Salut les amis, ça y es le rêve est réalisé, la belle est arrivée ce matin
Un grand merci a Omar et Guillaume de la société
www.gocarz.eu qui se sont occupés de l import avec un sérieux exemplaire
Pour la liste des specs, la voici (désolé en anglais)
D autres photos de meilleure qualité viendront par la suite
New parts in the last 10k include:
front discs with hawk pads front and rear
tein super street coilovers
both rear wheel bearings and hubs replaced
complete overhaul of rear diff including LSD,bearings and seals
engine mounts
clutch replaced both rear seals were changed on the gearbox along with the bushes.
steering rack replaced
Front and rear facelift lights
Facelift Indicators
OEM carpet
Facelift leather roof lining
TRD carbon spoiler
Full respray
New tyres
New Battery
New Wipers
The list goes on
Spec as follows:
Engine spec:
HKS forged pistons
HKS metal head gasket
ARP studs
HKS 256/264 cams
HKS exhaust adjustable cam pulley
5 angle valve modification to head
Turbocharger & Induction:
SP T61 turbo
S/S 4" turbo induction pipe
S/S modified XS power tubular manifold
Custom 2" screemer pipe
HKS style 50mm external wastegate
4" AEM filter
Custom 3" alloy intercooler pipe work from turbo to throttle body, using samco hose couplers
custom intercooler delta fin (same as apexi)
S/S goodridge oil feed/return hoses
Custom turbo heat shield
HKS SSQV 2
Custom Oil catch tank
Fuel, tuning & Ecu:
HKS VPC
Apexi safc 2
HKS FCD
HKS EVC 4
HKS turbo timer 2
HKS twin ignition ( DLI )
Racelogic traction control
Exhaust:
S/S 3" custom downpipe Vband heat wrapped
HKS 3" 2nd decat pipe
HKS silent hi power cat back
Cooling:
Silicon lower rad pipe
S/S upper rad pipe
Custom alloy radiator
Custom S/S rad cover plate
Toyota long life coolant
Drivetrain:
South bend DXD feramic clutch
Solid gear shift bushes
rear diff over hauled including LSD
Suspension,Wheels,Tires and Brakes:
Tein superstreet coilovers
18" BBS RS-GT Split rim alloys, 9" front & 10" rear refurbed 500 miles ago
Uk calipers painted black
Powerslot discs
S/S Goodridge braided hoses
Hawk brake pads front and rear
HKS front strut brace
Cusco rear strut brace
front toyo proxes T1R 225/40/18 nearly new
rear toyo R888 285/35/18 nearly new
Interior and ICE:
JVC touch screen head unit
Alpine 10" sub and amp
MVP alloy dash rings
Dash sprayed gloss black
Greedy alloy gear knob
Black oem carpet like new
Black leather facelift roof lining
Razo pedal set including foot rest
Alloy handbrake handle
Exterior:
Brand new Facelift front headlamps
Brand new Facelift rear lights
Brand new Facelift front indicators
OEM HID headlights
LED Side lights
Clear side repeaters
Full carbon TRD spoiler sides painted black leaving end caps and blade carbon
J spec front bumper without head lamp washers
Active spoiler fixed down
Bonnet lifters
Lexus spray washer jets
Other:
Stock TRAC removed and smoothed throttle body
Stock EGR removed
Custom PAS Cooler
Security:
Toad A606i Cat 1 alarm immobiliser
Performance:
Producing 538 rwhp at 1.2 bar and 471ft/lb of torque
