NISSAN 350Z DRAG 1000hp
http://www.leboncoin.fr/voitures/314973040.htm?ca=12_s
NISSAN 350Z - Z33 TWIN TURBO APS-COSWORTH
Bi-turbo GTX 3076R nouvelle génération.
APS extreme turbine kit fully ceramic coated.
APS extreme intercooling system.
APS extreme fuel system.
AAM FUEL RAILS.
4 x 255L/H fuel pumps.
6 x HKS 1000cc INJECTORS.
25 row oil cooler on MOCAL oil plate.
Koyorad Racing water radiator.
Cosworth oversized pistons (3.7L).
Cosworth rods / bearings / studs / gaskets.
Cosworth ported heads with +1mm valves / titanium retainers / dual valve springs.
Cosworth ZK2 high lift cams.
Cosworth dual chamber intake manifold.
Carbonetic triple plate clutch.
Carbonetic carbon differential.
Carbonetic front big brake kit (6P) 355mm on SPEC-R pads (billet caliper).
Carbonetic rear big brake kit (4P) 345mm on SPEC-R pads (billet caliper).
Whiteline swaybars / end link and silent blocs (arms / frame).
Cusco trailing arms / rod ends / control arms.
CustomCage roll cage.
Defi control unit II (x2) with 2x EGT 1x OIL TEMP 1x BOOST 1x OIL PRESURE.
AEM Dual lambda control with gauges.
Racelogic traction control unit.
UpRev OEM tune.
Haltech Platinum Pro Ecu.
RacePack digital dash display.
VOLK TE37 19x9 & 19x10.5 on 265mm R888 front and 305mm R888 TOYO RACING.
TEIN SUPER RACING dampers.
SEIBON dry carbon bonet.
SEIBON carbon trunk.
SEIBON carbon doors.
Recaro SPG seats (driver and passenger).
DEI isolation and thermal management.
NISMO V2 front bumper with canards and racing aluminium undertray.
AAM true dual 3" Ti exhaust system (2 x full 3" piping from the GTX3076R till the tail pipe).
