Méfiez vous des contrefaçons + Technique de l'embrayage
grumly2000 Hors ligne
Sujets : 99
22-11-2005, 11:56:28   -   Méfiez vous des contrefaçons + Technique de l'embrayage
en parcourant le site Exedy USA on trouve toute une page concernant les contrefaçons; les vendeurs qui mettent du OEM dans des boites Sports...
http://www.exedyusa.com/products/PDF/IMITATIONS.pdf
http://www.exedyusa.com/technical/GENUIN...UIDE.shtml
Citation :AUCTION WEBSITE PURCHASES
Exedy OR Daikin Clutch parts that are sold on EBay are always of great concern to us for following reasons:
There are many companies in Asia, that manufacture counterfeit Daikin Products and even go to the extent of copying our logo onto their inferior product. Please download the PDF above for more examples and what to look for.
Another reason, the Exedy sports clutch is engineered specifically for sports & performance applications. The standard replacement product is often substituted and sold as a performance product. Boxes & packaging are changed to hide the fact, so, for instance, its possible that you are really purchasing a Daikin Standard clutch and it has been reboxed into a sports clutch box to mislead you into thinking you actually purchased an Exedy sports clutch. Our recommendation to you is that you look up our website www.Daikin-Clutch.com and choose a distributor who carries our product. They are listed under Distributors / Exedy Sports & Performance Clutch Specialists. If you have any difficulties choosing a distributor please let us know and we will point you in the right direction.
All in all, we absolutely do not recommend purchasing an Exedy sports clutch on any auction website.
Egalement pour tout maîtriser sur l'embrayage.
très bien et très complet.
http://www.exedyusa.com/technical/files/...entals.pdf
http://grumly2000.labrute.fr
Tsuchiya Hors ligne
Sujets : 86
22-11-2005, 22:38:24   -
merci pour les infos mieu vaut se méfier lors de l'achat sur ebay
hondapowaa Hors ligne
Sujets : 110
29-11-2005, 15:01:34   -
bonnes info merci!
Mais donc comment savoir qui fait du faux ou qui met de oem dans des carton de perf??
jpense principalement a
-aimco clutch
-gripforce
-proclutch
(les trois plus gros sur ebay)
  technique demarrage avec vm allégé et embrayage stage 3? v tec 6 2 862 02-04-2007, 14:25:54
Dernier message: lovic
  Méfiez vous des rongeurs !! [Serieux] RB26DETTvs2JZ 20 4 620 02-02-2006, 19:20:33
Dernier message: Panda
  [Technique] Intéret des ressorts sport grumly2000 21 2 193 20-06-2005, 13:32:01
Dernier message: Greg_P
  Méfiez-vous des réparations de crash Maxiflooder 16 2 982 13-06-2005, 19:50:43
Dernier message: [ED9]Arno
  Appuyé vous sur l'embrayage au démarage? EK3-VTEC-PT 40 7 113 31-08-2004, 12:05:34
Dernier message: Suzuki Man
