03-12-2015, 16:23:38
Vivant en Angletterre depuis plus d'un an et ayant toujours mes joujou en France, j'ai decide de reimporter ma RH9.
La voiture possedait deja un bon gros setup a + 800ch. mais en discutant avec l Mark de MGT racing, quelque improvement sont a venir.
Ancien setup :
Vehicle info:
1996 Nissan Skyline R33 GTR
75,000km, (6,000km on built engine)
Colour change from white to purple (no accident history)
Engine
BNR34 GTR base engine
HKS 87mm forged pistons
Tomei H Beam forged conrods
Super high balanced crank (10,000rpm)
HKS High lift cams 272IN/280Ex 10.5 Lift
OS adjustable cam pulleys
Topsecret intake manifold
90mm infinity single throttle body
Trust T88-34D (22cm)
Trust external waste gate
External vented screamer pipe
Tomei oil pump
N1 water pump
Nismo thermostat
Trust sump extension
Custom internal sump mods
Aftermarket valve springs
Ported and polished head
Valve guides cut
Naprec oversized valves
Naprec modified valve head
HKS timing belt
Muffler has the apexi ECV controller
HKS mushroom filter
Custom intake pipe
Oil catch tank
HKS hard piping
Trust muffler system
R34 GTR cas sensor
Fuelling
Sard 1000cc injectors
Trust fuel delivery
Sard FPR
Collector tank
Tomei tank fuel pump
2 x 044 Bosch external fuel pumps
2 fuel filters
Cooling
Aluminium radiator
HKS drag intercooler
Oil cooler kit
Ecu and controllers
Apexi power FC d-Jetro with twin map sensors
Apexi power fc hand contoller
HKS evc 5 boost controller
Techtom meter
Transmission/Suspension
OS Giken 6 speed sequential (Over £9,000 for gearbox alone!)
Breather bottles for OS sequential
ATS carbon triple plate clutch (very easy to use)
Rear Cusco 2 way LSD
HKS drag suspension
Rear arms upgraded
Rear upper arm cusco
Rear front arms and bush are nismo
Rear solid mount bush
Hicas cancel bar
Front pillow tension rods
Interior
Recaro driver and passenger reclining bucket seats
Defi fuel pressure gauge
Defi oil pressure gauge
Defi water temp gauge
Defi oil temp gauge
Defi exhaust temp gauge
Defi boost presure gauge
Defi rev meter with shift light
Defi link controller
Techtom meter
Nismo 320km dials
OS sequential shift gauge built into clock (awesome idea!)
Exterior
18” work emotion alloy wheels
JUN front bumper
JUN side skirts
Nouvelles pieces :
-Link G4+ Plug-in
-Innovate LC2 wideband
-Precision PT6870 CEA Gen 2 divided turbine
-T316 Twin gate T4 divided turbo manifold
-Turbosmart 40mm Compgate x2
-Custom downpipe
-Custom oil delivery & return lines
-Custom boost oulet pipe
-Exhaust wrap
-Iridium spark plugs
-Timing belt
-Tensioner & idler pulley's
-Suppression de la clim
-Suppression de la valve exhaust apexi
-Suppression du cata
-Getrag 6 speeds close ratio gearbox PPG dog gears
-ATi pulley damper
Bon quelques photos aller
![[Image: Rivertec_GTR005.jpg]](http://s12.postimg.org/5ctdgjr9p/Rivertec_GTR005.jpg)
upload pictures
![[Image: Rivertec_GTR011.jpg]](http://s3.postimg.org/wyd5j4w3n/Rivertec_GTR011.jpg)
screen shot windows 7
![[Image: Rivertec_GTR026.jpg]](http://s29.postimg.org/c90uzzes7/Rivertec_GTR026.jpg)
free upload image
![[Image: Rivertec_GTR024.jpg]](http://s7.postimg.org/ohku1nse3/Rivertec_GTR024.jpg)
free upload pictures
Ancien setup :
Vehicle info:
Engine
Tomei oil pump
N1 water pump
Nismo thermostat
Valve guides cut
HKS timing belt
HKS mushroom filter
Custom intake pipe
Oil catch tank
HKS hard piping
R34 GTR cas sensor
Fuelling
Trust fuel delivery
Sard FPR
Collector tank
2 fuel filters
Cooling
Aluminium radiator
Oil cooler kit
Ecu and controllers
Techtom meter
HKS drag suspension
Rear arms upgraded
Hicas cancel bar
Interior
Defi oil temp gauge
Techtom meter
Nismo 320km dials
Exterior
JUN front bumper
JUN side skirts
Nouvelles pieces :
-Link G4+ Plug-in
-Custom downpipe
-Exhaust wrap
-Timing belt
-ATi pulley damper
upload pictures
free upload image
