Version complète : Blitz K26 Turbo + ext. Wastegate. GT Four, MR2, 3SGTE
Pour ceux qui seraient intéressé !!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...eName=WDVW
Blitz/KKK K26 (K2670 GGA) turbo for sale with BLITZ external wastegate. Also comes with CT20b/CT26 manifold adapter for fitment to 3SGTE engines.
The Blitz wastegate alone is worth a hefty sum.
Rated about 300-320bhp (confirmed by KKK).
So a good fast road upgrade for a ST185, ST165 and ST205 GT Fours, plus MR2 Turbos.
I bought this turbo second hand from japan but have never fitted it to my car as I changed my plans. There's no play in the shaft etc, everything is secure. New gaskets are needed. And some other modifications may be needed to fit this to your car.
From the position that the turbo is in and the positioning of the wastegate when everything is placed together i would suggest that this setup was removed from a MR2. But the turbo positioning can be adjusted to suit.
Cheaper than a hybrid, plus you get the expensive wastegate included.
Some trimming needed on the outlet to fit to chargecooler/A2A cooler
The impeller outlet measures 2 inches and the exducer measures 2 1/2 inches across.
NO RESERVE AUCTION
More pics available on request.
Ill try and answer any questions you may have.
KKK are the preffered and only endorsed turbo by Blitz. Reknowned for performance and durability. Also used by the BMW, Porsche and Ferrari race teams.
Items are heavy so will send via Parcelforce.
Will not split parts.
Will cancel suspicious looking bidders so email your intentions before bidding, if you have low feedback.
[Image: 04_1_b.JPG]
ET EN FRANCAIS CA DONNE KOI?
ben ça permet au proprios de 3s gte gen 2 d' atteindre voir de dépasser les 300cv...
sur un 3è gen ça sert à que dalle puisque le turbo d'origine permet d'atteindre 300 cv... c pour ça d'ailleurs que le proprio de ce turbo qui a une st205 le revends...
il y a une cale d'adaptatin du turbo KKK sur le collecteur d'origine et qui permet de monter la waste gate externe Blitz fournie avec...
par contre il faut penser qu'à ce kit il faut rajouter une downpipe pour raccorder la ligne... et les durites d'eau et d'huile... :roll:
