04-02-2005, 18:45:45
Voilà en regardant un peu en détail ceci:
http://www.sxoc.co.uk/vbb/showthread.php...ge=4&pp=20
extrait:
et ceci:
http://www.sxoc.co.uk/vbb/showthread.php...ge=2&pp=20
ben du coup j'ai encore craqué et j'ai pris un wahlbro :'(
extrait:
Citation :OK, the figures below arent hard fact, and will vary car to-car, but lets take the things in order of being "maxed out" ... dont think anyone could argue with the order even with differance of opinion on figures.
Generally (12psi) 240bhp is OK on std pump & plugs
At (13psi)250bhp fuel pump may cause lean running @ 7K in 5th on WOT
At 14psi (260bhp)fuel pump may cause lean running @ 6.5K in 5th on WOT
At 14psi your WMIC is in danger of overheating after 1 minute flat out .. (that may not seem a long time, but consider standing 1/4 to 100mph takes 14secs ...)
At 15psi (270BHP) your injectors are @ 90%
At 18psi (310BHP) your T28 is maxed.
RR with full fuelling and setup cheack are one of the few ways to get 95% peice of mind ... but this is not 100% safe if it happens to be a 30oC hot summers day when you do your top speed run......or your fuel filter starts to block / muck from your tank blocks your pickup sock (this happened with my old volvo, wouldnt go up hills, couldnt supply the fuel) NOTHING is 100% safe, not even a 100% standard car.
et ceci:
