Tous Sur Les Honda
maxvtec Hors ligne
02-08-2005, 22:06:08   -   Tous Sur Les Honda
copié sur le forum quebec tuning, il se peu qu'il y es des infos incorect et les modeles de voitures sont pas tous les memes au quebec...
Getting Started
What engine is in my civic/honda?
http://www.superhonda.com/forum/showthread.php?t=99764
What are "bolt-ons"?
Boltons are the most common and easily installed engine modifications which are the intake, header and exhaust (also referred to as i/h/e). These bolt-ons essentially help the engine to breath better which should result in more power being transmitted to the wheels. On average people see around 10whp with typical bolt-ons (i/h/e), so don't be fooled by many manufacturers claims of 25+hp from a single bolt-on.
What is the best intake?
There is no real answer to this question. The test methods that each companies uses to generate their hp figures is questionable. Here is some good reading on the more commonly available intakes :
http://www.tprmag.com/issue/1/1_intakes.shtml
What is the best exhaust
Again, there is no real answer to this question. What exhaust works best depends on your setup and where you want your power to be made. In many cases the only difference between the exhausts is sound and looks. Most of the common import exhausts produce similar power gains.
http://www.tprmag.com/issue/3/3_exhausts.shtml
I do not think that the magnaflow exhaust was part of their tests, but it is a quality unit and rather inexpensive. It can be found at www.magnaflow.com and www.hottexhaust.com .
What exhaust is the quietest?
The Apexi World Sport and RS*R Ex-Mag are considered to be 2 of the quietest aftermarket cat-back exhausts available for our little cars.
What is the best header?
Again, no real cut-and-dry answer here. You have to determine which header best suits your needs/goals. Many consider the DC Sports 4-2-1 to be a quality unit. It is not the best, and not the worst, but it is a good street performer. You can find more in depth review of headers here :
http://www.hadamotorsport.com/tech/...semc/index.html
Engine Modifications
How do I tell what Engine I have?
The engine code (i.e. D16Y8, D15B2, etc.) are stamped right on the engine block. Simply pop the hood of your car and look where the head of the engine meets the block, just under the valve cover. Look over to the left side of the front of the block and you will see a flat spot with the engine code stamped there. If you had a D16Z6, then the "D" would indicate a D-Series engine, the "16" would indicate a 1.6L engine, and the "Z6" would indicate which engine in the D-Series family.
What are my engines specs?
Engine specs such as stroke, bore, etc are available at numerous resources on the web. You can simply type in your engine code (i.e. D16Y8) into any search such as www.google.com . Here is an excellent resource available here on SHO :
http://www.superhonda.com/forum/showthread.php?t=125367
What is a mini-me?
A mini-me or frankenstein motor is where you swap the head from one engine onto the block of another. This is typically done using a vtec head such as that from the d16z6 (92-95 ex/si) or d16y8 (96-00 ex). The addition of the vtec head (along with other components such as ecu/vtec solenoid, etc.) adds vtec to the motor which is typically around another 20hp. The size of the combustion chamber with the d16y8 head is smaller than that of any other d16 head so swapping it onto another block can also result in raised compression of the new motor which will also help power output. It is often recommended that when doing the mini-me, you also swap in the transmission from the d16z6 or d16y8 to get the most benefit from the new setup.
http://www.superhonda.com/forum/showthread.php?t=144200
What is headwork or pnp or port and polish?
As many will tell you, the secret to making big power in our little engines is in the head. The engine is essentially an air pump and the better quality air you can get flowing through the head and engine, the more power you will make. The process of porting is to remove material from the head that is obstructing airflow. This is typically done in the intake ports, exhaust ports, combustion chamber and valve seats. Keep in mind that more air does not mean more power, you have to achieve the right balance between amount of air and air velocity, so don't be fooled by flowbench numbers alone as higher cfm doesn't translate to more power. You can find more info available at some of the following resources :
http://www.superhonda.com/forum/showthread.php?t=127827
http://www.theoldone.com/articles/d16a%5Fhead/
http://www.sa-motorsports.com/diyport.htm
http://pub143.ezboard.com/fhondadse...picID=672.topic
http://nicotine.golden.net/D-Series/Porting/
Unberdata:
http://www.clubcivicquebec.com/ubb/ultim...1;t=000552
Where can I get my head ported?
This is not a recommendation, but simply a list of companies that offer head porting services :
www.exospeed.com (porting done in conjunction with RS machines)
www.hondaraceengines.com
www.alaniztechnologies.com
www.portflow.com
www.extrudehone.com
What is the best camshaft?
Again, there is no best camshaft. You have to choose the best one for your application. Also keep in mind that if you have plans to auto-x or road race that an upgraded camshaft may not be legal in the class that you plan to compete in. More info on camshafts is available here :
http://www.superhonda.com/forum/showthread.php?t=153746
Engine Management
What is obd1, obd2, obd2b, etc.?
OBD = On-Board Diagnostics.
92-95 Hondas are obd1
96-98 Hondas are obd2
98-00 Hondas are obd2b
Would be lovely if some would do a writeup or provide a link to a good resource. for this one.
What ecu do I have?
D16Y8 - P2P (comes in an obd2 and obd2b variety)
D16Z6 - P28
Should I Chip my ecu?
If you have an obd-2 (96-00) then you can not chip your ecu. However there are a few places that will reprogram an obd2 ecu ( www.ericksracing.com ). Unfortunately no one can reprogram an obd2b ecu. There are plenty of places that you can find chips/programs for your obd1 ecu (jet, skunk2, etc.) I wouldn't recommend any of them as they are generic chips that do not take into account the actual modifications that you have done to your vehicle. If you want to chip your obd1 ecu, then get a custom chip with a program that was created for your vehicle. Please read the engine modification section of the faq for info in chips that raise or remove your engines redline or rev-limiter.
How can I reprogram my stock ECU?
OBD2b ecus can not be reprogrammed. This is not a recommendation, but simply a list of resources for reprogramming your ecu, or doint a custom setup:
www.pgmfi.org (look for uberdata)
www.turboedit.org
www.ghettodyne.com
www.hyperducktuning.com
What is hondata?
Hondata is one of the many aftermarket engine management systems such as the AEM EMS, Apexi PowerFC, Accel DFI, etc. These are complete engine management systems that can replace your ecu. The hondata is the cheapest, but the others are programmable on the fly via a laptop whereas you have to burn a new chip for the hondata. The downside of hondata is that it requires that you are obd-1, whereas the other systems are available for obd2 vehicles. It is illegal to convert an obd2 vehicle to an obd1 vehicle and depending on your area, they may actually test factory equipped obd2 vehicles by connecting to the obd2 service port, so you will fail inspection if you have converted to obd1.
How is the AFC different from hondata?
The Apexi V-AFC/S-AFC are piggybacks onto the factory ecu. They are used to make fuel adjustments and are often used in mild turbo setups. However the AFC is not able to control the spark which is where it really falls short of hondata and other engine management systems. Also if you have an obd1 vehicle, then go ahead and do it right with hondata. It is not much more expensive than the AFC.
Ici les liens utiles.
Tous sur les civics.
http://www.civicland.com/diy/index.php
Explication sur la détonation.
http://www.efi101.com/forum/viewtopic.php?t=131
Les turbo.
http://www.beesandgoats.com/boostfaq/g2icturbo.html
How VTEC Works:
http://auto.howstuffworks.com/question229.htm
General Camshaft Info:
http://auto.howstuffworks.com/camshaft.htm
http://www.tprmag.com/issue/2/2_camshafts.shtml
D-Series Camshaft Info:
http://www.hadamotorsport.com/tech/...6camshafts.html
D-Series Camshaft Vendors:
www.crower.com
www.skunk2.com
www.zex.com
www.cranecams.com (billet cams)
D-Series Camshaft Regrind Services:
www.exospeed.com
www.deltacam.com
www.webcamshafts.com
www.jgenginedynamics.com
D-Series Valvetrain Sources
www.iskycams.com
www.crower.com
www.skunk2.com
www.zex.com
comment changer un cardan et plus:
http://www.prostreetonline.com/pso/pages...ticleid=46
http://www.geocities.com/chipman_13/z6-ecu-p28.html
Pour des chosew home made très intéressant.
http://www.homemadeturbo.com
B20-B18/Vtec
http://www.geocities.com/thelsvtec/ls_vtechowto.html
http://www.geocities.com/whiterabbit_59/frame.html
http://www.angelfire.com/dc/lsvtec/2019.html
http://www.b20vtec.com/frontpage.html
http://www.c-speedracing.com/howto.php
4th gen Civic
Dx => SI MPFI
http://www.geocities.com/c_rexboy/mpfi.html
OBD-0 => OBD-1
http://www.geocities.com/kurtsi_on/page7.html
Un autre site sur les obd
http://65.54.184.250/cgi-bin/linkrd?_lan...BD1%2ehtml
Plusieurs links
http://www.civic4g.com/linkslow.htm
B16a 1st gen
http://students.washington.edu/kristic/enginesw.htm
http://www.teirney.net/civic/EngineSwapPhotos.htm
Information général et technique
http://www32.brinkster.com/tjshondas/default.htm
Zc info
http://www.thezcresource.com/html/zcinfo.html
5th gen Civic
Transmission D serie spec
http://home.cinci.rr.com/mistab0ne/tranny.html
H22a swap
http://www.h22hybrid.20m.com/
http://h22acivic.com/H22aspecs.phtml
Lien pour installation d'un k20 dans une civic 7g.
http://tech.hybridgarage.com/tech/7gtech/7g-swap.htm
Pour une ek:
http://sportcompactcarweb.com/tech/0407scc_hybrid/
6th gen Civic
OBD-2 => OBD-1
http://www.t24ever.com/tech.htm
ITR cluster installation
http://patriot.net/~merritt/gauge.html
Home Made Poly-Urethane Motor mount
http://importnut.net/motormount.htm
Fuel pump rewire
"s`applique sur les civic de la même façon"
http://www.vfaq.com/mods/pump-relay.html
Auto Math Calculations
http://www.smokemup.com/auto_math/index.php
Les d15b
http://asia.vtec.net/article/d15b/
http://www.leecao.com/honda/vtec/index.html
Civic ferio
http://www.epwork.com/subfolder/civicsho...K4DML.html
Beaucoup de chose utiles ici.
http://www.hondaswap.com/forums/index.php?showforum=33
Merci a jfk et le forum kamikaze pour les liens suivant:
http://www.kamikazenipponracer.be/viewtopic.php?t=916
http://www.kamikazenipponracer.be/viewtopic.php?t=921
maxvtec Hors ligne
02-08-2005, 22:08:05   -
Poids des voitures honda/acura
1985 Honda CRX Si MT 1883
1985 Honda CRX DX MT 1819
1985 Honda CRX HF MT 1713
1986 Honda CRX Si MT 1953
1986 Honda CRX DX MT 1819
1986 Honda CRX HF MT 1713
1987 Honda CRX Si MT 1978
1987 Honda CRX DX MT 1865
1987 Honda CRX HF MT 1713
DA 1988 Acura Integra LS Coupe MT 2355
DA 1988 Acura Integra LS Sedan MT 2396
DA 1988 Acura Integra RS Coupe MT 2313
DA 1988 Acura Integra RS Sedan MT 2390
DA 1988 Acura Integra SE Coupe MT 2355
1988 Honda CRX Si MT 2017
1988 Honda CRX DX MT 1922
1988 Honda CRX HF MT 1819
1988 Honda Prelude 4WS MT 2685
1988 Honda Prelude S MT 2522
1988 Honda Prelude Si MT 2665
1988 Honda Accord DX CPE MT 2493
1988 Honda Accord LXi CPE MT 2551
1988 Honda Accord DX HB MT 2513
1988 Honda Accord LXi HB MT 2564
1988 Honda Civic DX SDN MT 2039
1988 Honda Civic LX SDN MT 2138
1988 Honda Accord LX Sedan MT 2482
1988 Honda Accord DX Sedan MT 2579
1988 Honda Accord LXi Sedan MT 2665
1988 Honda Civic DX HB MT 1993
1988 Honda Civic HB MT 1933
DA 1989 Acura Integra LS Coupe MT 2355
DA 1989 Acura Integra LS Sedan MT 2396
DA 1989 Acura Integra RS Coupe MT 2313
DA 1989 Acura Integra RS Sedan MT 2390
1989 Honda CRX Si MT 2138
1989 Honda CRX DX MT 2048
1989 Honda CRX HF MT 1834
1989 Honda Prelude 4WS MT 2741
1989 Honda Prelude S MT 2571
1989 Honda Prelude Si MT 2712
1989 Honda Accord DX CPE MT 2493
1989 Honda Accord LXi CPE MT 2646
1989 Honda Accord DX HB MT 2513
1989 Honda Accord LXi HB MT 2560
1989 Honda Accord SE CPE MT 2710
1989 Honda Accord SEi CPE MT 2718
1989 Honda Civic DX SDN MT 2147
1989 Honda Civic LX SDN MT 2211
1989 Honda Accord LX Sedan MT 2500
1989 Honda Accord DX Sedan MT 2595
1989 Honda Accord LXi Sedan MT 2685
1989 Honda Accord SEi Sedan MT 2718
1989 Honda Civic Si HB MT 2161
1989 Honda Civic HB MT 2013
1989 Honda Civic DX HB MT 2088
DA 1990 Acura Integra GS Coupe MT 2628
DA 1990 Acura Integra LS Coupe MT 2590
DA 1990 Acura Integra RS Coupe MT 2544
1990 Honda CRX Si MT 2174
1990 Honda CRX DX MT 2103
1990 Honda CRX HF MT 1967
1990 Honda Prelude 2.0S MT 2566
1990 Honda Prelude 2.0Si MT 2639
1990 Honda Prelude 4WS MT 2690
1990 Honda Prelude Si MT 2690
1990 Honda Accord DX CPE MT 2738
1990 Honda Accord EX CPE MT 2888
1990 Honda Accord LX CPE MT 2822
1990 Honda Civic DX SDN MT 2262
1990 Honda Civic LX SDN MT 2322
1990 Honda Civic EX SDN MT 2374
1990 Honda Accord DX Sedan MT 2733
1990 Honda Accord EX Sedan MT 2923
1990 Honda Accord LX Sedan MT 2857
1990 Honda Civic Si HB MT 2291
1990 Honda Civic HB MT 2127
1990 Honda Civic DX HB MT 2165
DA 1991 Acura Integra GS Coupe MT 2654
DA 1991 Acura Integra LS Coupe MT 2619
DA 1991 Acura Integra RS Coupe MT 2560
1991 Acura NSX MT 3010
1991 Honda CRX DX MT 2103
1991 Honda CRX HF MT 1967
1991 Honda CRX Si MT 2174
1991 Honda Prelude 2.0Si MT 2639
1991 Honda Prelude 4WS MT 2712
1991 Honda Prelude Si MT 2690
1991 Honda Accord DX CPE MT 2738
1991 Honda Accord EX CPE MT 2888
1991 Honda Accord LX CPE MT 2822
1991 Honda Civic DX SDN MT 2262
1991 Honda Civic LX SDN MT 2322
1991 Honda Civic EX SDN MT 2374
1991 Honda Accord DX Sedan MT 2773
1991 Honda Accord EX Sedan MT 2923
1991 Honda Accord LX Sedan MT 2857
1991 Honda Accord SE Sedan AT 3053
1991 Honda Civic DX HB MT 2165
1991 Honda Civic Si HB MT 2291
EF 1991 Honda Civic HB MT 2127
DA 1992 Acura Integra GS Coupe MT 2643
DA 1992 Acura Integra GS-R Coupe MT 2643
DA 1992 Acura Integra LS Coupe MT 2623
DA 1992 Acura Integra RS Coupe MT 2557
DA 1992 Acura Integra GS-Sedan MT 2703
DA 1992 Acura Integra LS-Sedan MT 2643
DA 1992 Acura Integra RS Sedan MT 2608
1992 Acura NSX MT 3010
1992 Honda Civic DX HB MT 2178
1992 Acura NSX AT 3098
1992 Honda Civic CX HB MT 2094
1992 Honda Civic DX HB AT 2275
1992 Honda Civic Si HB MT 2326
1992 Honda Civic VX HB MT 2094
1992 Honda Civic DX CPE MT 2224
1992 Honda Civic DX CPE AT 2317
1992 Honda Civic EX CPE MT 2390
1992 Honda Civic EX CPE AT 2445
1992 Honda Prelude S MT 2809
1992 Honda Prelude S AT 2862
1992 Honda Prelude Si MT 2866
1992 Honda Prelude Si AT 2921
1992 Honda Prelude VTEC MT 2932
1992 Honda Accord DX CPE MT 2738
1992 Honda Accord DX CPE AT 2804
1992 Honda Accord EX CPE MT 2888
1992 Honda Accord EX CPE AT 2954
1992 Honda Accord LX CPE MT 2822
1992 Honda Accord LX CPE AT 2888
DA 1992 Acura Integra GS Coupe AT 2701
DA 1992 Acura Integra LS Coupe AT 2681
DA 1992 Acura Integra RS Coupe AT 2615
DA 1992 Acura Integra GS Sedan AT 2760
DA 1992 Acura Integra LS Sedan AT 2701
DA 1992 Acura Integra LS Sedan AT 2665
EG 1992 Honda Civic DX SDN MT 2275
EG 1992 Honda Civic DX SDN AT 2342
EG 1992 Honda Civic LX SDN MT 2319
EG 1992 Honda Civic LX SDN AT 2388
EG 1992 Honda Civic EX SDN MT 2480
EG 1992 Honda Civic EX SDN AT 2524
1992 Honda Accord DX Sedan MT 2773
1992 Honda Accord DX Sedan AT 2844
1992 Honda Accord EX Sedan MT 2923
1992 Honda Accord EX Sedan AT 2989
1992 Honda Accord LX Sedan MT 2857
1992 Honda Accord LX Sedan AT 2923
DA 1993 Acura Integra GS Coupe MT 2643
DA 1993 Acura Integra GS-R Coupe MT 2657
DA 1993 Acura Integra LS Coupe MT 2619
DA 1993 Acura Integra RS Coupe MT 2557
DA 1993 Acura Integra GS-Sedan MT 2703
DA 1993 Acura Integra LS-Sedan MT 2643
DA 1993 Acura Integra RS Sedan MT 2608
1993 Acura NSX MT 3009
1993 Honda Civic CX HB MT 2094
EG 1993 Honda del Sol S MT 2277
EG 1993 Honda del Sol S AT 2359
EG 1993 Honda del Sol Si MT 2396
EG 1993 Honda del Sol Si AT 2474
1993 Honda Civic DX HB MT 2178
1993 Honda Civic DX HB AT 2275
1993 Honda Civic Si HB MT 2326
1993 Honda Civic VX HB MT 2094
1993 Honda Civic DX CPE MT 2224
1993 Honda Civic DX CPE AT 2317
1993 Honda Civic EX CPE MT 2390
1993 Honda Civic EX CPE AT 2445
1993 Honda Prelude S MT 2809
1993 Honda Prelude S AT 2862
1993 Honda Prelude Si MT 2866
1993 Honda Prelude Si AT 2921
1993 Honda Prelude VTEC MT 2932
1993 Honda Accord DX CPE MT 2734
1993 Honda Accord DX CPE AT 2800
1993 Honda Accord EX CPE MT 2948
1993 Honda Accord EX CPE AT 3014
1993 Honda Accord LX CPE MT 2822
1993 Honda Accord LX CPE AT 2888
1993 Honda Accord SE CPE AT 3014
DA 1993 Acura Integra GS Coupe AT 2701
DA 1993 Acura Integra LS Coupe AT 2681
DA 1993 Acura Integra RS Coupe AT 2615
DA 1993 Acura Integra GS Sedan AT 2760
DA 1993 Acura Integra LS Sedan AT 2701
DA 1993 Acura Integra LS Sedan AT 2665
EG 1993 Honda Civic DX SDN MT 2275
EG 1993 Honda Civic DX SDN AT 2342
EG 1993 Honda Civic LX SDN MT 2319
EG 1993 Honda Civic LX SDN AT 2388
EG 1993 Honda Civic EX SDN MT 2520
EG 1993 Honda Civic EX SDN AT 2564
1993 Honda Accord DX Sedan MT 2769
1993 Honda Accord DX Sedan AT 2835
1993 Honda Accord EX Sedan MT 2987
1993 Honda Accord EX Sedan AT 3053
1993 Honda Accord LX Sedan MT 2866
1993 Honda Accord LX Sedan AT 2932
DC 1994 Acura Integra GS Coupe MT 2643
DC 1994 Acura Integra GS-R Coupe MT 2667
DC 1994 Acura Integra LS Coupe MT 2643
DC 1994 Acura Integra RS Coupe MT 2529
DC 1994 Acura Integra GS-R Sedan MT 2765
DC 1994 Acura Integra LS Sedan MT 2703
1994 Acura NSX MT 3020
1994 Acura NSX AT 3109
EG 1994 Honda del Sol S MT 2301
EG 1994 Honda del Sol S AT 2387
EG 1994 Honda del Sol Si MT 2414
EG 1994 Honda del Sol Si AT 2474
EG 1994 Honda del Sol VTEC MT 2491
1994 Honda Civic CX HB MT 2108
1994 Honda Civic DX HB MT 2178
1994 Honda Civic DX HB AT 2264
1994 Honda Civic Si HB MT 2390
1994 Honda Civic VX HB MT 2094
1994 Honda Civic DX CPE MT 2231
1994 Honda Civic DX CPE AT 2326
1994 Honda Civic EX CPE MT 2443
1994 Honda Civic EX CPE AT 2502
1994 Honda Prelude S MT 2809
1994 Honda Prelude S AT 2862
1994 Honda Prelude Si MT 2866
1994 Honda Prelude Si AT 2921
1994 Honda Prelude VTEC MT 2932
1994 Honda Accord EX CPE MT 2954
1994 Honda Accord EX CPE AT 3020
1994 Honda Accord LX CPE MT 2822
1994 Honda Accord LX CPE AT 2888
DC 1994 Acura Integra GS Coupe AT 2685
DC 1994 Acura Integra LS Coupe AT 2685
DC 1994 Acura Integra RS Coupe AT 2570
DC 1994 Acura Integra LS Sedan AT 2745
EG 1994 Honda Civic DX SDN MT 2313
EG 1994 Honda Civic DX SDN AT 2392
EG 1994 Honda Civic LX SDN MT 2403
EG 1994 Honda Civic LX SDN AT 2456
EG 1994 Honda Civic EX SDN MT 2522
EG 1994 Honda Civic EX SDN AT 2575
1994 Honda Accord DX Sedan MT 2800
1994 Honda Accord DX Sedan AT 2866
1994 Honda Accord EX Sedan MT 3009
1994 Honda Accord EX Sedan AT 3075
1994 Honda Accord LX Sedan MT 2877
1994 Honda Accord LX Sedan AT 2943
DC 1995 Acura Integra GS-R Coupe MT 2667
DC 1995 Acura Integra LS Coupe MT 2643
DC 1995 Acura Integra RS Coupe MT 2529
DC 1995 Acura Integra SE Coupe MT 2643
DC 1995 Acura Integra GS-R Sedan MT 2765
DC 1995 Acura Integra LS Sedan MT 2738
DC 1995 Acura Integra SE Sedan MT 2703
1995 Acura NSX MT 3047
1995 Acura NSX AT 3113
1995 Acura NSX T AT 3208
1995 Acura NSX T MT 3142
EG 1995 Honda del Sol S MT 2295
EG 1995 Honda del Sol S AT 2387
EG 1995 Honda del Sol Si MT 2414
EG 1995 Honda del Sol Si AT 2474
EG 1995 Honda del Sol VTEC MT 2522
1995 Honda Civic CX HB MT 2108
1995 Honda Civic DX HB MT 2178
1995 Honda Civic DX HB AT 2264
1995 Honda Civic Si HB MT 2390
1995 Honda Civic VX HB MT 2094
1995 Honda Civic DX CPE MT 2231
1995 Honda Civic DX CPE AT 2326
1995 Honda Civic EX CPE MT 2443
1995 Honda Civic EX CPE AT 2502
1995 Honda Prelude S MT 2809
1995 Honda Prelude S AT 2862
1995 Honda Prelude Si MT 2866
1995 Honda Prelude Si AT 2921
1995 Honda Prelude VTEC MT 2932
1995 Honda Accord EX CPE MT 2954
1995 Honda Accord LX CPE MT 2822
1995 Honda Accord LX CPE AT 2888
DC 1995 Acura Integra LS Coupe AT 2685
DC 1995 Acura Integra RS Coupe AT 2570
DC 1995 Acura Integra SE Coupe AT 2685
DC 1995 Acura Integra LS Sedan AT 2780
DC 1995 Acura Integra SE Sedan AT 2708
EG 1995 Honda Civic DX SDN MT 2313
EG 1995 Honda Civic DX SDN AT 2392
EG 1995 Honda Civic LX SDN MT 2376
EG 1995 Honda Civic LX SDN AT 2440
EG 1995 Honda Civic EX SDN MT 2522
EG 1995 Honda Civic EX SDN AT 2575
1995 Honda Accord DX Sedan MT 2800
1995 Honda Accord DX Sedan AT 2866
1995 Honda Accord EX Sedan MT 3009
1995 Honda Accord EX Sedan AT 3075
1995 Honda Accord EX V6 SDN AT 3285
1995 Honda Accord LX Sedan MT 2877
1995 Honda Accord LX Sedan AT 2943
1995 Honda Accord LX V6 SDN AT 3218
DC 1996 Acura Integra GS-R Coupe MT 2667
DC 1996 Acura Integra LS Coupe MT 2643
DC 1996 Acura Integra RS Coupe MT 2529
DC 1996 Acura Integra SE Coupe MT 2643
DC 1996 Acura Integra GS-R Sedan MT 2765
DC 1996 Acura Integra LS Sedan MT 2738
DC 1996 Acura Integra RS Sedan MT 2628
1996 Acura NSX MT 3047
1996 Acura NSX AT 3113
1996 Acura NSX T MT 3142
1996 Acura NSX T AT 3208
1996 Honda Civic CX HB MT 2222
1996 Honda Civic CX HB AT 2298
1996 Honda Civic DX HB MT 2242
1996 Honda Civic DX HB AT 2317
1996 Honda Civic DX CPE MT 2262
1996 Honda Civic DX CPE AT 2339
1996 Honda Civic EX CPE MT 2483
1996 Honda Civic EX CPE AT 2513
1996 Honda Civic HX CPE MT 2313
1996 Honda Prelude S MT 2809
1996 Honda Prelude S AT 2862
1996 Honda Prelude Si MT 2866
1996 Honda Prelude Si AT 2921
1996 Honda Prelude VTEC MT 2932
1996 Honda Accord EX CPE MT 2965
1996 Honda Accord EX CPE AT 3031
1996 Honda Accord LX CPE MT 2855
1996 Honda Accord LX CPE AT 2921
DC 1996 Acura Integra LS Coupe AT 2685
DC 1996 Acura Integra RS Coupe AT 2570
DC 1996 Acura Integra SE Coupe AT 2685
DC 1996 Acura Integra LS Sedan AT 2780
DC 1996 Acura Integra SE Sedan AT 2708
EK 1996 Honda Civic DX SDN MT 2370
EK 1996 Honda Civic DX SDN AT 2319
EK 1996 Honda Civic LX SDN MT 2430
EK 1996 Honda Civic LX SDN AT 2387
EK 1996 Honda Civic EX SDN MT 2568
EK 1996 Honda Civic EX SDN AT 2518
1996 Honda Accord DX Sedan MT 2855
1996 Honda Accord DX Sedan AT 2921
1996 Honda Accord EX Sedan MT 3020
1996 Honda Accord EX Sedan AT 3086
1996 Honda Accord EX V6 SDN AT 3285
1996 Honda Accord LX Sedan MT 2899
1996 Honda Accord LX Sedan AT 2965
1996 Honda Accord LX V6 SDN AT 3219
DC 1997 Acura Integra GS Coupe MT 2680
DC 1997 Acura Integra GS-R Coupe MT 2667
DC 1997 Acura Integra LS Coupe MT 2685
DC 1997 Acura Integra RS Coupe MT 2570
DC 1997 Acura Integra Type-R MT 2600
DC 1997 Acura Integra GS Sedan MT 2767
DC 1997 Acura Integra GS-R Sedan MT 2765
DC 1997 Acura Integra LS Sedan MT 2703
1997 Acura NSX MT 3045
1997 Acura NSX AT 3069
1997 Acura NSX T MT 3140
1997 Acura NSX T AT 3164
RD 1997 Honda CRV MT 3164
1997 Honda Civic CX HB MT 2304
1997 Honda Civic CX HB AT 2238
1997 Honda Civic DX HB MT 2319
1997 Honda Civic DX HB AT 2253
1997 Honda Civic DX CPE MT 2337
1997 Honda Civic DX CPE AT 2271
1997 Honda Civic EX CPE MT 2496
1997 Honda Civic EX CPE AT 2460
1997 Honda Civic HX CPE MT 2339
1997 Honda Civic HX CPE AT 2324
1997 Honda Prelude Base MT 3009
1997 Honda Prelude Base AT 2954
1997 Honda Accord EX CPE MT 3031
1997 Honda Accord EX CPE AT 2965
1997 Honda Accord LX CPE MT 2921
1997 Honda Accord LX CPE AT 2855
1997 Honda Accord SE CPE MT 2921
DC 1997 Acura Integra GS Coupe AT 2638
DC 1997 Acura Integra LS Coupe AT 2643
DC 1997 Acura Integra RS Coupe AT 2529
DC 1997 Acura Integra GS Sedan AT 2725
DC 1997 Acura Integra GS Sedan AT 2764
DC 1997 Acura Integra LS Sedan AT 2742
EK 1997 Honda Civic DX SDN MT 2370
EK 1997 Honda Civic DX SDN AT 2319
EK 1997 Honda Civic LX SDN MT 2438
EK 1997 Honda Civic LX SDN AT 2387
EK 1997 Honda Civic EX SDN MT 2568
EK 1997 Honda Civic EX SDN AT 2518
1997 Honda Accord DX Sedan MT 2921
1997 Honda Accord DX Sedan AT 2855
1997 Honda Accord EX Sedan MT 3020
1997 Honda Accord EX Sedan AT 3086
1997 Honda Accord EX V6 SDN AT 3285
1997 Honda Accord LX Sedan MT 2965
1997 Honda Accord LX Sedan AT 2965
1997 Honda Accord LX V6 SDN AT 3219
DC 1998 Acura Integra GS Coupe MT 2636
DC 1998 Acura Integra GS-R Coupe MT 2665
DC 1998 Acura Integra LS Coupe MT 2640
DC 1998 Acura Integra RS Coupe MT 2526
DC 1998 Acura Integra Type-R MT 2577
DC 1998 Acura Integra GS Sedan MT 2722
DC 1998 Acura Integra GS-R Sedan MT 2762
DC 1998 Acura Integra LS Sedan MT 2703
1998 Acura NSX MT 3066
1998 Acura NSX AT 3066
1998 Acura NSX T MT 3160
1998 Acura NSX T AT 3204
RD 1998 Honda CRV LX 4WD MT 3208
RD 1998 Honda CRV EX 4WD MT 3217
RD 1998 Honda CRV EX 4WD AT 3245
RD 1998 Honda CRV LX 2WD AT 3126
RD 1998 Honda CRV LX 4WD AT 3236
1998 Honda Civic CX HB MT 2295
1998 Honda Civic CX HB AT 2357
1998 Honda Civic DX HB MT 2339
1998 Honda Civic DX HB AT 2392
1998 Honda Civic DX CPE MT 2342
1998 Honda Civic DX CPE AT 2385
1998 Honda Civic EX CPE MT 2504
1998 Honda Civic EX CPE AT 2551
1998 Honda Civic HX CPE MT 2361
1998 Honda Civic HX CPE AT 2429
1998 Honda Prelude Base MT 3009
1998 Honda Prelude Base AT 2954
1998 Honda Prelude Type SH AT 3042
1998 Honda Accord EX CPE MT 2976
DC 1998 Acura Integra GS Coupe AT 2678
DC 1998 Acura Integra LS Coupe AT 2683
DC 1998 Acura Integra RS Coupe AT 2568
DC 1998 Acura Integra GS Sedan AT 2764
DC 1998 Acura Integra LS Sedan AT 2742
EK 1998 Honda Civic DX SDN MT 2339
EK 1998 Honda Civic DX SDN AT 2385
EK 1998 Honda Civic LX SDN MT 2412
EK 1998 Honda Civic LX SDN AT 2458
EK 1998 Honda Civic EX SDN MT 2511
EK 1998 Honda Civic EX SDN AT 2558
1998 Honda Accord EX CPE AT 3042
1998 Honda Accord EX V6 CPE AT 3241
1998 Honda Accord LX CPE MT 2943
1998 Honda Accord LX CPE AT 3009
1998 Honda Accord LX V6 CPE AT 3197
1998 Honda Accord DX Sedan MT 2888
1998 Honda Accord DX Sedan AT 2954
1998 Honda Accord EX Sedan MT 3020
1998 Honda Accord EX Sedan AT 3086
1998 Honda Accord EX V6 SDN AT 3285
1998 Honda Accord LX Sedan MT 2987
1998 Honda Accord LX Sedan AT 2987
1998 Honda Accord LX V6 SDN AT 3241
DC 1999 Acura Integra GS Coupe MT 2639
DC 1999 Acura Integra GS-R Coupe MT 2667
DC 1999 Acura Integra LS Coupe MT 2643
DC 1999 Acura Integra Type-R MT 2577
DC 1999 Acura Integra GS Sedan MT 2764
DC 1999 Acura Integra GS-R Sedan MT 2764
DC 1999 Acura Integra LS Sedan MT 2703
1999 Acura NSX MT 3066
1999 Acura NSX AT 3110
1999 Acura NSX T MT 3160
1999 Acura NSX T AT 2204
RD 1999 Honda CRV LX 4WD MT 3210
RD 1999 Honda CRV LX 4WD AT 3236
RD 1999 Honda CRV EX 4WD MT 3219
RD 1999 Honda CRV EX 4WD AT 3245
RD 1999 Honda CRV LX 2WD AT 3126
1999 Honda Civic CX HB MT 2395
1999 Honda Civic CX HB AT 2423
1999 Honda Civic DX HB MT 2388
1999 Honda Civic DX HB AT 2434
1999 Honda Civic DX CPE MT 2359
1999 Honda Civic DX CPE AT 2405
1999 Honda Civic EX CPE MT 2513
1999 Honda Civic EX CPE AT 2560
1999 Honda Civic HX CPE MT 2370
1999 Honda Civic HX CPE AT 2445
1999 Honda Civic Si CPE MT 2612
1999 Honda Prelude Base MT 3009
1999 Honda Prelude Base AT 2954
1999 Honda Prelude Type SH AT 3042
1999 Honda Accord EX CPE MT 2976
1999 Honda Accord EX CPE MT 2981
DC 1999 Acura Integra GS Coupe AT 2681
DC 1999 Acura Integra LS Coupe AT 2685
DC 1999 Acura Integra GS Sedan AT 2767
DC 1999 Acura Integra LS Sedan AT 2745
EK 1999 Honda Civic DX SDN MT 2339
EK 1999 Honda Civic DX SDN AT 2388
EK 1999 Honda Civic LX SDN MT 2410
EK 1999 Honda Civic LX SDN AT 2456
EK 1999 Honda Civic EX SDN MT 2513
EK 1999 Honda Civic EX SDN AT 2562
1999 Honda Accord EX CPE AT 3042
1999 Honda Accord EX V6 CPE AT 3241
1999 Honda Accord LX CPE MT 2943
1999 Honda Accord LX CPE AT 3009
1999 Honda Accord LX V6 CPE AT 3197
1999 Honda Accord DX Sedan MT 2888
1999 Honda Accord DX Sedan AT 2954
1999 Honda Accord EX Sedan MT 3020
1999 Honda Accord EX Sedan AT 3086
1999 Honda Accord EX V6 SDN AT 3285
1999 Honda Accord LX Sedan MT 2987
1999 Honda Accord LX Sedan AT 2987
1999 Honda Accord LX V6 SDN AT 3241
DC 2000 Acura Integra GS Coupe MT 2639
DC 2000 Acura Integra GS-R Coupe MT 2672
DC 2000 Acura Integra LS Coupe MT 2643
DC 2000 Acura Integra Type-R MT 2595
DC 2000 Acura Integra GS Sedan MT 2725
DC 2000 Acura Integra GS-R Sedan MT 2764
DC 2000 Acura Integra LS Sedan MT 2703
2000 Acura NSX MT 3069
AP1 2000 Honda S2000 MT 2809
2000 Acura NSX AT 3113
2000 Acura NSX T MT 3164
2000 Acura NSX T AT 3208
RD 2000 Honda CRV LX 4WD MT 3210
RD 2000 Honda CRV LX 4WD AT 3236
RD 2000 Honda CRV SE 4WD AT 3254
RD 2000 Honda CRV EX 4WD MT 3219
RD 2000 Honda CRV EX 4WD AT 3245
RD 2000 Honda CRV LX 2WD AT 3126
2000 Honda Civic CX HB MT 2395
2000 Honda Civic CX HB AT 2423
2000 Honda Civic DX HB MT 2388
2000 Honda Civic DX HB AT 2423
2000 Honda Civic DX CPE MT 2359
2000 Honda Civic DX CPE AT 2405
2000 Honda Civic EX CPE MT 2513
2000 Honda Civic EX CPE AT 2560
2000 Honda Civic HX CPE MT 2370
2000 Honda Civic HX CPE AT 2445
2000 Honda Civic Si CPE MT 2612
2000 Honda Prelude Base MT 3009
2000 Honda Prelude Base AT 2954
2000 Honda Prelude Type SH AT 3042
2000 Honda Accord EX CPE MT 2981
DC 2000 Acura Integra GS Coupe AT 2681
DC 2000 Acura Integra LS Coupe AT 2685
DC 2000 Acura Integra GS Sedan AT 2767
DC 2000 Acura Integra LS Sedan AT 2745
EK 2000 Honda Civic DX SDN MT 2339
EK 2000 Honda Civic DX SDN AT 2388
EK 2000 Honda Civic LX SDN MT 2410
EK 2000 Honda Civic LX SDN AT 2456
EK 2000 Honda Civic EX SDN MT 2513
EK 2000 Honda Civic EX SDN AT 2562
2000 Honda Accord EX CPE AT 3048
2000 Honda Accord EX V6 CPE AT 3259
2000 Honda Accord LX CPE MT 2948
2000 Honda Accord LX CPE AT 3014
2000 Honda Accord LX V6 CPE AT 3215
2000 Honda Accord DX Sedan MT 2932
2000 Honda Accord DX Sedan AT 2987
2000 Honda Accord EX Sedan MT 3064
2000 Honda Accord EX Sedan AT 3120
2000 Honda Accord EX V6 SDN AT 3318
2000 Honda Accord LX Sedan MT 3020
2000 Honda Accord LX Sedan AT 3075
2000 Honda Accord LX V6 SDN AT 3274
DC 2001 Acura Integra GS Coupe MT 2639
DC 2001 Acura Integra GS-R Coupe MT 2667
DC 2001 Acura Integra LS Coupe MT 2643
DC 2001 Acura Integra Type-R MT 2639
DC 2001 Acura Integra GS Sedan MT 2725
DC 2001 Acura Integra GS-R Sedan MT 2764
DC 2001 Acura Integra LS Sedan MT 2703
2001 Acura NSX MT 3069
2001 Acura MDX Base AT 4323
2001 Acura MDX Touring AT 4383
AP1 2001 Honda S2000 MT 2809
2001 Acura NSX AT 3113
2001 Acura NSX T MT 3164
2001 Acura NSX T AT 3208
RD 2001 Honda CRV SE 4WD AT 3254
RD 2001 Honda CRV EX 4WD MT 3219
RD 2001 Honda CRV EX 4WD AT 3245
RD 2001 Honda CRV LX 2WD MT 3210
RD 2001 Honda CRV LX 2WD AT 3236
2001 Honda Civic DX CPE MT 2405
2001 Honda Civic DX CPE AT 2452
2001 Honda Civic EX CPE MT 2553
2001 Honda Civic EX CPE AT 2590
2001 Honda Civic HX CPE MT 2434
2001 Honda Civic HX CPE AT 2504
2001 Honda Prelude Base AT 2954
2001 Honda Prelude Type SH AT 3042
2001 Honda Accord EX CPE MT 3014
DC 2001 Acura Integra GS Coupe AT 2681
DC 2001 Acura Integra LS Coupe AT 2685
DC 2001 Acura Integra GS Sedan AT 2767
DC 2001 Acura Integra LS Sedan AT 2745
2001 Honda Civic DX SDN MT 2421
2001 Honda Civic DX SDN AT 2471
2001 Honda Civic LX SDN MT 2465
2001 Honda Civic LX SDN AT 2515
2001 Honda Civic EX SDN MT 2564
2001 Honda Civic EX SDN AT 2615
2001 Honda Accord EX CPE AT 3082
2001 Honda Accord EX V6 CPE AT 3283
2001 Honda Accord LX CPE MT 2967
2001 Honda Accord LX CPE AT 3036
2001 Honda Accord LX V6 CPE AT 3236
2001 Honda Accord DX Sedan MT 2943
2001 Honda Accord DX Sedan AT 3003
2001 Honda Accord EX Sedan MT 3075
2001 Honda Accord EX Sedan AT 3142
2001 Honda Accord EX V6 SDN AT 3329
2001 Honda Accord LX Sedan MT 3031
2001 Honda Accord LX Sedan AT 3097
2001 Honda Accord LX V6 SDN AT 3274
2002 Acura RSX Type S MT 2767
2002 Acura RSX Base AT 2769
2002 Acura RSX Base MT 2694
2002 Acura NSX 3.0 MT 3197
2002 Acura NSX 3.0 AT 3153
2002 Acura MDX Base AT 4374
2002 Acura MDX Touring AT 4436
AP1 2002 Honda S2000 MT 2810
2002 Honda Civic DX CPE MT 2405
2002 Honda Civic DX CPE AT 2452
2002 Honda Civic EX CPE MT 2553
2002 Honda Civic EX CPE AT 2590
2002 Honda Civic HX CPE MT 2434
2002 Honda Civic HX CPE AT 2504
2002 Honda Civic DX SDN MT 2421
2002 Honda Civic DX SDN AT 2471
2002 Honda Civic LX SDN MT 2465
2002 Honda Civic LX SDN AT 2515
2002 Honda Civic EX SDN MT 2564
2002 Honda Civic EX SDN AT 2615
2002 Honda Civic Si MT 2744
2003 Acura RSX Type S MT 2767
2003 Acura RSX Base MT 2694
2003 Acura RSX Base AT 2769
2003 Honda Civic Si MT 2744
2003 Honda S2000 MT 2810
JDM and USDM Civic Chassis Codes
Chassis Motor Origin Year Vehicle
4G (1988-1991)
ED3 1.5L USDM All 4-door DX/LX
ED4 1.6L USDM All 4-door EX
ED6 1.5L USDM All 3-door Standard
ED7 1.6L USDM All 3-door Si
ED8 1.5L USDM All CRX standard / HF
ED9 1.6L USDM All CRX Si
EE2 1.5L USDM All Wagon
EE4 1.6L USDM All Wagon 4WD
EE8 B16A EDM All Civic VTi
EF1 D13B JDM All Civic 3-door/4-door
EF2 D15B JDM All Civic 3-door/4-door
EF3 ZC JDM All Civic Si 3-door/Civic Si Extra 3-door
EF5 ? JDM All Civic 4-door 4wd
EF6 D15B JDM All Civic ? / CR-X
EF7 ZC JDM All Civic ? / CR-X Si
EF8 B16A JDM All CR-X SiR
EF9 B16A JDM All Civic SiR
5G (1992-1995)
EG1 D15B JDM All 3-door/4-door/CR-X
EG1 D15B7 USDM 1993-1995 del Sol S
EG2 B16A JDM All 3-door/4-door/CR-X
EG2 B16A3 USDM 1994-1995 del Sol VTEC (DOHC)
EG3 D13B JDM All 3-door/4-door
EG4 D15B JDM All 3-door/4-door/CR-X
EG5 D16Z6 EDM All 3-door/4-door
EG6 B16A JDM All 3-door/4-door/CR-X
EG7 D13B JDM All 3-door/4-door
EG8 D15B JDM All 3-door/4-door/CR-X
EG8 D15B7 USDM All 4-door DX/LX
EG9 B16A JDM All 3-door/4-door/del Sol CR-X
EH1 ZC JDM All 4-door/4WD
EH2 D15B8/D15Z1/D15B7 USDM All 3-door CX/VX/DX
EH3 D16Z6 USDM 1993-1995 3-door Si
EH6 D16Z6 USDM 1993-1995 del Sol Si
EH9 D16Z6 USDM All 4-door EX
EJ1 D16Z6 USDM All 2-door EX
EJ2 D15Z1 USDM All 2-door DX
6G (1996-2000)
EG1 D16Y7 USDM 1996-1997 del Sol S (SOHC)
EG2 B16A2 USDM 1996-1997 del Sol VTEC (DOHC)
EH6 D16Y8 USDM 1993-1995 del Sol Si (SOHC)
EJ1 D16A JDM All 2-door
EJ3 ? JDM All 2-door / 4WD
EJ6 D16Y7 CANADA All 2-door DX/Si
EJ6 D17A7 CANADA 2000 2-door DX-G/ 3-door CX-G
EJ6 D16Y7 CANADA 1996-1998 3-door CX
EJ6 D16Y7 CANADA 1999-2000 3-door CX/DX
EJ6 D16Y7 CANADA 2000 3-door SE
EJ6 D16Y7 CANADA All 4-door LX/EX
EJ6 D16Y7 USDM All 3-door CX/DX
EJ6 D16Y7 USDM All 4-door DX/LX
EJ6 D16Y7 USDM 1999 4-door DX-V
EJ7 D16Y5 USDM All 2-door HX (VTEC-E)
EJ8 D16Y8 CANADA All 2-door EX
EJ8 D16Y8 USDM All 2-door/4-door EX
EK2 D13B JDM All 3-door/4-door
EK3 D15B JDM All 3-door/4-door
EK4 B16A JDM All 3-door/4-door
EK5 D16A JDM All 4-door 4WD/LEV
EK8 D16A JDM All 4-door 4WD/LEV
EK9 B16B JDM All 3-door Type-R
EM1 B16A2 CANADA 1999-2000 2-door SiR
EM1 B16A2 USDM 1999-2000 2-door Si
7G (2001+)
? 1.7L USDM All 2-door DX/LX
? 1.7L USDM All 4-door DX/LX
? 1.7L USDM All 2-door HX
EM2 D17A1 USDM All 2-door/4-door EX
EP1 1.4L JDM All 3-door
EP2 1.6L JDM All 3-door
EP3 K20A3 USDM 2002+ 3-door Si
EP3 K20C1 JDM All 3-door Type-R
EU7 1.4L JDM All 5-door
EU8 1.6L JDM All 5-door
maxvtec Hors ligne
02-08-2005, 22:08:40   -
Pour faire un awd honda.
http://www.imagestation.com/album/?id=4288370669
En français:
http://www.quebecstreetracing.org/
Petit truc pour l'entretiens:
Flushing Transmission Fluid
http://www.c-speedracing.com/howto/.../transfluid.php
Flushing/Changing Coolant
http://www.d-series.org/forums/showthread.php?t=13144
Cleaning your Idle Air Control Valve (IACV)
http://www.superhonda.com/forum/showthread.php?t=144463
Adjusting your Ignition Timing
http://www.sohchonda.com/articles/a...hp?article=0005
http://www.c-speedracing.com/howto/timing/timing.php
Helms Idle Reset/Adjustment Procedure (96-00 Civic)
http://www.redpepperracing.com/technical/143/afk
D-Series Timing Belt Replacement
http://www.prostreetonline.com/pso/...sp?articleid=38
D-Series/SOHC Valve Adjustment Procedure
http://www.angelfire.com/biz7/aiper...adjustment.html
B-Series/DOHC Valve Adjustment Procedure
http://www.c-speedracing.com/howto/...valveadjust.php
Special Tool for B-Series Valve Adjustment
http://www.toolcraze.com/Merchant2/...egory_Code=spec
http://matcotools.com/Catalog/toolc...6&page=3獞
Following are the specs for the "infamous" Spoon B series motor as queried by the masses.
Here are the details of the Spoon "engine" / longblock once again:
- it is a new 98 spec R longblock
- internal components are JDM OE Honda with the following exceptions
- it is fully balanced and blueprinted
- it uses the Spoon 2 piece headgasket for a compression ratio of 11.3:1
- it uses the Spoon oil pump which is stronger and more effective than the OE Honda one
- it should put out around 180hp at the wheel
what is 'balanced and blueprinted by Spoon'?
- all engine components are weighed to 0.01grams precision
- engine components such as pistons and rods are balanced, they all weigh within 0.01gram of each other
- Spoon is able to balance these components because they order/weigh/sort hundreds of pistons, rods, etc. from Honda and sort them into balanced sets
- bolts are torqued within 0.01N/M of Honda specs
- what does balancing and blueprinting do? it makes the engine run incredibly smooth, reduces power lost to inefficiency, power delivery is extremely smooth, power is higher across the entire rpm band compared to a Honda assembled engine, engine/throttle response is much better, the engine revs smoother/faster and is able to withstand high rpm better, engine life is improved considerably especially in race environments
why does Spoon offer this engine?
- Spoon's core philosophy is in balance: good power, good driving feel, and long life. this engine offers all
- circuit racing requirements differ from drag racing: an engine with the aforementioned characteristics is preferred in circuit racing over a high power, less reliable engine which might be favored in drag racing
- these engines are frequently bought by pro race teams competing according to FIA Group N regulations which require stock internal motors. hence they need an engine which has maximum effectiveness and efficiency using stock parts
who should consider a Spoon engine?
- pro/amateur racers requiring a motor in stock trim (FIA Group N)
- circuit racers/enthusiasts who want an optimized stock motor for circuit use
- people who want a new stock or reliable motor with decent power
who shouldn't consider a Spoon engine?
- drag racers
- people on tight budget or DIY
- people who want a high power setup, N/A or Turbo
- people who don't care about or aren't sensitive to subjective intangibles such as driving feel or engine response
what is the price of a Spoon engine or block?
- it is priced comparably to the price of a new b18c5 longblock/shortblock from Acura considering the work Spoon has put into it
- remember it is a NEW longblock/shortblock
- price fluctuates with supply and demand, although spoon engines aren't common here, remember that they are very common and popular in Japan and Asia
- expect price to increase over time as the supply of b18c components dwindles
- contact an authorized Spoon dealer such as IPS, R&D, A&J for a price quote
does/why doesn't Spoon offer a high power engine?
- again, Spoon's philosophy is balance. to Spoon, high power is only worthwhile if the engine can endure the stress of a 24 hour race. to Spoon, a street tuned engine needs to be comfortable and reliable while delivering improved power and driving feel
- Spoon has built and sold high power engines with 200+whp... high compression kits and stroker kits including a 2L kit for the 18C. However, the reliability and engine life of these engines still aren't good enough for Spoon's standards and hence Spoon does not offer them anymore
- Spoon doesn't drag race
maxvtec Hors ligne
02-08-2005, 22:09:10   -
Pour les s2000:
http://www.superhonda.com/forum/showthread.php?t=193812
The fundamentals to swapping a '94 Prelude H22A engine into a '94 accord
Article Taken from “Honda Tuning” magazine featured February 2004
Engine Removal
Common sense dictates that you should arm yourself with a factory service manual. You’ll spend less o it than all the parts you probably break if you don’t use it. The F22 can be removed from either the top or the bottom, but dropping it from the bottom is easier if you have a lift and engine dolly at hand.
The Trick is to keep the A/C system intact and in the car (including the compressor) during the swap to avoid having to refill it. With compressor removed from the engine, string it up to the lower radiator support to keep it out of harms way.
Keep in mind that a lot of pieces are being reused, so its time well spent making sure you have everything unhooked before you move the engine. Removing the radiator will the engine compartment less cramped, especially if you’re working through the top of the engine compartment, Honda radiators have plastic end tanks that wont hold up to a swinging engine. One tap and they’re toast.
Our swap victim was a very sleepy looking ’94 LX with five speed. Our H2 came complete from HAP Recycling, ad it was from a 94 Prelude-perfect. With the two engines sitting side-by-side you’d be able o quickly piece together all the right bits.
Engine Mounts
Getting the H22 bolted in will require cutting tweaking and general rearrangement of the stock left side mount, or the purchase of Hasports part for this swap. The Hasports part is solid aluminum and comes with a polyurethane bushing, which reduces engine movement but increases vibration compared to stock rubber. The other three mounts are based on original parts. It’s a good time to consider the original mounts you’re reinstalling (hint, buy new mounts). A few decent launches will finish off any old and cracked mounts and its too easy of a job to pass up when the engine is out.
You’ll have to use the softer accord front mount because the stiffer prelude mount is the wrong height – bummer. Either the Accord of the Prelude rear bracket and mount set ( no mixing and matching between them) can be used but the Prelude parts are stiffer and a wiser choice.
If your car started automatic, you’ll need to weld the manual transmission bracket (Honda P/N 60831-SV4-970ZZ) to the right frame rail in place of the automatic part. Or keep your eye out for Hasport-produced mount that will adapt the autos frame rail bracket to a manual transmission.
Wiring
To prep the wiring harness, there’s enough soldering to kill half your brain cells, and plenty of work to stress out the survivors. Hasport also makes one that’s plug and drive. If you go the easy way, you’ll get a modified Accord harness and a separate sub harness, which connects the unique ***** guts to the h22a ECU. To tackle it yourself, get the two engines side by side, add a tasty beverage and get familiar with these mods.
-The oil pressure sender wire, while still using the accord plug, gets extended 5 inches to reach the H22’s sender.
-The electronic air control valve is located near the middle of the fuel rail on the h22 rather that near the throttle position on the F22. To accommodate the EACV plug and its yellow/black and blue/yellow wires gets moved to the center of the injector harness.
-The vehicle speed sensor plug gets moved from the front to the back in the engine, near the O2 sensor plug. Same wires, different location to fit around the h22a.
-Because the distributor is closer to the coil on the accord vs. the h22, the coil, EGR and fan switch circuits need lengthening. While on the EGR wires, change the connector from the accord’s 3 pin square connector to the preludes round one. You can keep the same pins but swap out the plastic connector.
-The intake air temperature sender is located at the end of the intake manifold on the h22 vs. the middle of it on the f22. Extend its red/yellow and green/white wires to fit.
-If your car didn’t come with VTEC, you’ll need to add the wiring for the air intake bypass (AIB), knock sensor, VTEC oil pressure sensor and VTEC solenoid. IF your car was EX, you will only need to add wiring for the IAB and the knock sensor.
-The knock sensor circuit (red/blue) which isn’t there on the stock f22m is added at the same breakout as the oil pressure sending wire by suing the pigtail from eh prelude harness, This wire connects to the sub-harness and then to the ECU pin D3.
-The h22’s AIB circuit that opens the short high rpm runners in the intake manifold also gets added by tapping the black/yellow wire form the h22’s plug to the same color wire that foes to the distributor in the Accords harness. This simply supplies power to the AIB solenoid. The pink signal wire goes from the AIB Solenoid back to the sub-harness/ECU at pin A17.
The VTEC oil pressure switch wiring will already exist on the Accord EX’s, but the rest of us need to add the circuit., The plug from the h22a and its light blue wire gets routed to pin D6 on the ecu. The black/red wire form the switch goes to ground.
-To hookup the VTEC solenoid, connect its green/yellow to pin A4 on the ECU.
-In a futile attempt to throw us off, Honda switched the EGR solenoid valve wire and the O2 sensor heater wire on the ECU’s A connector (pins 6 and 11) on the prelude as compared to the Accord. Swap those two pins in the under das connector and thank the engineers for there effort.
Engine Accessories
Getting the engine dressed with the right combination of parts will be easy if you have everything in front of you outside the car, So resist the temptation before you have a game plan of which parts to use, For engine accessories its all h22 except for the Accord A/C compressor and compressor bracket, Mixing prelude and accord accessories makes either accessory drive belt unusable, but NAPA part number 25-060425 is slightly smaller (42.5 inches, six rib) and works great. The Accords high-pressure power steering line will to be cobbled to fit the h22’s pump. Replace a few inches of the Accord line with a piece you cut from the preludes. Remember. This is the high pressure side of the pump which can run at about 400 times the pressure of the engine oil system, so its not a connection to be made with hose clamps. Brazing or welding required.
Drivetrain
As mentioned preciously, the transmissions are similar, so the accord clutch and slave connection and shifter cables fit without modifications. Don’t you love how Honda makes this easy?
The prelude half shafts are the stronger and should be considered a necessity if you plan to use the extra power. The Accords inner CV joint has a splined section on the half shaft that engages an internally splined section of the half shaft. The preludes assembly has a male spline on the half shaft that engages the beefy CV join casing, a stronger design. Apart from this difference, the sets are dimensionally the same and you’ll have no trouble using the prelude parts in the Accord knuckles and hubs.
Exhaust
The exhaust is another example of great planning (or maybe just laziness) of Honda engineers. How many engine swaps are out there where you can use all OEM parts? The prelude already comes with a nicely made 4-3-1 header. Using the prelude down pipe and cat, the rest of the exhaust system from a 90-93 accord ill bolt up. Another option is to use the prelude SH header, which comes with an adaptor that allows you to use the original (94-97) exhaust system. With either approach, plenty of shops can supply a freer flowing system so the h22’s high end isn’t snuffed out.
Intake
The accord throttle body is smaller than the prelude part, so all the work you just did will be gasping for air right about when VTEC switches. The accord throttle body works fine for regular sedan driving. The h22a will breather deeper and easier, especially at high revs where the Accord engine never ventured. If you don’t need cruise control, you can use the Prelude throttle body and prelude cables. Unlike the accord throttle body’s integrated MAP sensor, the preludes sensor is mounted on the firewall in a mystery box. Use a MAP from a ’90-93 Civic DX mount to the firewall in place of the Prelude mystery box (which has other emissions control functions we don’t need). To keep cruise control, stay with an Accord-like throttle body and cables.
Fuel System
When you try hookup the fuel line, you’ll notice the accords rubber line bolts onto eh opposite side of the fuel rails as the prelude. Fortunately, a ’97-or-newer Prelude fuel rail will marry the fuel systems. The part number from the dealer is 16610-PT3-A00.
Cooling
Heater hoses from the 96 Prelude are slightly longer that earlier prelude and Accord pieces and will fit better, Similarly, Prelude radiator hoses are required to match up the h22, The radiator that came with he accord will be big enough for the h22 in stock form. The h22a accord radiator used in JDM applications is a slightly thicker than the North American five-speed radiator. The thicker radiator was also used in North American automatic transmission cars if you’re going for authenticity.
maxvtec Hors ligne
02-08-2005, 22:09:43   -
Lien pour turbo merci à speedix du ccq:
La plupart des sites suivants sont pour le moteur ZC, mais c'est la même chose pour les d16!
http://www.homemadeturbo.com/ -- Turbo Projects with the HF manifold, etc; Abaz's old site
http://thenew.gamesbbs.com/~turbosi/ -- Gary and Randy's HF manifold turbo site; lots of info
http://www.turbocrx.net/ -- Great site with great pictures and information on homemade turbos
http://www.thedropshop.tv/cheapo -- Jon's 14B and T25 HF manifold turbos; angled adapters
http://www.thedropshop.tv/vafc.htm -- VFAC control while under boost, under Jon's website
http://www.216turbo.com/index2.htm -- British Rover / ZC Turbo website, install and info
http://members.truepath.com/bryson/bryson.html -- Bryson's homemade turbo setup
http://www.geocities.com/MotorCity/... -- Interesting HF manifold turbo website; decent info
http://www.turbocivic.net/ -- Decent 92-95 Greddy install with lots of pics, etc
http://www.geocities.com/civic_fi/zdyne/zdyne.html -- Zdyne file sharing database
http://www.jgstools.com/turbo/ -- Very nice machining page and custom manifolds
Gracieuseté de Shorty's sur homedeturbo.com
http://www.honda-tech.com/zerothread?id=248965 - truth about EGT's
http://www.honda-tech.com/zerothread?id=221260 - propane injection
http://zoogle.zapto.org/wastegate.jpg - how to lower boost.
http://www.homemadeturbo.com/forum/index...10;start=0 - Jeff's Tyrus Intercooler install CRX
http://www.homemadeturbo.com/forum/index...eadid=2952 - lowering boost (carb spring, jeff)
http://www.homemadeturbo.com/forum/index...readid=989 - making manifold (shortyz)
http://www.homemadeturbo.com/forum/index...62;start=0 - mezbo's manifold
http://www.homemadeturbo.com/forum/index...38;start=0 - jeffs air to water.
http://www.homemadeturbo.com/forum/index...eadid=2450 - a/r
http://www.homemadeturbo.com/forum/index...eadid=3363 - calculating intercooler
http://www.homemadeturbo.com/forum/index...eadid=3361 - testing WG
http://www.homemadeturbo.com/forum/index...eadid=3359 - lowering audi WG.
http://www.honda-tech.com/zerothread?id=373528&page=2 - chipping
http://www.honda-tech.com/zerothread?id=366319 - clutch install
http://www.honda-tech.com/zerothread?id=67146 -oil return
http://www.honda-tech.com/zerothread?id=109160 -oil return line setup
http://www.honda-tech.com/zerothread?id=114490 -oil return line parts
http://www.honda-tech.com/zerothread?id=71999 -where to weld oil return
http://www.honda-tech.com/zerothread?id=119100 -oil return line
http://www.honda-tech.com/zerothread?id=119539 -oil pan welding
http://www.honda-tech.com/zerothread?id=119715 -oil pan welding
http://www.honda-tech.com/zerothread?id=118687 -oil grade to use
http://www.honda-tech.com/zerothread?id=118694 -ft for oil feed line
http://www.honda-tech.com/zerothread?id=118807 -oil feed line
http://www.honda-tech.com/zerothread?id=119681 -oil feed line
http://www.honda-tech.com/zerothread?id=93550 -part for oil feed line
http://www.honda-tech.com/zerothread?id=114436 -where to buy brass t for feed line
http://www.honda-tech.com/zerothread?id=126335 -oil t question
http://www.honda-tech.com/zerothread?id=125438 -another place to buy oil lines
http://www.honda-tech.com/zerothread?id=131447 -oil feed line an/npt connector ?
http://www.honda-tech.com/zerothread?id=134078 -feed diagram
http://www.honda-tech.com/zerothread?id=133948 -oil bpst fitting again
http://www.honda-tech.com/zerothread?id=144586 -oil feed line restrictor
http://www.honda-tech.com/zerothread?id=155510 -oil leaks
http://www.honda-tech.com/zerothread?id=158018 -oil feed 3' better
http://www.honda-tech.com/zerothread?id=156571 -oil pan bolts
http://www.honda-tech.com/zerothread?id=170223 -oil pressure readings
http://www.honda-tech.com/zerothread?id=168084 -oil feed fitting
http://www.honda-tech.com/zerothread?id=131450 -oil feed diagram
http://www.honda-tech.com/zerothread?id=195068 -oil pressu
http://www.honda-tech.com/zerothread?id=364948 -BSPT and NPT AN explanation. ***
http://www.honda-tech.com/zerothread?id=365360 -install of walbro 255lph EF
http://www.honda-tech.com/zerothread?id=122635 -drag 3 (to) coolant line?
http://www.honda-tech.com/zerothread?id=116891 -closed loop turbo info
http://www.honda-tech.com/zerothread?id=119724 -drag 3 turbo fitment (filing block)
http://www.honda-tech.com/zerothread?id=119690 -vacuum source
http://www.honda-tech.com/zerothread?id=94820 -closed loop
http://www.honda-tech.com/zerothread?id=120814 -Drag3 downpipe
http://www.honda-tech.com/zerothread?id=120867 -Drag3 + Tial connection
http://www.honda-tech.com/zerothread?id=118699 -wastegate vacuum line
http://www.honda-tech.com/zerothread?id=118767 -feul pump for drag 3
http://www.honda-tech.com/zerothread?id=121442 -fittings (brass T on block)
http://www.honda-tech.com/zerothread?id=123326 -blow off valve tightening
http://www.honda-tech.com/zerothread?id=123925 -catalytic converter removal o2 sensor
http://www.honda-tech.com/zerothread?id=124474 -'burning' in the turbo + blow off valve ?
http://www.honda-tech.com/zerothread?id=124580 -drag 3 manifold boost spike issues
http://www.honda-tech.com/zerothread?id=124662 -drag 3 tial fitment
http://www.honda-tech.com/zerothread?id=151845 -closed loop dump tube
http://www.honda-tech.com/zerothread?id=155616 -flexpipe issue
http://www.honda-tech.com/zerothread?id=159889 -blow off valve adjusting/cleaning
http://www.honda-tech.com/zerothread?id=163453 -egt probe tapping
http://www.honda-tech.com/zerothread?id=167329 -o2 sensor bung
http://www.honda-tech.com/zerothread?id=170498 -don't use tial gasket
http://www.honda-tech.com/zerothread?id=175270 -intercooler direction
http://www.honda-tech.com/zerothread?id=175277 -drag bolts suck
http://honda-tech.com/zerothread?id=373528 -map sensor explanation and chipping
http://www.honda-tech.com/zerothread?id=206376 -bov greddy type s (loose)
http://www.honda-tech.com/zerothread?id=120548 -hondata install (solder stuff)
http://www.honda-tech.com/zerothread?id=98092 -hondata install heiarchy
http://www.honda-tech.com/zerothread?id=121859 -hondata info on pumps
http://www.honda-tech.com/zerothread?id=117300 -spark plugs
http://www.honda-tech.com/zerothread?id=156273 -spark plugs (2)
http://www.honda-tech.com/zerothread?id=116886 -changing plugs
http://www.honda-tech.com/zerothread?id=117326 -flexpipe for good price
http://www.honda-tech.com/zerothread?id=117733 -injectors, 440 or 550
http://www.honda-tech.com/zerothread?id=119569 -guage for autometer
http://www.honda-tech.com/zerothread?id=119591 -autometer guages
http://www.honda-tech.com/zerothread?id=121452 -aero fpr
http://www.honda-tech.com/zerothread?id=119884 -best FPR?
http://www.honda-tech.com/zerothread?id=118885 -place to buy aem fpr
http://www.honda-tech.com/zerothread?id=122590 -(installing) aeromotive fuel regulator
http://www.honda-tech.com/zerothread?id=86051 -removing/installing intank fuel pump
http://www.honda-tech.com/zerothread?id=120889 -profec b install
http://www.honda-tech.com/zerothread?id=116651 -Radiator fans
http://www.honda-tech.com/zerothread?id=119819 -diff between mechanical/electrical gauges
http://www.honda-tech.com/zerothread?id=117513 -turbo XS boost controllers and tial wastegates
http://www.honda-tech.com/zerothread?id=122396 -block guard
http://www.honda-tech.com/zerothread?id=107030 -rc 440 injector polarity
http://www.honda-tech.com/zerothread?id=82211 -rc 440 after hondata install
http://www.honda-tech.com/zerothread?id=121452 -aeromotive fpr part #
http://www.honda-tech.com/zerothread?id=125639 -hks ssbv clip
http://www.honda-tech.com/zerothread?id=153531 -more hks bov install
http://www.honda-tech.com/zerothread?id=125852 -carsound cat part #
http://www.honda-tech.com/zerothread?id=92570 -turbo timer relay
http://www.honda-tech.com/zerothread?id=128321 -turbo timer wiring
http://www.honda-tech.com/zerothread?id=132485 -radius rods
http://www.honda-tech.com/zerothread?id=63095 -rear seat removal
http://www.honda-tech.com/zerothread?id=133644 -injector fitment
http://www.honda-tech.com/zerothread?id=104940 -thermal to cat issues
http://www.honda-tech.com/zerothread?id=136680 -egt guage stuff
http://www.honda-tech.com/zerothread?id=137223 -which runner to tap for egt
http://www.honda-tech.com/zerothread?id=55987 -aem fpr against strut bar
http://www.honda-tech.com/zerothread?id=139706 -tools to carry
http://www.honda-tech.com/zerothread?id=140003 -base fuel map
http://www.honda-tech.com/zerothread?id=140774 -bleeding coolant
http://www.honda-tech.com/zerothread?id=156073 -js safeguard
http://www.honda-tech.com/zerothread?id=168470 -js safeguard, who is using
http://www.honda-tech.com/zerothread?id=160428 -summit part
http://www.honda-tech.com/zerothread?id=170160 -9psi, raise static fuel + retard timing
http://www.honda-tech.com/zerothread?id=170821 -wires to tap for guages
http://www.honda-tech.com/zerothread?id=171397 -c clamp pliers for hks bov
http://www.honda-tech.com/zerothread?id=171314 -EGT temps
http://www.honda-tech.com/zerothread?id=166449 -vacuum sources
http://www.honda-tech.com/zerothread?id=175335 -assembling an fittings
http://www.honda-tech.com/zerothread?id=176725 -oem fan clearance - move to right
http://www.honda-tech.com/zerothread?id=193263 -greddy profec b
http://www.honda-tech.com/zerothread?id=85987 -installing rc injectors
http://www.honda-tech.com/zerothread?id=106033 -matching wires rc injectors
http://www.honda-tech.com/zerothread?id=133644 -fitment of rc injectors
http://www.honda-tech.com/zerothread?id=107030 -polarity does not matter
http://www.honda-tech.com/zerothread?id=154935 -once installed
http://www.honda-tech.com/zerothread?id=159623 -tips to install
turbo install http://coolazz.tripod.com/turbo.html http://home.attbi.com/~jeffrich/
injectors http://www.hstuners.com/forums/showthrea...adid=11436
resister wiring http://www.honda-tech.com/zerothread?id=441107
fuel pump http://www.theoldone.com/articles/fuelpump/
DIY boost controller http://www.geocities.com/chmwatson/FAQs/mbc.html
DIY Oil line kit http://www.honda-tech.com/zerothread?id=432769
Oil press sensor install http://www.theoldone.com/articles/oilpressure/
a/f gauge install http://www.rx-7.org/1stgen/airfuel.htm http://www.roadraceengineering.com/instr...ctions.htm http://www.hstuners.com/forums/showthrea...readid=826
boost gauge install http://www.seansa4page.com/mya4s/995/boo...gauge.html http://www.carreview.com/projecteclipse%...gecrx.aspx http://www.seansa4page.com/mya4s/97/boost/boost.html http://www.roadraceengineering.com/instr...ctions.htm
maxvtec Hors ligne
02-08-2005, 22:10:47   -
Honda/Acura Throttle Body Inside Diameters (in mm)
Engine mm
b18c1 60
b18c spec R 62
b18a 58
b18b 60
b16a SiR 58
b16a2 60
b16a3 58
b20b/z 60
f20c 62
d15b7 56
d16a6 55
d16y7 56
d16y8 56
d16z6 56
ZC 55
d16a1 55
d16a8 55
h22a / h23a 60
f22 / f23 60
La différence entre les tranny itr et ctr.
Type Hydraulic Hydraulic
ITR B16a
1st 3.230 3.230
2nd 2.105 2.105
3rd 1.458 1.458
4th 1.034 1.107
5th 0.787 0.848
final Drive 4.785 4.400
Reverse 3.000 3.000
Le ratio d'une couple de tranny.
86-87 integra: 3.181, 1.944, 1.347, 1.033, 0.848, FD = 4.216, R = 3.000
88-89 integra: 3.181, 1.944, 1.347, 1.033, 0.823, FD = 4.216, R = 3.000
Civic STD 88-91 Cable no 3.23 1.894 1.259 0.937 0.771 3.888 3
Civic DX Hatch 88-91 Cable no 3.25 1.894 1.259 0.937 0.771 3.888
Civic LX 88-91 Cable no 3.25 1.65 1.033 0.823 0.694 2.954
Civic Si 88-91 Cable no 3.25 1.894 1.259 0.937 0.771 4.25
Civic EX 88-91 Cable no 3.25 1.894 1.259 0.937 0.771 3.888
Civic EX coupe 92-95 Hydro no 3.25 1.9 1.25 0.909 0.702 4.25
Civic DX coupe 92-95 Hydro no 3.25 1.761 1.172 0.909 0.702 4.058
Civic CX 92-95 Hydro no 3.25 1.761 1.172 0.909 0.702 3.888
Civic EX sedan 92-95 Hydro no 3.25 1.782 1.172 0.909 0.702 3.722
Civic LX Sedan 92-95 Hydro no 3.25 1.761 1.066 0.852 0.702 3.25
Civic DX Sedan 92-95 Hydro no 3.25 1.761 1.066 0.852 0.702 3.25
Civic Si/EX 92-95 D16Z6 Hydro no 3.25 1.9 1.25 0.909 0.702 4.25
Civic VX 92-95 Hydro no 3.25 1.161 1.066 0.853 0.75 3.25
Civic DX Hatch 92-95 Hydro no 3.25 1.762 1.172 0.909 0.702 4.058
Civic EX coupe 96-2000 Hydro no 3.25 1.9 1.25 0.909 0.702 4.25
Civic HX coupe 96-2000 Hydro no 3.25 1.761 1.066 0.852 0.702 3.722
Civic DX coupe 96-2000 Hydro no 3.25 1.761 1.172 0.852 0.702 3.888
Civic EX sedan 96-2000 D16Y8 Hydro no 3.25 1.9 1.25 0.909 0.702 3.722
Civic LX Sedan 96-2000 Hydro no 3.25 1.761 1.172 0.852 0.702 3.888
Civic DX Sedan 96-2000 Hydro no 3.25 1.761 1.172 0.852 0.702 3.722
Civic DX Hatch 96-2000 Hydro no 3.25 1.761 1.066 0.852 0.702 3.722
Civic CX Hatch 96-2000 Hydro no 3.25 1.761 1.172 0.909 0.702 3.888
CRX Si *87 Cable no 2.92 1.76 1.19 0.87 0.71 4.4
CRX Si 85-86 D15 Cable no 3.3 1.99 1.35 1 0.79 4.27
CRX HF 84-87 Cable no 2.92 1.76 1.18 0.82 0.65 3.85
CRX DX 84-87 Cable no 2.38 1.76 1.18 0.85 0.71 4.27
CRX HF 88-91 Cable no 3.25 1.65 1.033 0.823 0.694 2.954
L3 CRX DX 88-91 D15A1 Cable no 3.25 1.864 1.259 0.937 0.771 3.888
CRX Si 88-91 D16A6 Cable no 3.25 1.894 1.259 0.937 0.771 4.25
Del Sol S 93-97 D15B7 Hydro no 3.25 1.761 1.172 0.909 0.702 3.888
Del Sol Si 93-95 D16Z6 Hydro no 3.25 1.9 1.25 0.909 0.75 4.25
Del Sol Si 96-97 D16Y8 Hydro no 3.25 1.9 1.25 0.909 0.75 4.25
and the one you've all been waiting for:
Civic Vti JDM *1999 D15B Hydro no 3.25 1.782 1.172 0.909 0.702 4.058 3.153
Un lien sur les tranny.
http://www.geocities.com/bing_bong916/trannyspecs1.html
Les frankensteins:
Et oui il est possible de faire des moteur avec base pas vtec et une tête de vtec voici quelque renseignement.
Pour les ls-vtec ou b2o-vtec la base
b18b1
b18b2
b20b
b2oz
Avec les moteurs si dessus vous pouvez faire un frankenstein.
Voici les tête de moteur qui fite avec:
b16a
b16a1
b16a2
b16a3
b17a1
b18c
b18c1
b18c3
b 18c5
Il a aussi des mini-me ça c'est fait avec des serie-d
Voici les base
D15A Honda Civic DX 1988-1991
D15A1 Honda CRX DX 1988-1991
D15A2 Honda CRX HF (Carbed) 1984-1987
D15B2 Honda Civic DX/LX 1988-1991
D15B6 Honda Civic HF/CRX HF 1988-1989
D15B6 Honda Civic HF/CRX HF 1990-1991
D15B7 Honda Civic DX/LX 1992-1995
D15B8 Honda Civic CX 1992-1995
D15Y7 Honda Civic DX/LX/CX 1996-2000
D15Z Honda Civic HF 1996-2000
D16A1 Acura Integra 1986-1987
D16A3 Acura Integra 1988-1989
D16A8/9 Acura Integra 1988-1989
Pis les tête qui vont avec
D15Z1 Honda Civic VX 1992-1995
D15B Honda civic Ferio 1996-2000
D16Y8 Honda Civic EX 1996-2000
D16Z6 Honda Civic EX/Si /Del Sol Si 1992-1995
Si vous vouler faire un moteur comme ça svp faite a faire avec quelqu'un qui connais les honda parce que vous risquer d'avoir des gros trouble.
Une site qui explique bien:
http://crx.honda-perf.org/articles/z6swap/z6swap.html
ECU codes:
PG6 : 88-89 Integra (all makes)
PM5 : 88-91 Civic/CRX DX
PM6 : 88-91 Civic/CRX SOHC Si
PM7 : 89-91 DOHC ZC (JDM 'EF' ECU)
PM8 : 88-91 CRX HF
PR2 : 89-91 ZC (Euro)
PR3 : 89-91 JDM B16A EF8/9
PR3 -J00 or J51 : 92 JDM Integra B16A EF8/9
PW0 : 89-91 JDM B16A EF8/9 DA6-XSi
PR4 : 90-91 Integra LS/GS
PS9 : 88-91 4 door Civic EX Auto
P05 : 92-95 OBD-1 Civic CX
P06 : 92-95 OBD-1 Civic DX
P07 : 92-95 OBD-1 Civic VX
P08 : 92-95 OBD-1 Civic D15 JDM
P0A : 94-95 OBD-1 Accord EX
P13 : 93-95 OBD-1 Prelude Vtec
P14 : 93-95 OBD-1 Prelude Si (non Vtec)
P27 : 92-95 OBD-1 EG JDM Civic 1600 sohc
P28 : 92-95 OBD-1 Civic Si/Ex
P30 : 92-95 OBD-1 DelSol DOHC Vtec Si/EG SiR
P54-G31 : 1997 Honda Accord 1.8 LS
P61 : 92-93 OBD-1 Integra GSR
P72 : 94-95 OBD-1 Integra GSR
P72 : 96-00 OBD-2 Integra GSR
P73 : 96-00 OBD-2 Integra Type-R (JDM & USDM)
P74/75: 92-95 OBD-1 Integra LS/GS
P75 : 96-00 OBD-2 Integra LS/GS
P2N : 96+ OBD-2 Civic HX Coupe
P2P : 96+ OBD-2 Civic EX Coupe
P2E : 96+ OBD-2 Civic DX Coupe
P2M : 96+ OBD-2 NZ Civic SOHC VTEC
P2T : 99+ OBD-? Civic Si Coupe
P5P : 97-00 OBD-2 Prelude Type-S (JDM ECU)
PBA : 97+ US Acura 1.6EL
PCT : 98+ JDM ITR / CTR
PCX : 99+ OBD-? S2000
Motors with horsepower ratings
EW4 1.4L & 1.5L SOHC PGM-Fi '84-'87 Civic 60-92hp
D15B 1.5L SOHC non-VTEC '88-'95 Civic's 62-102hp
D16A1 1.6 L DOHC 86-89 Integra 86/87 113hp 88/89 118hp
D16A6 1.6L SOHC 88-91 Civic Si/ CRX Si 108hp
ZC JDM equivalent of D16A1 130ps
D16Z6 1.6L SOHC VTEC 92-95 Civic EX/Si 125hp
D16Y5 1.6L SOHC VTEC-E 96-00 Civic HX 115hp
D16Y7 1.6L SOHC non-VTEC 96+ Civic CX/DX/LX 106hp
D16Y8 1.6L SOHC VTEC 96+ Civic EX 127hp
B16A 1.6L JDM DOHC VTEC 89-91 Civic Si-R I/CRX Si-R, Integra RSi/XSi 160ps
B16A2/3 1.6L USDM DOHC VTEC 93-97 DelSol VTEC/99-00 Civic Si 160hp
B16A 1.6L JDM DOHC VTEC 92-95 Civic Si-R II/ 92-97 CRX DelSol SiR 170ps
B16B 1.6L JDM DOHC VTEC 98+ Civic Type R 185ps
D17A2 1.7L SOHC VTEC-E 01 Civic EX 127hp
D17A1 1.7L SOHC non-VTEC '01+ Civic DX/LX 115hp
B17A1 1.7L USDM DOHC VTEC 92-93 Integra GS-R 160hp
B18A1 1.8L USDM DOHC non-VTEC 90-93 Integra RS/LS/GS 90-91: 130hp / 92-93: 140hp
B18B1 1.8L USDM DOHC non-VTEC 94-01 Integra RS/LS/GS 140hp
B18C 1.8L JDM DOHC VTEC 94+ Integra SiR-G 180ps
B18C1 1.8L USDM DOHC VTEC 94+ Integra GS-R 170hp
B18C5 1.8L USDM DOHC VTEC 97+ Integra Type R 195hp
B18C6/7 1.8L JDM DOHC VTEC 96+ Integra Type R 200ps
B20A5 2.0L DOHC non-VTEC 87-91 Prelude 2.0Si 135hp
B20B 2.0L DOHC non-VTEC 96-98 CR-V 126hp
B20Z 2.0L DOHC non-VTEC 99-01 CR-V 143hp
B21A1 2.1L DOHC non-VTEC 90-91 Prelude Si 145hp
K20A3 2.0L DOHC i-VTEC '02+ RSX
'02+ Civic Si 160hp
K20A2 2.0L DOHC i-VTEC 02+ RSX Type S
02+ Civic TypeR 200hp
K20A 2.0L JDM DOHC i-VTEC '02+ Integra Type R 220ps
F20A1 2.0L JDM DOHC non-VTEC 90-93 Accord Si 155hp
F20B 2.0L JDM DOHC VTEC 90-93 Accord Si-R 190ps
F20C1 2.0L DOHC VTEC '00+ S2000 250ps/240hp
F22A1 2.2L USDM non-VTEC 92-96 Prelude S 90-93 Accord LX/EX
130hp-135hp
F22B 2.2L USDM SOHC VTEC 94-97 Accord EX/97 2.2CL 145hp
F23A5 2.3L USDM SOHC 98+ Accord DX 135hp
F23A1 2.3L USDM SOHC VTEC 98+ Accord EX & LX/98-99 2.3CL
150hp
F23A4 2.3L USDM SOHC ULEV VTEC 98+ Accord EX & LX 148hp
H22A1 2.2L USDM DOHC VTEC 92-96 Prelude VTEC 190hp
