RX7 de Getaway in stockohlm 5
H.K.S Hors ligne
17-12-2004, 17:08:32   -   RX7 de Getaway in stockohlm 5
[Image: 1.jpg]
[Image: 2.jpg]
[Image: 3.jpg]
[Image: 4.jpg]
[Image: 5.jpg]
[Image: 6.jpg]
[Image: 7.jpg]
[Image: 8.jpg]
[Image: 9.jpg]
[Image: 10.jpg]
[Image: 11.jpg]
Mazda RX-7 (1993)
Engine Specs
13B – Rew with a Big extended streetport that flows for 220 hk without boost, theoretically at 1 Bar over Pressure it is estimated to make about 500 hk on the wheels.
The Engine has been totally renovated with race parts only. Hutley 3 mm race “apex” tipp seals and double springs to keep it intact. Gears and rotor bearings has been adjusted for a bigger bearing space, and a deep grove in the rotor bearing. Dynamic outbalanced excenter with balanced rotors and weight compensated. O-rings for the oil seal and new springs. The engine is reinforced on the detonation side with a 7075 T6 Aluminium block to prevent the rotor house form separating at high combustion and on high boost load. Exhaustport is ported for a hard pressure pulse too the turbine side for a quicker response.
Add on hardware
Greddy T88 34D Turbo
Greddy Stainless steel Exhaust manifold
Greddy 60 mm Racing Wastegate
Greddy 3Row FMIC
Greddy 100 mm exhaust
Greddy 100 mm Down pipe
Greddy Elbow
Greddy Type R Blow off valve
Greddy Pully kit
Greddy x6 52mm meters inkl EGT, boost, temp etc
Greddy Clutch line
Greddy Shift knob
Greddy Oil filler cap
Apexi AVC Type-R
HKS Twin Power Rotary Type
NGK R625 10.5 Racing Spark plugs
Magnicore 8,5mm and 10 mm ignition cables
AEM Programmable Engine Management System
AEM UEGO Sensor Kit
G.E.T Exhaust Temp Sensor kit
New racing fans
Flexlite Fuel cooling
Koyo Aluminium radiator
Expansion tank I aluminium
NOS 75 Hp dry nitrous on demand
NX Ntercooler kit, cooling of the intercooler by C02
2x OEM Pumps in tank
1x SX External race fuel pump
1x SX High Flow filter
1x SX fuel regulator high flow
New fuel lines
K2rd Fuel rail secondary
Extra mounted catch tank
Bosch 1600 cc Injectors on secondary
ACT Xtreme pressure plate ZX3-XTR6 spec 780 Nm
ACT Disc 6 plates
Sparco PRO 2000 x2
Willians safety belts 4 pungt
Autometer pod
Carbon fiber rear wing
Roll cage in the same Colour as the car.
Snap of for the steering wheel
Suade Steering wheel black
Tinted windows light
Mazda Speed GTC Front
Hood is customized by the owner
Mazda OEM 99 spec combo lights
New Paint OEM M6
New side markers in white
99 Spec. rear tail lamps
Rear wing Racingbeat Type 2
Tein HA Coilover kit
Cusco Stuntbrace
Fluids that are used
Motul 300V
Motul inergel 50 "Motorcool"
Motul Gearbox
Pennzoil Rear axel
Pennzoil power steering
Brakes
Hawk carbon pads
Brake houses in steel
Brake fluid Castrol SRF
Brake Callipers painted in red
Wheels
BBS Lemans 8,5 x 18 in front with 235/40 18 Pirelli Pzero Corsa
BBS Lemans 10 x 18 in the rear with 265/35 18 Pirelli Pzero Corsa
2x Original wheels with Bfgoorich DRAG radial
2x Original wheels with M/T ET Street 26*10,5 16
2x OZ 17" 3 peace split with race tires.
A VENDRE 35000€
[Image: pub1vm1.gif]
JapanSpirit Hors ligne
17-12-2004, 21:45:13   -
Merci Wink je cherchais justement le modèle de l'aileron et je voulais savoir ce qu'il y avait comme modifs (elle chauffe limite grave au bout d'une quart d'heure dans la vidéo)
Vive les chaudières rotatives...
[Image: banniere3.jpg]
17-12-2004, 21:52:38   -
On dirait qu'il la fait tourner à l'huile de synthèse dis donc...
kgil Hors ligne
18-12-2004, 17:00:46   -
Oh là là ! Le joli monstre!
Traction , Propulsion , Intégrale, Atmo , Turbo : BANZAÏ !!
bruno NISMO Hors ligne
18-12-2004, 17:58:24   -
je kiffe la RX7,
dommage qu'on est a pas en France!!!!!!!!!!!! :mp4:
snooze561 Hors ligne
mazda 6 2.2/ct200h
18-12-2004, 18:02:21   -
lolll heuresement qui yen a en france lolll
http://snooze561.free.fr/snooze
photos, playlist...
18-12-2004, 18:22:15   -
snooze561 a écrit :lolll heuresement qui yen a en france lolll
En France,
elle sont ou les RX7???
moi jen voi pas!!!!
TINOU Hors ligne
18-12-2004, 18:34:10   -
Moi j en connais 10 au moins
TINOU
collectionneur de mazda 323 bizarre
Didomars Hors ligne
Sujets : 30
18-12-2004, 20:44:52   -
TINOU, normal tu bosse chez mazda lol
La vitesse est un culte, la mort une fatalité
-== Didomars Membre Fondateur du Mazda French Club ==-
loony-q Hors ligne
18-12-2004, 22:54:08   -
très très chouette :!:
[Image: 6R2rcuu.gif]
NaYashy_MyNakytu Hors ligne
18-12-2004, 23:32:56   -
Vraiment la plus belle gt japonaise! magnifique cette rx7!
Ataru kun Hors ligne
19-12-2004, 17:49:18   -
En France,
moi jen voi pas!!!!
y en a pas un qui en vends une ?
depuis pas mal de temps du reste (mais elle est p'etre vendue)
MARCNSX Hors ligne
20-12-2004, 19:27:53   -
jolie
loony-q Hors ligne
21-12-2004, 19:27:31   -
Il y a une RX-7 en cours de péparation chez les drifters X aréa.
Jeff RX-7 Hors ligne
24-12-2004, 12:33:47   -
Heureusement qu'il y en a effectivement.....MDRRRR
[Image: avantcot8hm.jpg]
24-12-2004, 12:40:25   -
Jeff RX-7 a écrit :Heureusement qu'il y en a effectivement.....MDRRRR
vous etes des mauvaise langues.... LOL LOL
si je vous ecoute il y a autant de RX-7 que de 206 dans la rue en France!!!
LOL LOL LOL
24-12-2004, 22:59:49   -
Il parait qu'il y en a actuellement 26 d'immatriculées en france (dont certaines qui ne roulent peut etre plus...)
ça fait pas beaucoup tout ça Wink
  nouveau chez mazda... rx7 or not rx7 porcoleader 17 4 677 07-11-2005, 00:47:50
Dernier message: porcoleader
