17-12-2004, 17:08:32
![[Image: 1.jpg]](http://www.shift-light.com/rx7/1.jpg)
![[Image: 2.jpg]](http://www.shift-light.com/rx7/2.jpg)
![[Image: 3.jpg]](http://www.shift-light.com/rx7/3.jpg)
![[Image: 4.jpg]](http://www.shift-light.com/rx7/4.jpg)
![[Image: 5.jpg]](http://www.shift-light.com/rx7/5.jpg)
![[Image: 6.jpg]](http://www.shift-light.com/rx7/6.jpg)
![[Image: 7.jpg]](http://www.shift-light.com/rx7/7.jpg)
![[Image: 8.jpg]](http://www.shift-light.com/rx7/8.jpg)
![[Image: 9.jpg]](http://www.shift-light.com/rx7/9.jpg)
![[Image: 10.jpg]](http://www.shift-light.com/rx7/10.jpg)
![[Image: 11.jpg]](http://www.shift-light.com/rx7/11.jpg)
Mazda RX-7 (1993)
Engine Specs
13B Rew with a Big extended streetport that flows for 220 hk without boost, theoretically at 1 Bar over Pressure it is estimated to make about 500 hk on the wheels.
The Engine has been totally renovated with race parts only. Hutley 3 mm race apex tipp seals and double springs to keep it intact. Gears and rotor bearings has been adjusted for a bigger bearing space, and a deep grove in the rotor bearing. Dynamic outbalanced excenter with balanced rotors and weight compensated. O-rings for the oil seal and new springs. The engine is reinforced on the detonation side with a 7075 T6 Aluminium block to prevent the rotor house form separating at high combustion and on high boost load. Exhaustport is ported for a hard pressure pulse too the turbine side for a quicker response.
Add on hardware
Greddy T88 34D Turbo
Greddy Stainless steel Exhaust manifold
Greddy 60 mm Racing Wastegate
Greddy 3Row FMIC
Greddy 100 mm exhaust
Greddy 100 mm Down pipe
Greddy Elbow
Greddy Type R Blow off valve
Greddy Pully kit
Greddy x6 52mm meters inkl EGT, boost, temp etc
Greddy Clutch line
Greddy Shift knob
Greddy Oil filler cap
Apexi AVC Type-R
HKS Twin Power Rotary Type
NGK R625 10.5 Racing Spark plugs
Magnicore 8,5mm and 10 mm ignition cables
AEM Programmable Engine Management System
AEM UEGO Sensor Kit
G.E.T Exhaust Temp Sensor kit
New racing fans
Flexlite Fuel cooling
Koyo Aluminium radiator
Expansion tank I aluminium
NOS 75 Hp dry nitrous on demand
NX Ntercooler kit, cooling of the intercooler by C02
2x OEM Pumps in tank
1x SX External race fuel pump
1x SX High Flow filter
1x SX fuel regulator high flow
New fuel lines
K2rd Fuel rail secondary
Extra mounted catch tank
Bosch 1600 cc Injectors on secondary
ACT Xtreme pressure plate ZX3-XTR6 spec 780 Nm
ACT Disc 6 plates
Sparco PRO 2000 x2
Willians safety belts 4 pungt
Autometer pod
Carbon fiber rear wing
Roll cage in the same Colour as the car.
Snap of for the steering wheel
Suade Steering wheel black
Tinted windows light
Mazda Speed GTC Front
Hood is customized by the owner
Mazda OEM 99 spec combo lights
New Paint OEM M6
New side markers in white
99 Spec. rear tail lamps
Rear wing Racingbeat Type 2
Tein HA Coilover kit
Cusco Stuntbrace
Fluids that are used
Motul 300V
Motul inergel 50 "Motorcool"
Motul Gearbox
Pennzoil Rear axel
Pennzoil power steering
Brakes
Hawk carbon pads
Brake houses in steel
Brake fluid Castrol SRF
Brake Callipers painted in red
Wheels
BBS Lemans 8,5 x 18 in front with 235/40 18 Pirelli Pzero Corsa
BBS Lemans 10 x 18 in the rear with 265/35 18 Pirelli Pzero Corsa
2x Original wheels with Bfgoorich DRAG radial
2x Original wheels with M/T ET Street 26*10,5 16
2x OZ 17" 3 peace split with race tires.
A VENDRE 35000
