08-02-2011, 19:14:56
voila a question est simple, les 2 font 170 poneys, entre les 2 mon coeur balance, et je ne sais trop vers lequel m'orienter, merci d'appuyer votre choix et d'argumenter, (potentiel, preparation....) un petit rappel:
JDM B16A (Second Generation)
Found in:
1991-1994 JDM Honda Civic Sir/SiRII (EG6)
1991-1993 JDM Honda Civic Ferio SiR (EG9)
1992-1995 JDM Honda CRX Delsol SiR (EG2)
1995-1998 JDM Honda Civic Sir/SiRII (EK4)
1995-1998 JDM Honda Civic Ferio Si (EK4)
Displacement: 1,595 cc (97.3 cu in) 1.6 liter
Compression: 10.4:1
Bore: 81.0 mm (3.2 in)
Stroke: 77.4 mm (3.0 in)
Rod Length: 134 mm (5.3 in)
Rod/stroke ratio: 1.745
Power: MT: 170 PS (125 kW; 168 hp) @ 7,800 rpm & 16.0 kg·m (157 N·m; 116 ft·lbf) @ 7,300 rpm
VTEC engagement: 5800 rpm
Redline: 8200 rpm (AT: 7700 rpm )
Transmission: S4C/Y21/S21 (4.4 final drive, optional LSD)
ECU code: P30 (EG2/EG6/EG9) P2S (EK9)
OBD1
pour info la differnce entre celui ci et le b16a2 serai seulement du aux pistons qui augmente les compressions
B18C4VTEC
Found in:
1996-2000 UK Civic 1.8i VTi 5-door Hatch (MB6)
1996-2000 UK Civic 1.8i VTi-S (Limited Edition) 5-door Hatch (MB6)
1996-2000 UK Civic Aerodeck 1.8i VTi 5-door Wagon (MC2)
1998-1999 EU Civic Aerodeck 1.8i VTi 5-door Wagon (MC2)
1998-1999 EU Civic 1.8i VTi 5-door Hatch (MB6)
Displacement: 1,797 cc (109.7 cu in)
VTEC engagement@4,300 rpm
IAB open@5,750 rpm
Compression: 10.0:1
Power: 169 hp (126 kW) @ 7600 rpm & 128 lb·ft (174 N·m) @ 6200 rpm
Limit: 8,100 rpm
Transmission: S9B w/Torsen LSD.
0/100 km/h : 7.9 seconds (8.5 Aerodeck)
Found in:
Compression: 10.4:1
OBD1
B18C4VTEC
Found in:
IAB open@5,750 rpm
Compression: 10.0:1
Limit: 8,100 rpm
