alor une petite rubrique qui ne feras que du bien as tous
Cette rubrique est la pour tous les revendeurs de pieces japonnais ou
boutiques pour nos caisse .
alors lachez vous
pour ceux a qui ca intéresse ultra tuning vend le kit gros intercooler BILTZ CA18DET pour 890euro neuf
ainsi que la pome walbro 255L/H 169euroTTC
un petit plus par ultratuning:
Pour convertir les livres HT en Euros TTC, il suffit de multiplier par 1,75
Stage 1 [2165]
Nissan 200SX S13
(SR20DET or CA18DET)
Stage 1 upgrade: (15 BHP) Exhaust system
HKS exhaust system. All systems are designed to fit 'cat-back' and where marked 'JASMA' will conform to strict Japanese noise levels.
For SR20DET:
HKS Silent Hi Power for £Call + 1 hour (JASMA)
or
Blitz NUR spec R from 91/1~93/10 for £465.00
Blitz NUR spec V from 91/1~93/10 for £495.00
For CA18DET:
HKS Legal Exhaust from 89/4~90/12 for £495.00 + 1 hour (JASMA)
or
Blitz NUR spec R from 88/5~91/01 for £471.00
Blitz NUR spec V from 88/5~91/01 for £495.00
Stage 2 [2166]
Stage 2 upgrade: (Up to 20 BHP)
For CA18DET:
HKS Super Power Flow induction kit for £155.00 + 1 hour
For SR20DET or CA18DET:
Blitz SUS Power Air Filter for £150.00
Stage 3 [2167]
Stage 3 upgrade: (Up to 50 BHP)
HKS Fuel Cut Defencer (overboost chip) £95.00 + 1 hour
HKS EVC V Electronic boost controller £445.00 + 5 hours
Stage 4 [2168]
Stage 4 upgrade: (Up to 60HP - Intercooler upgrade)
HKS Intercooler upgrade for £765.00
Blitz Intercooler (incl. hard pipes) for £705.00
Stage 5 [2169]
Stage 5 upgrade: (Up to 80 BHP)
(ECU upgrade) Please call to discuss which unit would be more appropriate for your particular upgrade path.
HKS F-Con SZ fuel & ignition timing 'piggyback' ECU for £545.00
+ Factory quality wiring loom for above £225.00 (required)
or
HKS F-Con V Pro fuel & ignition timing 'piggyback' ECU for £950.00
+ HKS A/F knock monitor £495.00 (recommended, uses original knock sensor)
Optional wide band Lambda sensor for above £350.00 (recommended)
+ Larger fuel injectors £620.00 (may be required)
For approximate fitting and mapping times please contact us
Stage 6 [2170]
Stage 6 upgrade: (95 BHP+)
Vein Pressure Converter (replacement air metering device) £885.00 + 4 hours
Stage 7 [2171]
Stage 7 upgrade: (120 BHP+)
For SR20DET:
Blitz Turbo Kit (incl. Manifold, KKK turbo & Remote Wastegate) for £2788.00
Stage 8 [2172]
Stage 8 upgrade: (Up to 140 BHP)
HKS Camshafts for £370.00 + 6 hours
HKS adjustable cam gears for £260.00 (only for SR20DET)
Stage 9 [2173]
Stage 9 upgrade:
For SR20DET:
TODA 2.2L Stroker kit for £4195.00
(incl piston kit 86 or 87mm, I beam con rod, SPL crankshaft)
or
HKS 2.2L Stroker Kit (Crank/Pistons/Rods) for £2995.00
For CA18DET:
TODA Forged Piston Kit Ø 84mm (1853cc) for £630.00
je voudaris pas t arreter en si bon chemin, mais 170 euros la walbro, c est du vol!!!!
va sur ebay et tape "walbro SR20DET"
je sai bien mai le problem n'est pas la avec les dollars et tou ca tu atten 2 mois avan d'avoir des nouvelles et je n'ai pas du tou confiance en paypal ou ce genre de truc alor qu'avec ultratuning j'ai toujour tou u sur les 2 jours voir 5 si c'est pas en stoks et une entiere confaince voila
Tu as déjà fais des commandes en import au moins ?
Personellement le seul shop qui ma décu c'est un shop francais ou j'ai payé le prix fort pour avoir du matos qui a pas tenus la route .
Pour moi les meilleurs shop pour l'achat de pièces performance sont :
www.motors.ebay.com , aucun problème et livraison toujours dans les temps .
www.frsport.com , tu trouve ta Walbro pour 100⬠livré , livraison nickel et dans les temps.
www.nengun.com , ils sont très long à livrer (1 mois en moyenne) mais ils ont pas mal de matos pour CA18DET
Voila
pareil la walbro sur ebay à 115 euros livré en 3 jours à peu prés
200sx200 a écrit :je sai bien mai le problem n'est pas la avec les dollars et tou ca tu atten 2 mois avan d'avoir des nouvelles et je n'ai pas du tou confiance en paypal ou ce genre de truc alor qu'avec ultratuning j'ai toujour tou u sur les 2 jours voir 5 si c'est pas en stoks et une entiere confaince voila
grave la tu parle sans savoir, j'ai commandé tout sur ebay.com
- ma walbroo 5 jour aprés je l'avais provenance japon = 100 livrée
- mes injecteurs 3 jours provenance japon = 142 livré
- mon échappement 1 semaine provenance japon = 70
- embrayage renforcé cusco 1 semaine provenance japon= 350
alors si c'est pas fiable
70 euros la ligne ???????????
ok ok jsui novice mai c'est ouvert a tou le monde
jai tou simplement mi ce que je connaissai voila
Vas matter le choix et les prix sur Ebay et tu comprendras
goro a écrit :70 euros la ligne ???????????
echappemment pas ligne
clair les emmerdes j'en ai eu que avec des shops francais.
+1
et moi donc !!!! merci toxic tuning a toulouse !!!!!
en meme temps du moment qu il y a le mot tunig haiiiii !!!!
bielle.chaude a écrit :en meme temps du moment qu il y a le mot tunig haiiiii !!!!
C'est clair !!!
, ces cons chez Blitz ils ont écrient ce mot sur le BC DSBC , espérons que ca vas pas apporter le mauvais oeil !!!!
