Detail engine bay with WD-40 (91 Civic Si)
Robb Hors ligne
02-08-2013, 06:21:14   -   Detail engine bay with WD-40 (91 Civic Si)
Here's a writeup on how to clean up a dirty engine bay using WD-40.
This engine bay had a 20 year buildup of rustproofing and dirt, that dried up onto the paint.
I used WD-40 and a paintbrush and 4 microfiber towels.
Works amazing on 20 year old buildup of dirt and rustproofing. No joke.
Car had been sitting for 10+ years.. I basically spent 4 afternoons/evenings total on it.
STEP BY STEP
1. Go to the automotive store, buy 2 cans of WD-40 , 4 microfiber towels, paintbrush.
2. Open Hood.
3. remove battery, air filter box and arm, fuse box cover, wiper motor, map sensors assembly, coolant overflow tank, move away side wires and tubes on shock towers.
4. Start attacking the dirtiest parts with WD-40.
5. Spray and brush/agitate the grime/dirt
6. Wipe off dirt with towel.
7. Once all the bay is clean, you can buff and polish the paint around the bay and dress the rubber hoses with rubber and vynil dressing.
Keep doing this until all dirt is removed. It takes a while, but well worth it.
WD-40 wont remove the paint.
Note: As you will notice, some parts were replaced/restored as well.
[Image: 2bpbah.jpg] [Image: 2jacnex.jpg] [Image: k6cd0.jpg]
BEFORE:
[Image: untitled5.jpg]
[Image: untitled4.jpg]
[Image: untitled3.jpg]
[Image: untitled2.jpg]
[Image: untitled1.jpg]
AFTER
[Image: 33884780134_large.jpg]
[Image: 33884780128_large.jpg]
[Image: 33884780136_large.jpg]
[Image: 33884780129_large.jpg]
[Image: 33884780135_large.jpg]
[Image: 33884780132_large.jpg]
[Image: 33884780126_large.jpg]
[Image: 33884780133_large.jpg]
sebbouh Hors ligne
02-08-2013, 08:27:19   -   RE: Detail engine bay with WD-40 (91 Civic Si)
that's mad but takes hell lot of of time ! thanks for your sharing
02-08-2013, 09:22:18   -   RE: Detail engine bay with WD-40 (91 Civic Si)
I found an easier way to do this : go to the car wash, use some 'white spirit' or gasoline to clean the engine bay, and wash after application ^^
Robb Hors ligne
03-08-2013, 04:55:32   -   RE: Detail engine bay with WD-40 (91 Civic Si)
^^ uhh.. no.
skyline gtr Hors ligne
Godzillla/Bimmer E91
42 - Loire France
03-08-2013, 08:17:47   -   RE: Detail engine bay with WD-40 (91 Civic Si)
I don't like so much the car wash in the engine bay :S
[Image: 872167SkylineR32base.jpg]
03-08-2013, 11:17:02   -   RE: Detail engine bay with WD-40 (91 Civic Si)
never had a problem.
BiSBAR Hors ligne
03-08-2013, 13:02:08   -   RE: Detail engine bay with WD-40 (91 Civic Si)
why we still writing in english ?
Instagram : @bisbar_45
gineto Hors ligne
Réputation : 62
03-08-2013, 13:13:42   -   RE: Detail engine bay with WD-40 (91 Civic Si)
because Robb is from Canada Wink
loony-q Hors ligne
03-08-2013, 22:18:43   -   RE: Detail engine bay with WD-40 (91 Civic Si)
Only 2 WD40 cans Shock
[Image: 6R2rcuu.gif]
BiSBAR Hors ligne
06-08-2013, 00:02:22   -   RE: Detail engine bay with WD-40 (91 Civic Si)
Canada speak freeeeench ^^
no prob I can read ya !
I personaly cleaned my engine bay with some p5 and cotton , now its clean !
42 - Loire France
06-08-2013, 17:48:52   -   RE: Detail engine bay with WD-40 (91 Civic Si)
(06-08-2013, 00:02:22)BiSBAR a écrit : Canada speak freeeeench ^^
Just Quebec Wink
06-08-2013, 22:27:26   -   RE: Detail engine bay with WD-40 (91 Civic Si)
FREE QUEBEC Sac
kimken Hors ligne
Civic EK4
73 - Savoie France
10-08-2013, 12:03:59   -   RE: Detail engine bay with WD-40 (91 Civic Si)
it look like brand new. Amazing job Wink
Thanks fo the tip
Myzerykord Hors ligne
Cupra 5F
Suisse centrale Suisse
Réputation : 28
13-08-2013, 21:31:17   -   RE: Detail engine bay with WD-40 (91 Civic Si)
You changed a lot of bolts, don't you ? Wink
(10-02-2010, 22:32:08)Kyosuke a écrit : Par contre l'AE86 j'accroche pas sur cette caisse, on dirait une Sirocco.
Robb Hors ligne
13-08-2013, 22:22:44   -   RE: Detail engine bay with WD-40 (91 Civic Si)
Not alot.. just maybe 10.
chicken Hors ligne
200SX S14a
- Suisse
13-08-2013, 22:42:47   -   RE: Detail engine bay with WD-40 (91 Civic Si)
it's really clean, good job, maybe I going to try this on some part of my SR20 just to see the result after some km
Robb Hors ligne
18-09-2013, 02:42:36   -   RE: Detail engine bay with WD-40 (91 Civic Si)
Thanks ! Good luck !
Sxyllaz Hors ligne
06-04-2014, 19:14:45   -   RE: Detail engine bay with WD-40 (91 Civic Si)
Thanks
Colin MX5 Hors ligne
06-04-2014, 19:32:27   -   RE: Detail engine bay with WD-40 (91 Civic Si)
WD40 leaves a greasy film onto parts, after using it, use degreaser and rince, otherwise dirt is gonna stick to it quickly.
Robb Hors ligne
31-05-2014, 05:06:24   -   RE: Detail engine bay with WD-40 (91 Civic Si)
(06-04-2014, 19:32:27)Colin MX5 a écrit : WD40 leaves a greasy film onto parts, after using it, use degreaser and rince, otherwise dirt is gonna stick to it quickly.
You can clean it with water after.
  ENGINE DAMPER -arnaque Ebay ?pas hydraulique ! comprends poa Nightrider 22 4 455 16-06-2007, 15:44:39
Dernier message: alundra
  [Outillage] Engine Stand BugBtz 5 3 988 15-05-2006, 22:34:06
Dernier message: Urban Racer
  detail éstétique : peinture jantes => vos avis svp ! japcarman 17 3 388 27-10-2005, 00:39:17
Dernier message: japcarman
  e bay Zabuza 5 1 909 03-09-2004, 02:50:19
Dernier message: [Nicco]
