très) long terme Jniwx 86 15 385 18-10-2019, 15:36:35
  [200sx s13] =====> R33 GTR jojosss 118 22 616 01-07-2018, 22:05:02
Dernier message: nico_ledingo
  [R33 GTR] ma futur spec1 jessvti 18 3 180 30-05-2017, 23:54:51
Dernier message: Yoshix
  [Nissan R33 GTR] serie 3 in France Jerem33GTR 34 6 817 12-04-2017, 18:49:13
Dernier message: BiSBAR
  [Nissan Skyline r33] gtr v-spec IDrazI IDrazI 1 2 690 20-02-2017, 12:16:24
Dernier message: fefe hyundai
  [R33] GTR V-Spec Ravenz 36 8 431 19-11-2014, 20:21:22
Dernier message: vin's-gtr
