10-01-2006, 23:03:18
Voila, c'est Mtec, qui m'a fait découvrir cette perle de la technologie Japonaise
C'est vraiment une "ultimate JDM Sleepa" Je vous laisse lire les spec
Les photos:
- ENGINE TYPE:MA09ERT(SUPER CHARGER & TURBO)
CYLINDER:INLINE-FOUR
HEAD TYPE:SOHC 2VALVE
BORE/STROKE:66.0$B&U(J/68.0mm
CAPACITY:930cc
MAX BOOST:0.7kg/cm2(NORMAL)
MAX POWER:138ps/6250rpm
MAX TORQUE:16.0kg-m/4800rpm
MAX SPEED:200km/h OVER
LENGTH:3735mm
WIDTH:1590mm
HEIGHT:1395mm
WEIGHT:770kg(F510kg R210kg)
WHEELBASE:2300mm
TREAD:F1350mm R1335mm
Citation :In 1988 Nissan launched a limited 10,000 unit run of their Homologated Nissan March Superturbo (EK10). Both this and the March Superturbo R (see below) featured the same highly advanced sequential compound charged (supercharged+turbocharged) engine in an all aluminium straight-4 930 cc 8v 4 cylinder MA09ERT unit that produced 110 PS JIS (81 kW/108 hp) at 6400 rpm. This car came with either 3 speed auto or 5 speed manual gear box with viscous LSD, as well as options such as air con, and electric mirrors. The March Superturbo is still to this day holds the crown for the fastest production Micra in Nissan's history, with factory performance figures of 7.7 0-60 and 15.5 1/4 mile.
Les photos:
