la liste complète des SB energy suspension pour Eg ;
Train Avant ;
- Front Control Arm Bushings Part Number: 16.3105 Manufacturer: Energy Suspension
- Front Shock Mount Bushings Part Number: 16.8102 Manufacturer: Energy Suspension
- Front Sway Bar End Links Part Number: 16.8104 Manufacturer: Energy Suspension
- Front Sway Bar Bushings - 22mm Part Number: 16.5108 Manufacturer: Energy Suspension
- Ball Joint Dust Boots Part Number: 16.13101 Manufacturer: Energy Suspension
- Tie Rod Dust Boots Part Number: 9.13103 Manufacturer: Energy Suspension
Direction assisté ;
- Steering Rack Bushings - Power Steering Only Part Number: 16.10102 Manufacturer: Energy Suspension
Train Arrière ;
- Rear Lower Control Arm Bushings Part Number: 16.3104 Manufacturer: Energy Suspension
- Rear Shock Mount Bushings Honda / Acura Part Number: 16.8103 Manufacturer: Energy Suspension
- Rear Trailing Arm Bushings 16.7106 Part Number: 16.7106 Manufacturer: Energy Suspension OU
plus cher Rear Trailing Arm Bushings - Includes Hardware Part Number: 8304 Manufacturer: PrOthane
- Rear Compensator Arm Bushings Part Number: 8309 Manufacturer: PrOthane
- Rear Sway Bar Bushings - 15mm Part Number: 16.5117 Manufacturer: Energy Suspension
Support moteur insert ;
- Motor Mount Inserts -Set 1 of 2 - Honda Civic 92-00 / del Sol 92-97 Part Number: 16.1105 Manufacturer: Energy Suspension
- Motor Mount Inserts - Set 2 of 2 Part Number: 85018502 Manufacturer: Prothane
Stabilisateur boite de vitesse ;
- Shifter Stabilizer Bushings Honda (D Series Engines) Part Number: 16.1102 Manufacturer: Energy Suspension
- Shifter Stabilizer Bushings Honda Acura B Series Engines Part Number: 16.1101 Manufacturer: Energy Suspension
Le prix total ;
- Avec les Rear Trailing Arm Bushings Part Number: 16.7106 Manufacturer: Energy Suspension
sa donne un total de 315$ soit 220E env... pour le chassis complet
- Avec les Rear Trailing Arm Bushings - Includes Hardware Part Number: 8304 Manufacturer: PrOthane sa
donne un total de 397$ soit 275E env... pour le chassis complet et biensur sans les FDP mais c'est pas excessif.
Ps ; si vous prenez le master kit il n'est pas complet manque des pièces, de plus si vous les prenez au
detail vous payer 10$ de plus soit 7E par rapport au pièce du master kit voila
http://www.energysuspensionparts.com/pro...Civic+1992
_____________________________________________________________________________________________
Pour faire vôtre chassis totalement complet vous devez completer avec ;
Train Avant ;
- Rotule triangle supérieur ou fourni avec des camber OEM type moog ou delphi ou SPORT type buddy club, skunk, SPC
géneralement réglabe mais plus couteux Ex ;
OEM ;
http://www.rockauto.com/catalog/x,carcod...type,10401
SPORT ;
http://www.hondaperformanceparts.co.uk/F...gra_94-01/
MIXTE OEM SPORT ;
http://www.superstreetonline.com/techart...to_37.html
- Rolule triangle inférieur de marque en OEM moog ou delphi et en SPORT buddy club ou J's racing qui donne une extention de 10mm environ Ex ;
OEM ;
http://www.energysuspensionparts.com/pro...OG%2DK9802
SPORT ;
http://www.evasivemotorsports.com/Mercha...-BJP1-H002
SPORT ;
http://www.nengun.com/js-racing/roll-center-adjuster
- Rotule de direction intérieur et extérieur en OEM moog, delphi ou musashi etc...
OEM ;
http://www.energysuspensionparts.com/pro...%2DES3332R
OEM ;
http://www.energysuspensionparts.com/pro...OG%2DEV299
Train Arrière ;
- Biellette de barre stabilisatrice en OEM chez oscaro 17E parceque energy suspension font pas les SB de biellette barre stab arrière
possible de trouver en hardrace par ex mais le prix fait freiner
OEM ;
http://www.oscaro.com/barre-stabilisatri...732-3229-p
- Camber arrière en OEM mapco etc... ou SPORT buddy club, skunk etc...
OEM ;
http://www.oscaro.com/biellette-de-barre...647-3230-p
SPORT ;
http://www.hondaperformanceparts.co.uk/R...88-00_All/
Avec ceci faut penser une bonne suspension et des barres anti rapprochement des jantes de qualité veut pas dire les plus cher et des bon
pneus et vous avez un chassis qui respire la santé
les pièces les plus cher sont pas forcement les meilleurs hein
pareil les pièces que
j'ai cité sont a titre d'exemple donc regarder avant d'acheter les critiques sur les produits que vous trouvé voila j'éspère que ca vous aidera