H22A4 2.2L DOHC VTEC 97-01 Prelude VTEC/SH 97-98: 195hp 99-01: 200hp
H22A 2.2L JDM DOHC VTEC 92+ Prelude Type-S, 97+ Prelude SiRS Spec 220ps
H23A1 2.3L USDM DOHC non-VTEC Prelude Si 160hp
G25A1 2.5L USDM SOHC non-VTEC 96-98 2.5TL 176hp
J25A 2.5L JDM SOHC VTEC V6 JDM Honda Aspire/Sabre 200ps
C27?? 2.7L USDM SOHC non-VTEC V6 86-89 Legend 150-160hp
C27?? 2.7L USDM SOHC non-VTEC V6 95-97 Accord V6 170HP
C30A(?) 3.0L DOHC VTEC V6 91-96 NSX/NSX-T 270hp
J30A1 3.0L USDM SOHC VTEC V6 98-02 Accord V6/97-99 3.2CL 200hp
C32A6 3.2L USDM SOHC non-VTEC V6 91-95 Legend Sdn, 91-92 Legend Cpe 96-98 3.2TL 200hp
C32A5 3.2L USDM SOHC non-VTEC V6 94-95 Legend GS Sdn, 93-95 Legend Cpe 230hp
C32A? 3.2L DOHC VTEC- V6 97+ NSX/NSX-T 290hp
J32A1 3.2L USDM SOHC VTEC V6 98+ 3.2TL/3.2CL 225hp
J32A2 3.2L USDM SOHC VTEC V6 00+ 3.2CL Type-S, 01 3.2TL Type-S 260hp
C35A2 3.5L USDM SOHC non-VTEC V6 3.5RL 215-225hp
J35A1 3.5L USDM SOHC VTEC V6 98+ Odyessy 210hp
J35A3 3.5L USDM SOHC VTEC V6 Acura MDX 240hp
Accord
5G Japan '94-'97 H22 2157 10.6:1 190hp@6800/152ft/lbs@5500
4G Japan '90-'93 F20A 1997 9.5:1 150hp@6100/137ft/lbs@5000
civic
6G Japan '97-'00 B16B 1595 10.8:1 184hp@8200/118ft/lbs@7500
6G Japan '96-'00 B16A 1595 10.4:1 168hp@7800/118ft/lbs@4500
6G Europe '96-'00 B16A 1595 10.4:1 168hp@7800/118ft/lbs@4500
5G Japan '92-'95 B16A 1595 10.4:1 168hp@7800/118ftlbs@7300
4G Europe '89-'92 B16A1 1595 10.2:1 158hp@7600/111ft/lbs@7000
4G Japan '88-'91 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700
4G Japan '89-'92 B16A 1595 10.2:1 158hp@7600/112ft/lbs@7000
4G Japan '90-'91 B16A1 1595 10.4:1 160hp@7600/111ft/lbs@7000
3G Japan '86-'87 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700
crx/delsol
5G Europe '94-'97 B16A3 1595 10.2:1 158hp@7600/112ft/lbs@7000
5G Japan '92-'96 B16A 1595 10.4:1 168hp@7800
4G Japan '89-'92 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700
3G Japan '85-'87 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700
Integra
3G Japan '95-'97 B18C 1797 10.6:1 178hp@7600/129ft/lbs@6200
3G Japan '95-'00 B18C 1797 11.0:1 197hp@8000/130ft/lbs@7500
2G Japan '90-'93 ZC 1590 9.0:1 119hp@6300/105ft/lbs@5500
2G Japan '90-'91 B16A 1595 10.4:1 158hp@7600/112ft/lbs@7000
1G Japan '86-'89 ZC 1590 9.6:1 129hp@6800/106ft/lbs@5700
prelude
5G Japan '97+ H22A 2157 10.6:1 200hp@6800/161ft/lbs@5500
4G Japan '92-'96 F22 2156 160hp@5800/156ft/lbs@5000
4G Japan '92-'96 H22 2157 10.6:1 200hp@6800/161ft/lbs@5500
Engine codes:
A20A3 Honda Accord 1988-1989
B16 Acura Integra XSi/RSi (JDM) 1990-1991
B16 Acura Integra XSi/RSi 1992-1993
B16A Honda Civic SiR (JDM) 1989-1991
B16A Honda Civic (EDM) 1992-1995
B16A Honda Civic VTi 1996-2000
B16A Honda Del Sol/CRX SiR 1992-1996
B16A Honda Civic SiR (JDM-Hatch) 1989-1992
B16A1 Honda CRX 1.6i/VTi (EDM) 1989-1992
B16A1 Honda CRX SiR 1990-1991
B16A1 Honda Civic SiR (JDM) 1990-1991
B16A2 Honda Civic Si 1999-2000
B16A2 Honda Civic SiRII (JDM) 1992-1995
B16A2 Honda Del Sol (JDM) 1993-1995
B16A3 Honda Del Sol 1992-1995
B16B Honda Civic Type R (JDM) 1998-2001
B17A1 Acura Integra GSR 1992-1993
B18A1 Acura Integra GS 1990-1991
B18A1 Acura Integra GS 1992-1993
B18B1 Acura Integra GS/LS/RS 1994-1995
B18B1 Acura Integra GS/LS/RS 1996-2000
B18C Acura Integra SiR (JDM) 1995-1997
B18C1 Acura Integra GSR 1994-2001
B18C3 Honda Integra Type R 1995-1998
B18C5 Acura Integra Type R 1998-2001
B18C5 Honda Integra Type R 1997-2001
B20A3 Honda Prelude 2.0 S 1990-1991
B20A5 Honda Prelude 2.0 Si 1990-1991
B20A5 Honda Prelude Si 1988-1989
B20B Honda CRV 1997-1998
B20Z Honda CRV 1998-2001
B21A1 Honda Prelude Si 1990-1991
C30A Acura NSX 2002+
C32B Acura NSX 2002+
D16Y7 Honda Civic DX/LX/CX 1996-2000
D16A6 Honda Civic Si/CRX Si 1988-1991
D16A6 Honda Civic EX 1990-1991
D17A1 Honda Civic DX/LX 2001+
D17A2 Honda Civic EX 2001+
EW4 Honda CRX Si 1985-1987
EW4 Honda Civic Si 1986-1987
F20A Honda Accord 2.0Si (JDM) 1990-1993
F20C Honda S2000 2000+
F22 Honda Prelude Si 1992-1996
F22A1 Honda Accord 1990-1993
F22A1 Honda Prelude S 1992-1996
F22A4 Honda Accord 1990-1991
F22A6 Honda Accord 1991-1993
F22B1 Honda Accord EX 1994-1997
F22B2 Honda Accord DX/LX 1994-1997
H22 Honda Accord SiR 1994-1997
H22 Honda Prelude VTEC 1992-1996
H22A Honda Prelude SiR (JDM) 1997-2001
H22A Honda Prelude 1999-2001
H22A Honda Prelude Type S (JDM) 1997-2001
H22A1 Honda Prelude 1997-1998
H22A1 Honda Prelude VTEC 1994-1996
H23 Honda Prelude Type S (JDM) 1993-1995
H23A1 Honda Prelude SE/Si 1992-1996
K20A Acura Integra (JDM) 2001+
K20A Honda Civic Type R (JDM) 2001+
K20A Integra Type R (JDM) 2001+
K20A Acura Integra IS (JDM) 2001+
K20A2 Acura RSX Type S 2001+
K20A3 Acura RSX 2001+
K20A3 Honda Civic Si 2002+
K24 Honda CRV 2002+
ZC Honda CRX (JDM) 1990-1993
ZC Honda CRX Si16/1.6i (JDM) 1989-1992
ZC Honda CRX Si (JDM) 1985-1987
ZC Acura Integra (JDM) 1990-1993
ZC Acura Integra (JDM) 1986-1989
ZC Honda Civic Si (JDM) 1986-1987
ZC Honda Civic Si (JDM) 1988-1991
Honda service manuel
88-91 et 92-95 Civic
http://www.honda.co.uk/owner/serviceManualsPdf.jsp
http://www.honda.co.uk/owner/CivicManual/
http://www.honda.co.uk/owner/accordManual/index.html
Merci à jackdrill
Home made shift light
http://www.national.com/ds/LM/LM2917.pdf
Calcul de compression:
http://www.c-speedracing.com/howto/compc...mpcalc.php
Here are the links:
CHILTON on line http://www.cybrrpartspro.com/Manual%20Lo...ookup.html
88-91 CRX Workshop Manual - 16MB
http://www.crxpower.net/~silverkorn/manu...Manual.pdf
EF B16 VTEC Manual - 7MB
http://www.crxpower.net/~silverkorn/manu...lement.pdf
Assembly Diagrams - 3MB
http://www.crxpower.net/~silverkorn/manu...agrams.zip
92-95 Civic - 90MB
90-93 Integra - 43MB
http://www.crxpower.net/~silverkorn/manuals/9093teg.zip
94+ Integra - 38MB
http://www.crxpower.net/~silverkorn/manu...ntegra.pdf
91 NSX - 51MB
HONDA ACCORD AERODECK 1986-1989
http://www.pauldesign.ru/honda/shopmanual.html
1995 - 1997 Civic Manual
1991 - 1993 Accord Manual
1990 - 1994 Concerto Manual
1988 - 1991 CRX Manual
1988 - 1990 Prelude Manual
1984 - 1987 Civic Manual
http://www.honda.co.uk/owner/workshopmanuals2.html
autozone online repair manuals :
http://www.autozone.com/servlet/UiBroker...deYMMEYear
__
bonne lecture et surtout bonne traduction si vous etes aussi douez que moi en anglais Wink
zeneman Hors ligne
Honda Cr-Z
83 - Var France
Réputation : 16
02-08-2005, 23:06:31   -
c sympat mais deja posté plusieur fois ;-)
> http://forums.quebectuning.qc.ca/viewmes...&Topic=309
Alex du Team AXC & HOMYSEED
[Image: Homyseedsign.gif]
maxvtec Hors ligne
03-08-2005, 13:17:37   -
j'avais pas vu, désolé mais il y a pas mal de lien interessant et c'est dommage que les personnes qui debutent n'ai pas ces infos :roll:
Jules Hors ligne
04-08-2005, 17:35:42   -   hello
SAlut
J'avais pas vu le lien de zen auparavant car jpcar est vaste mais celui là je l'ai pas loupé. Je suis entre la tanche et le top en anglais mais je vais essayer d'en lire le plus possible.
A+ Big Grin
Juless
[Image: banniere.jpg]
